Philips 22PFL3504D 22 in. LCD HDTV Logo
Posted on Aug 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Philips 22"
Anonymous
Level 3:
  • Master 998 Answers
  • Posted on Aug 13, 2011
Anonymous
Master
Level 3:
Answers
998
Questions
0
Helped
189408
Points
2955
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
1helpful
Philips 46PFL5706/F7 46 LCD TV. When you turn it on you have power. The Philips logo appears for a second then goes away. Screen is black after that.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
I need the base for my Philips Series3000 22PFL3504D Tv? Can I get a replacement part?
Hello ljhorning,
Welcome, and thank you for using FixYa!
You're in luck! I happened to find the part for you on eBay!
I have posted the link for you below.
Base
http://www.ebay.com/itm/TV-BASE-PHILIPS-PEDESTAL-22PFL3504D-F7-/220708658329?pt=LH_DefaultDomain_0&hash=item336342dc99
Have a great day!
3helpful
3answers
Fuse keeps blowing in my philips 32pfl3505d/f7 tv
Good day!!!!
That problem is cause of shorted bridge diode or power mosfet..
just see the picture below to see the image of bridge diode and power mosfet..
If you don't have a tools or you have no electronic background you only have to is order the new power supply board..
I hope this solution will be helpful..Thanks for using fixya....
3answers
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
We bought a new phillips moderl #22PFL3504D/F7 tv.
You can download the manual as a PDF here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=22PFL3504D/F7&slg=en&scy=US
There is also a link to Parts and Accessories on the left hand side of the page. Follow the link and enter your model number to get a replacement remote.
You can also buy a replacement remote at remotes.com:
http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12743739505150&smodel=22PFL3504DF7&brand_pn=PHILIPS_22PFL3504DF7
I hope this helps.
Trying to hook up a Philips 22'' TV to Sony CD/DVD player. Need help. I have a Red, White. and Black connector to go from TV to CD Player. Do I need anytning else? TV model # 22PFL3504D/F7
Usually the Color Red and White is for the audio channels and yellow is for the video but in your case you find black instead of yellow.
So you do the connection as per the instruction given below.
TV DVD Player
Red--------------Red
White------------White
Black-------------Yellow
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
