Question about E-Machines e15t 15" Flat Panel LCD Monitor
Computer monitor image curves at sides.
When on the desktop the image looks fine but when I load a game or another program that takes up the screen the image seems to curve into the sides like playing on a cylinder. been through most of the settings in the menus but nothing seems to work...   thanx for the help!
  • 4 more comments
  • mike kyle
    mike kyle Sep 05, 2008
    its a newer Emachine and theres no plugin cards its all the way i bought it. and its not only the games (ive tried a few) its any program that takes the screen off of the desktop (music editing software, games, movies, etc)
  • mike kyle
    Driver version 5.1.2001.0
  • mike kyle
    mike kyle Sep 06, 2008
    first off i have to apologize the monitor is an emachine, the computer itself is an IBM  the driver i got was from the device manager for the monitor. i cant seem to find the model of the tower itself.
  • Roberta Smith
    Roberta Smith May 11, 2010
    a couple of things you can try. ensure you have the correct driver for your video... chances are it has a video accelerator on the board. often the driver offered is not the newest (as i've experienced with my compaq). go into device manager and see what device is used for video. right click on it and then properties.... select driver from the tabs.... write down the version driver it is using. oh and the type of video accelerator it uses.
    I'll look up the driver when i have a moment.
  • Roberta Smith
    what is the computer brand and model.... and are you using an add on video card ?
    Oh and what is the game as well ?
  • Roberta Smith
    two things i need... what is that driver for ....and what model number emachine do you have so i can look it up.
I need a solution for that
Posted on Sep 05, 2008
My Viewsonic 2235 monitor only shows the desktop top on 70% of the upper screen. It was fine and I ran Paretologic. When I rebooted, the screen images are egg shaped or stretched out side to side. ...
If you have an Auto Adjust option on your monitor, press that and it should adjust the screen to the correct size.
The button should be on the panel or it might be a setting in the monitor settings itself.
Hope that helps
Dec 15, 2010 | ViewSonic VX2235WM Monitor
My monitor has a hourglass screen and not a full screen please help
Look in your monitors menu screen. You will see a setting to change that. On mine it is labeled "Pincushion", it bends the middle of the screens image to compensate for the curve of the glass
Sep 22, 2009 | HP Computers & Internet
I have a Dell monitor and the text is blurry and fuzzy, how do I fix this?
this is actually from dell support website.. hope it will correct your problem...
1 Ensure the correct resolution is set for the monitor. Flat panel monitors display the sharpest, clearest images when set to their optimal resolution. Sometimes games and other programs will change the resolution then fail to set it back once they are closed. This will then make the desktop look big, distorted, and grainy. Perform the following steps to adjust the resolution:
  1. Right-click an empty area of the desktop, and then click Properties. (Or, click Start, click Control Panel, and then double-click Display.)
  2. In the Display Properties window, click the Settings tab.
  3. Under Screen resolution, move the slider to the desired setting. For most flat panels the optimal setting will be all the way to the right.
  4. Click Apply, and then click OK.
  5. If prompted, restart the computer.
NOTE: If the resolution will not adjust to the appropriate settings, the video driver may need to be reinstalled or updated.
2 Ensure the screen is clean. Finger prints and smudges will make the screen look blurry. Clean the screen with a soft lint free cloth. If needed, dampen the cloth with warm water or use a LCD cleaning kit that can be purchased from most electronics stores.
3 Use the On Screen Display (OSD) on the monitor to select the Auto Adjust feature. Selecting this will synch the video signal and can sharpen the video image.
4 Reseat the video signal cable to ensure a secure connection.
5 Use the On Screen Display (OSD) on the monitor to select the Factory Reset feature.
6 Test the monitor on another computer or test another monitor on this computer. If available, testing different hardware will isolate if the problem stays with the computer or monitor
Sep 12, 2009 | Gateway FPD2275W LCD Monitor
Distorted shrunken picture
reduce the resolution to a bit lower and the refresh rate to a nominal 60hz and things should get back to normal
my hunch is u r using a slightly high resolution and refresh rates
but before that try the buttons on the monitor to see if expanding the image sideways or top and bottom would help initially
pls rate if this was any help
Mar 31, 2009 | NEC MultiSync FE700 17" CRT Monitor
I have a ViewSonic Monitor, model number Vs11307. The screen is all blurred and the screen isn't adjusting properly. The screen is shifted to the right and I have a blank rectangle at the left side. I...
I had the same problem same model. The image was off center to the right and it couldn't be fixed by the auto-image adjust or the manual adjust.
My solution was really simple, I moved a video player (RealPlayer) onto the monitor and maximized the screen, then pressed auto-adjust once. It worked.
Jul 14, 2008 | ViewSonic Computers & Internet
Wide screen problems
I guess the video board or logic board is having problem.
Apr 24, 2008 | ViewSonic VX1935wm LCD Monitor
Blank screen
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went white, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace.
Thank you,
Mar 18, 2008 | Mag Innovision LT776s 17" LCD Monitor
Monitor issue
Look to Caps on the inverter if its an LCD or flat pan. monitor.. Weve seen this be4..
Jan 13, 2008 | Norcent Technologies LM-762 17" Monitor
Screen image display distortion
What you are reporting is a problem in the pincushion circuit in the horizontal section of your CRT monitor. Usually this is from an electrolytic capacitor that is no longer willing to play nice with all the other components.
It is repairable, but get an estimate first. If the repair bill appears to be around $100, you would be better off to put a few more dollars with that and buy an LCD TFT monitor.
If you are quoted $25 or $30, it is probably worth having repaired. Just keep in mind that these older CRT monitors have age on their components, and once repaired, it will still be an old monitor.
Only you can decide which choice is right for you. At least now you have a few facts to help make the decision.
I hope this helps.
Nov 06, 2007 | Apple Multiple Scan 1705 Monitor
Screen does not maximise automatically
reinstall the driver for your monitor or adjust the resolution in the desktop properties
May 14, 2007 | LG Studioworks 700S 17" CRT Monitor
E-Machines e15t 15" Flat Panel LCD Monitor Logo
103 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
