Samsung washing machine - no power
Apprears that nachine has gone out of balance and tripped household power - reset fuse all other appliances working but nothing starting in the washing machine.
Washing machine spins freely when turned by hand but program will not display.
Machine is less than 12 months old.
Checked internal wiring and found that when the machine went out of balance the counter balance on the top of the agitator drum had squashed the power wire against the the top rib of the frame causing the wire to short circuit and blow the power fuses to the house.
rejoined the power witr and relocated it above the rib frame so as to eliminate any further possibility of this happening again.
I believe this is either a design fault with the machine or it was incorrectly installed at the time of manufacture
Posted on Sep 10, 2008
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Why is my washing machine tripping my main fuse box even when I change the plug socket
by "tripping main fuse" do you mean the high amp (eg 60 amp or 100 amp) fuse that feeds the whole fuse box? if that is the case, there is too much stuff on in your house that's drawing power. The fuse box is too small to power all the stuff you have plugged in and running. Suggest turning off other high draw appliances in the house, like large TVs or microwaves or air conditioners, when running the washing machine.
Nov 18, 2013 | Washing Machines
Our old Hoover washer dryer had been working perfectly and then started tripping out - it would seemingly lose power mid cycle. We tried it in different plug sockets and using an extension lead with a...
ok I assume from what you are say that the circuit breaker in the consumer unit (fuse box) trips it could be that the circuit breaker is beginning to fail (they can go weak after prolonged use) and will tend to be a problem on high load appliances the water heater will take around 12.4 amps as will the dryer heater get the circuit breaker changed
Oct 24, 2013 | Hoover Washing Machines
No power to Whirlpool awo/d5727. I have checked the fuse and the socket but still have no power.
You say you checked "socket" and the "fuse," did you mean the AC wall outlet (115V) and a fuse or breaker in the main power panel?
Nearly all circuits involving water are protected by a Ground Fault Interrupter that can be servicing several wall outlets (perhaps one not near the washing machine) or can be located as part of a circuit breaker in your main power panel.
The GFI outlets will have one or two push buttons located between the outlets and a combination GFI/overcurrent breaker will also have at least one button where others will have none.
If you find one that is tripped, try resetting it. If it will not reset, unplug the washing machine and try again.
If it now stays on, your machine may have an electrical path causing it to trip and using an unprotected outlet may be unsafe and an indication that the appliance itself may have electrical leakage which could be otherwise dangerous.
The circuit breakers in the main power panel can also fail (they didn't 20 years ago) and we have replaced 3 in a home only 5 years old already so they are not made well anymore.
Jun 22, 2013 | Whirlpool Washing Machines
Our washing machine does not work at all. No power. Replaced timer and still nothing. We have model number 3XWTW5705SWO. Could it be the in line fuse?
I would suggest getting/obtaining a schematic diagram, your washing machine may incorporate a out of balance switch, or your water level censor switch ether on of thees can cause your fault, most likely your fault is the water level censor, it is the disk shape unit with the plastic hose connected to it at the bottom and wire connections to the top.
Apr 26, 2012 | Whirlpool Washing Machines
Oven not working - rest of appliance fine
It is most likely that the oven heating element has failed and will need to be replaced.
This not an overly expensive part to have replaced and should be much less than the cost of buying a new oven although you would need to compare actual costs in your area.
Jan 17, 2010 | Ovens
ZANUSSI 1237 Washing Machine
have you tried to plug your machine in a different socket try it if you can by using an extension instead of moving the machine.
Sep 22, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Hoover 205 washing machine
The actuator arm for the out-of-balance safety switch had become misaligned from the safety switch. As such, it had tripped but could not be reset.
Jul 03, 2008 | Hoover Washing Machines
Hotpoint WD51 fuse issue
is it the motor that got hot?, if so then check the motor carbons for wear, as these heat up when worn, also if the carbons are fine check the pump and filters for blockages, this makes the motor spin while water is still in the machine causing the motor to overheat, and subsequently tripping and blowing the fuses etc hope i have helped a little
Sep 25, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Hot point washing machine WMA 32
It's unusual for a household RCD to go out on excess current from an appliance - the fuse in the plug top and circuit fuse/MCB in the consumer unit should provide closer protection. This leaves you with an earth fault. Earth faults aren't usually related to motor load. Watch carefully what phase of the cycle the trip happens. Does it correlate with the start of water heating? A very frequent cause of low current earth faults is water ingress into the heating element. If you can trip the RCD reliably on every cycle, running the same cycle with the element disconnected would confirm whether or not this is the cause. A.
Feb 28, 2007 | Hotpoint WMA32 Front Load Washer
Washing Machines Logo
582 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
