DFI LANPARTY DK P35-T2RS LGA 775 Intel P35 ATX Intel Motherboard Logo
Posted on Aug 13, 2011
Error Code 50 (on digital readout on motherboard). System hangs up on Lanparty screen
Have an Abit A17 motherboard that stops booting with a check sum error. Code on the digital readout is either IA or 1A, neither of which is in the manual. Any idea about this?
Press delete as the system boots up and go into BIOS Setup.
Change boot sequence so that your machine starts with the CD/DVD ROM disk.
Boot from the CD/DVD and do a clean installation.
I have a DFI LanParty NFII Ultra motherboard. I had to move the power supply to a different machine and have purchased a new one to drive the DFI system (Win Power) rated at 650w. The power standby...
It's the craziest thing, I'm looking dead at the Motherboard Manual for the DFI LanParty NFII Ultra B motherboard, and the diagnostic LED lights are Not referred to.
Looking at the view of the System Board, the LED lights are shown down by the CMOS Battery.
LED 1, 2, 3, and 4.
The manual indicates only two types of BIOS Beeps are listed;
1) One Long beep followed by Three Short beeps.
Video error has occurred and BIOS cannot initialize the video screen to display any additional information
2) Single Long beep
A DRAM error has occurred. {Problem with the Ram Memory modules}
The BIOS program is a Phoenix - Award BIOS, but doesn't indicate what version or date.
[ The motherboard manual is downloaded for free from here,
http://productsmanuals.com/computer-manuals/dfi-lanparty-nfii-ultra-b-system-board-user-manual
Go to > To view the Products Manual - or to Download it - just click HERE.
{Click on HERE}
Allow up to 30 seconds for the file to download.
Offhand I would say it is Ram Memory that is the problem. Remove the ram memory module/s, and clean the gold plated contact pins with a pencil eraser, then use air to remove the eraser dust.
However, in looking up for information on the diagnostic LED lights, (The info IS out there. Maybe on DFI's support website, but I couldn't find it), I see that if you are using a graphics card that requires an additional power cable, you'd better have that baby plugged in.
The motherboard won't work if the additional power cable isn't plugged into the graphics card.
Regards,
joecoolvette
I use a computer with a DFI LanParty Pro 875b (LP PRO 875B) Motherboard in it, and i can't get it to connect to the internet, either wirelessly, or through an Ethernet cable. the device manager says the...
Go to DFI and look for Drivers for your operating system...all device drivers are OS specific..or just purchase a new compatible network wifi or lan card and install it....
Blue screen on windows 7 with geforce 210 and 1 GB
May be Your Problem due to corrupt RAM DDR Commonly reason of Blue Screen Problem is Ram Fault.So U can change Ur Ram May B Ur Problem Will Be Solve.
5helpful
2answers
I have problems with my lan party 400a mother bord
Well everything doesn't work or it would post. I'd check the manual for the light code,it will point you to the problem. Other option is to contact thier support at the site.
I need to connect wires to DFI LANParty mother board.
You can find your manual here in PDF version, this will allow you to " zoom " in on any connection information your may need.
http://img.lanparty.tw/Upload/Manual/CM/lputnf4%20847505101.pdf
Top DFI Computers & Internet Experts
SmartAviator
SmartAviator
ADMIN Eric
ADMIN Eric
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
