Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Soap dispenser doesn't open
For three times now we have run the dishwasher to find the soap stuck in the dispenser like the lid just wouldn't open. What's up?
  • Anonymous Oct 27, 2008
    I have the exact same problem, which seems to happen intermittently. It's very frustrating.
  • Anonymous Feb 13, 2009
    I have the same problem, i am wondering if it matters what type of soap you use.Can you get a liquid detergent and just dispense it in the bottom of the diswasher I am wondering. Forgoing any need for the dispenser to open.
I have had the same problem in the past. Usually I found that something of large size was sitting in the corner just in front of where the soap door opens. The door tries to open, hits this item (in my case a cutting board) and can't open completely. Try keeping only short items in this corner and see if it helps. Good luck!
Posted on Nov 03, 2008
Dishwashing soap dispenser door won't close
Posted on Feb 19, 2009
    Sergeant:
  • 409 Answers
Check the dispenser for anything that may be caught in it. if you don't find anything, it needs to be replaced.
Posted on Sep 13, 2008
Soap dispenser on my Miele G646 Sci Plus doesn't open every time. Have cleaned the washer, run a full hot cycle with the washer empty; I always ensure the dish and surrounding is dry before inserting...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 12, 2011 | Dishwashers
I have a Hotpoint HDA2100 and I am having an issue with the soap dispenser. The lid is not opening all the way during the cycle. When I open the door after the cycle is complete to remove my dishes, i...
heatman101
Aug 07, 2011 | Hotpoint 24 in. HDA3400G Built-in...
My office's GE QuietPower 3 dishwasher detergent
heatman101
Jul 29, 2011 | Maytag Dishwasher
The detergent compartment on our dishwasher will open during operation. We have run the dishwasher three times and the detergent capsule remains in the compartment and is only partially dissolved. It...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
Apr 18, 2011 | KitchenAid Dishwashers
The gizmo that keeps the soap dispenser shut until it needs to pop open the dispenser lid during washing has fallen out and will not stay in .
heatman101 ,../,
Mar 22, 2011 | KitchenAid KUDK03ITBK Built-in Dishwasher
The some dispenser and the rinse aid dispenser seem to be "stuck", soap door doesnt open and dishes appear streaky from no rinse aid. this happened after I cleaned the deposits from under the screen in the...
There is a solenoid which pops open the soap lid after the initial rinse.
If the solenoid or soap lid latch is faulty, you will need to replace it. In the interim just poar your soap in the bottom of the dishwasher tray before cycle starts.
Only use a little amount as per normal. Dishwashing tablets are best as it is a measured amount and has the rinse aid built in.
Good luck.
Ash
Oct 21, 2009 | Bosch Dishwashers
Soap does not dispense from cup.
heatman101
Sep 07, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Dishwasher soap cup lid will not open during a wash cycle
heatman101
jj
Dec 31, 2008 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
258 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
