Question about Video Game Consoles & Games
My Wireless Playstation 2 Controller Isnt working
All im getting is a Flashing light That should stay solid when the controller is turned on
  • mike kyle
    mike kyle May 11, 2010
    Good chance that there could be a loose solder point or the receiver is broken.  does the receiver light flash when you hold the connect button?
    Problem Solver:
  • 5 Answers
I know it sounds simple, but mine does that when I need to change the batteries in it. I presume you *have* tried that, yes?
Posted on Nov 07, 2008
PS3 Controller Keeps Flashing
Does the controller actually turn on and if not you have to connect it to the ps3 or whatever your connecting it to
Oct 16, 2013 | Sony PS3 DualShock3 Wireless Controller...
Why wont it connect?
there is a sync button somewhere on the controller and the usb thing you plug into your Ps3, pres those at the same time continuosly put make a 2 second break untill it connects.
May 16, 2013 | PDP Afterglow AP.2 Wireless Controller for...
Chameleon controller isnt working
Are the batteries fully loaded? Are the IR lights on the top clean? Try fixing that and see if the problem still exists.
May 20, 2012 | Pelican Clear Translucent Chameleon...
My controller is plugged into my ps2 but it says my controller isnt? im very confused and have tried everything! help!?
The controller probably has faulty wiring. If that is the case, you should contact MadCatz about it and they may send you a new controller or at least give you a refund.
Mar 01, 2011 | Mad Catz Indianapolis Colts Wireless...
I just bought a Lava Glow Wireless Controller for my ps3, but i cant get it to connect to my system. what do i need to do?
With the playstation powered ON plug the USB Receiver in the Console into Input 1#. The Light on the receiver will flash rapidly. On the controller press the menu button. the led on the controller then will flash rapidly, press the menu button again while the LED on the Controler is Flashing. Once you have done this you should get a solid Light on the controler. Now your controler is set.
Jan 18, 2010 | DreamGear Lava Glow Wireless Controller...
How do I get my Mad Catz wireless controller for ps2 to work? Not sure which buttons to press on controller to get it to work.
If the reciever is plugged into the console it should just work. There IS a power button on Mad Catz. Make sure it's turned on but other than that it should work. It doesn't need to be synced to the reciever. It was made already synced. Check the batteries. Make sure the reciever is plugged all the way in.
Nov 30, 2009 | Mad Catz NFL Controller for PlayStation 2
PS3 Controller wont turn on?
mine sometimes does that, just try pushing and holding it until the options come up on the screen, then turn off controller. Then try turning it back on. If that doesn't work, turn the ps3 off when its done charging, then unplug it while its off. This should work.
Aug 19, 2009 | Sony Wireless Controller for PlayStation 3
Ps3 will not reconize intec in any way wireed or wireless. just invisible
CONNECTION A:
DO NOT INSERT BATTERIES INTO THE CONTROLLER; THE USB CABLE USED WILL SUPPLY THE POWER TO THE CONTROLLER.
STEPS # 1 – TURN THE POWER ON TO THE PS3 CONSOLE.
STEP # 2 – CONNECT THE USB CABLE TO YOUR PS3 CONSOLE AND CONTROLLER.
STEP # 3 – NEXT PRESSE THE SYNC BUTTON ON THE CONTROLLER, THE CONTROLLERS LED INDICATOR’S LOCATED ON THE FRONT OF THE CONTROLLER WILL START TO FLASH RAPIDLY.
STEP # 4 – CONNECT THE USB RECEIVER TO THE USB PORT ON THE PS3 CONSOLE.
STEP # 5 – WHEN THW CONTROLLERS LED INDICATOR’S LOACTED ON THE FRONT OF THE CONTROLLER START FLASHING SLOW PRESS THE HOME BUTTON.
WHEN THE CONTROLLER HAS ESTABLISHED A CONNECTION BETWEEN THE CONTROLLER AND THE USB RECEIVER ONE OF THE CONTROLLER’S LED INDICATOR’S WILL BECOME SOLID RED.
Jul 12, 2009 | Intec PlayStation 3 Turbo Shock III...
Controller not working
I had the same problem, so I called customer service and had me do this:
1) with the USB cable plugged into the controller, power down the ps3 and turn the on/off switch in the back to "off".
2) hold your thumb down on the front button (where you normally can turn it on) while turning the switch on the back to "on" again. keep your thumb or finger on the front switch.
3) You will hear the normal "beep" that you usually hear when the PS3 boots up, but after a few seconds later, you will hear a secondary beep. Remove your thumb or finger after this second beep and the PS3 will reset itself after a few seconds. I have a projector connected to it, so I had to set the display screen back to HDMI afterwards, but when I disconnected the USB cable the controller worked wirelessly again. The customer service rep said that this allowed the controller to pair with the PS3 again. Note: You probably do not have to have the controller plugged into the USB cable at all while doing this. I just happened to have it plugged in. Hope this helps.
Mar 29, 2009 | Sony Wireless Controller for PS3
Guitar hero 3 on ps2
You need to plug the controller in before you turn on the ps2. Don't change out controllers unless you reset the game system.
Aug 21, 2008 | Electronic Arts SSX Tricky for PlayStation...
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
