Question about Compaq Presario M2000 Notebook
Laptop screen i picked my laptop up by the monitor and now i have color lines like ink is busted...i don't know how to explain it. but i cant even see anything half way down the screen
    Brigadier General:
  • 5,158 Answers
You may have damaged the screen itself... did you hear anything breaking or did the monitor itself bend.
there is a possibility that you have pulled the connector for the screen partially loose. disassembly is required to confirm that. and attach the cable properly.
I'm hoping you have a dell as they seem to have excellent manuals on their site for disassembly instructions.
Robert
Posted on Sep 05, 2008
Why does my monitor have colored vertical lines?
Hi Shannon,
I don't have good news for you. Coloured vertical lines is a symptom of terminal failure of LCD screens. Most common in laptops, monitors, and TVs. Problem only gets worse with time with more lines appearing, then expanding to cover a whole side of the screen. 30 - 50% normally.
Jul 19, 2012 | Dell Inspiron 2200 Notebook
Where to hook up speakers on monitor and desktop
The color codes [if even present] probably don't match
the PC should have its outputs marked with both color AND an icon::looking for 'line out'; headphone; speaker
Feb 19, 2012 | Gateway Computers & Internet
Hi, My acer laptop screen gets color vertical lines and cant see anything else. sometime it works fine but after some time it gets lines again
HI There,
The easiest way to troubleshoot your problem is to connect your laptop to an external monitor. If the lines on the laptop screen don't appear on the monitor, then you know you need to replace your screen and screen inverter.
If the lines appear on the external monitor as well, then your video card on the motherboard of the laptop is failing and you'll need a new motherboard or want to consider a new laptop, depending on the repair cost.
Regards,
Marcus
Nov 10, 2010 | Acer Aspire 5580 Notebook
From yesterday i have been getting this streak flash type of line on the bottom of my screen ....being display in every 2 secs ...green or white in color l though its not hampering the operation of the...
Hello:
Your most likely cause to the color flash on your screen is a bad LCD panel. One way to troubleshoot this is to hook an externa monitor up to your laptop, and observe the display on the external monitor. If it is ok, then your LCD is the cause. If you still experience the flash, you could have a motherboard video problem, but unlikely.
There is no easy fix to get rid of the flashing line. If your laptop is still under warranty, or even close, I would contact HP /Compaq customer support and explain your laptop's problem.
Hope this helps !
Oct 15, 2010 | Compaq Presario Notebook
It displays colorful lines on the monitor...cant see nothing
Test your laptop with an external monitor and find out if the external video goes bad too. If both, internal and external images go bad, you have a problem with the video card.
If external works fine and only internal goes bad, most likely it’s either bad video cable or LCD screen failure.
May 21, 2010 | Nvidia GeForce 7200 Graphic Card
LCD screen is busted
Once a lcd screen is busted there is no other choice but to replace the lcd. You can always hook the laptop up to a monitor in the meantime and use that for your output.
Nov 30, 2009 | Compaq Presario Notebook
No display on screen
It's either the backlight lamp or screen inverter is busted. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Boot up.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the screen inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 25, 2009 | HP Pavilion dv9000z Notebook
Screen with a weird flickering and coloring on Acer 5715Z laptop
To determine if he video card is faulty, connect an external monitor to the laptop's external video port, then power up the external monitor and then the laptop. The video info should automaticall switch to the external monitor. If you see anormal Windows image on the monitor then the video card is OK and the fault is with the LCD screen, could be the video cable/connector. Try reseating the video cable/connector to the motherboard.
If the video card is faulty and because it is part of the motherboard it is extremely dificult to repair, usually a replacement motherboard is required. This may not be a cost effective solution depending the age of the laptop. You could remove the hard drive from this laptop and insert it into an USB hard drive adapter case and use it as an external USB drive.
Aug 16, 2009 | Acer Computers & Internet
My screen has color lines in the middle do i have to change
Same with you i have may experience also regarding a color lines in my laptop monitor, so what i did is that i find a computer shop in my area and i let my laptop checked with their technician and ask what is the problem of my laptop then the technician explained to me what are the causes of those lines and then they fix it for me. So i just wait for 30 minutes then my laptop is back to its original condition.
So my recommendation: please find a computer shop in you place and let them check and fixed the problem.
thanks
Aug 04, 2009 | Toshiba Satellite P105-S6207 Laptop
Monitor is busted
Hello David,
I think along the lines like you. $500 dollars is a good chuck of money and alternatives would be my first choice. My suggestion is to check both ends of the cable harness the plugs into the screen and to the mother board. Make sure both ends are inserted properly.
Next thing is to test - power up the laptop and see if that made a difference. If not, it may be the screen or the motherboard. So test further by pluging in an external monitor to check to see you get a good picture/image. If so, then that means you need to replace the laptop screen. If you dont get a good picture/image, than that means your motherboard needs replacing.
Hope that helps and good luck.
Jul 20, 2008 | Dell Inspiron 700M Notebook
Compaq Presario M2000 Notebook Logo
46 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
