Question about Soltek SL-K890Pro-939 Motherboard
The Manual suggests copying the original Mainboard BIOS , along with AWDFLASH.EXE before upgrading the BIOS. How do I do this?
  • hkbuyer2002 Jan 21, 2009
    My motherboard cannot show the SATAII harddisk on bios. So that I cannot install window.
    What Can I do?
    Where to find the update bios?
    Please advise, thankyou very much!
    Philip
  • Anonymous Apr 07, 2009
    Do you have the manual for this board? Soltek SL K8Pro 939?
    Kind regards
    Rob
    Brigadier General:
  • 6,966 Answers
When you run AWDFLASH.EXE, it will first check compatibility of the new BIOS to the one installed. Thereafter before writing the new BIOS, it will ask you if you want to SAVE the old BIOS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 05, 2008
How to flash the JetWay 939AGP-P Bios
Get this installer programs and the Bios bin file and put them onthe desktop together and open the Awdflash exe program and fallow the instructions on this site
How to update Bios
http://www.jetway.com.tw/evisn/download/update.htm
http://www.jetway.com.tw/evisn/download/bios/Awdflash.exe
Mar 16, 2011 | VIA JetWay 939AGP-P Socket 939 K8T800 Pro...
On my motherboard the counter shows FF what does it mean, and how can I fix the problem(my monitor doesn't switch on)
The FF on the board just means that the motherboard completed an attempt to boot. That's it. Very vague i know...but in every instance of the ff code the board had to be replaced. Error code 2D may indicate a video problem...ultimately we could never know what to expect with generic codes like that...As an engineer I I would go a step further and try disconnecting the hard drive to see if you get the computer to get to the BIOS which would indicate a failed drive or corrupt OS Otherwise you are probably correct in thinking you might have a video problem which is onboard and would still require a board replacement. But save yourself the trouble and get another computer which doesn't have motherboards in it from shut down companies. I'd be glad to explore your options with you.
ASpecialty4You.com
Nov 10, 2009 | Soltek SL-K890Pro-939 Motherboard
My computer starts windows and restarts
It would be best to start with a fresh bios flash that you can download from
http://www.perfectdrivers.com/drivers/Bios/Soltek-SL-K890Pro-939-Bios-T1-4
or
http://driverscollection.com/?H=SL-K890Pro-939&By=Soltek
After this is installed then start the computer in SAFE mode and run a full virus, malware and spyware scan.
Then restart the computer in normal mode and if it fails again you will have to use a Windows restore disc, if you have one, or use the Windows installation disk to start and run a Repair on the system then restart it. Then download all the remaining up top date drivers at
http://rapidshare.com/files/12368442/SL-K890Pro-939.rar (51.394 MB) No pass required.
And run a full virus, malware and spyware sweep on the download before using it. Then install all the latest drivers to you system and restart. Then check for any Microsoft updates.
Sep 29, 2009 | Soltek SL-K890Pro-939 Motherboard
Error 1C
There is no 1C error code according to the manual...Looks like you might mean C1 which is a memory failure...try disconnecting your memory modules and check for any debris or anything that might be interfering with the connection and then put the memory back into the slots. If this still generates the same code you need to replace your memory.
Sep 25, 2009 | Soltek SL-K890Pro-939 Motherboard
Looking for the manual for a Soltek SL K8TPro 939 Mother board
You can download most of the drivers in the VIA Hyperion Pro Driver Package.
http://www.viaarena.com/default.aspx?PageID=420&OSID=1&CatID=1070
Let me know, what drivers you are missing after this install.
Apr 06, 2009 | Soltek SL-K890Pro-939 Motherboard
Need original bios
you should enter your motherboard manufacture website and dawanload new version
Jan 12, 2009 | Intel D845PT (KD845PTPAK10) Motherboard
Soltek SL-B8E-F Mainboard
I need a manual for this motherboard, the Soltek SL-B8E-F
Sep 02, 2007 | Intel Motherboard
Soltek SL-K890Pro-939 Motherboard Logo
273 people viewed this question
Top Soltek Computers & Internet Experts
John Anderson
John Anderson
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
