Question about GE Nautilus 24" Built-in Dishwasher
Dishwasher when I start the dishwasher the water does'nt go in
  • feick2 Sep 14, 2008
    Our dishwasher is about 7 years old. I can turn it on and get a humming noise but nothing else. it dropped a little water in the bottom of the dishwasher but that's all.
  • willisde Oct 21, 2008
    Washer runs through the cycle (timer seems to be operational), water is turned on, and the bottom plunger apparatus appears to be going through its motions during the cycle but no water enters the machine.
Don' t know. jsut pulled it out to look at the fan to see if it had something stuck in it and it must have released something cause it started to run fine. thank you for your trouble
Posted on Sep 06, 2008
    Scholar:
  • 141 Answers
A few things to check:
- is the timer running? The first thing the timer does is open the water valve solenoid. You should hear a click immediately before the water flows through the pipe. If you don't hear this click, then either the dishwasher has no power (check your circuit breaker), the timer is faulty, or the solenoid is faulty.
- is the water turned on? Obvious question, but I have to ask.
- is the hose kinked somewhere?
You didn't mention if the rest of the functions work after the fill function. If so, it must be either the solenoid or a water delivery problem. If not, perhaps the dishwasher has no power, or else it is probably the timer.
Dishwasher is'nt turning on
You can test the latch with an ohmmeter. If the latch is good, check the fuse and look at any of your wiring for shorts or disconnections
Jun 09, 2012 | Dishwashers
Water is not coming into dishwasher.... it comes intermittently but ..does'nt clean properly
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 13, 2011 | Beko DE2541FW 18 in. Portable Dishwasher
My dishwasher does'nt drain, how can I fix that?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If it's still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 08, 2011 | KitchenAid 24 in. KUDP01IL - Multiple...
Bosch dishwasher, SHE43M 30" built-in, door won't latch closed, yet can still start cycle.
check latch on dishwasher side of the unit to make sure it has `nt got loose they make them so you can remove them when the unit is discarded so children can`t get trapped in side
Nov 06, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Water not draining
take the cover off the inside off the dishwasher and remove the food scraps and roate the wire around and even use the palm of your hand as a plunger
Jun 22, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Does nt drain
Check the following to address this issue further.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer or Control board
Replace if defective (note: uncommon problem).
Jun 19, 2009 | Bosch Dishwashers
GE Nautilus 24" Built-in Dishwasher Logo
134 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
