Question about Philips 50P8341 50" Rear Projection Television
Philips 50p8341 hi my problem is this first there was a dead set, I replaced fly back and powered it up and heard the it come on and the crt's fire up but had no picture or sound, but I did notice the crts were very dim sow I turned up the power to them on the focus block and they lit up. Now there is a rainbow curved lines with no sound and the remote has no control or the menu button. sow I replaced the convergence ic both of them and ic 7612 it was bad on ssm board, also changed the ic7550 and the power reg next to it. replaced ic 7402 audio out. I checked all diodes. on all the boards nothing bad. but resistor r3306 was not looking good i removed it and it was good. I was looking for r3307a but had no luck finding it. I though It could be the ssb board but I have to tv same model and switch the the new one id nothing to change this. any help you could give would be nice Dave
    Brigadier General:
  • 5,158 Answers
Time for some old fashioned trouble shooting. first divide the issues... the remote not working could possibly be a connection issue.
second you can do a soft reset ... unplug the tv for about four hours.
third is to check for cold solder joints. that requires first smacking the tv (yep pretty old fashioned test). if anything changes you need to localize where the problem is.
You need to be EXTREMELY CAREFUL for this next part. power on the tv and tap components on the circuit board gently with a non conducting item. even a hollow pen would do... or something plastic.
Be aware that you are dealing with electricity so be very careful with that.
any changes on the screen as you tap components indicate most likely bad solder joints... after you have unplugged the set resolder those components.
also inspect by feel the capacitors on the circuit board .... feel for rounded tops. any you find need replacement... not the values of the component as well as the orientation of them.
I will stress again... when you are testing for bad solder joints be aware that it is electricity you are dealing with and it has the potential to kill you.
Robert
Posted on Sep 09, 2008
    Genius:
  • 2,035 Answers
Well you need to have service manual which will guide to trouble shoot step by step , and it contains details part number for parts you get one from this link:
http://servicemanuals.vstore.ca/
Good luck.....
I need to change the flyback of my TV Philips of rear projection model 50P8341. I do not Know how to remove the damage flyback. First, I tried to remove the anodes that are connected to each of the three...
Leave the CRT's alone!!!!! You will ruin them. The red wires come out of the Fly-back. Pull the rubber caps up and then with a twisting motion pull each red wire out 1 at a time.
Apr 27, 2011 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television
normally when something like this happens, we could right away propose what can be done, in your case, since youve already changed a lot of parts on that tv, you can at anytime fix it. the tv alone is not fixed yet as of the moment but to some it up, experts have already given you some ideas on how to fix the tv. cheers. hope youll fix that tv in no time.
Mar 12, 2008 | Philips 50P8341 50" Rear Projection...
My Television wont turn on and the power button just blinks red and then shuts off, after a minute or so.
Power supply board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a reburbish power supply board for the replacement.
Take care.....
Nov 29, 2010 | Philips 50P8341 50" Rear Projection...
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
How do I replace the Vertical Output IC
Replace the Small Signal Board Part #313912725871
This is a common problem withis TV.
Jul 30, 2009 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 Does Not
Have some one with experience on repairing tvs try this and it will determine wich board is bad and the you can go to www.tritronicsinc.com for the part.
Have them unplug the connector from the LSB to the SSM (the plug that feeds the voltage to the convergence IC’s, toward the front of the set) If the H/V comes up replace the SSM. If the H/V don’t come up unplug the CRT’s from the H/V generator. If it comes up see which CRT is bad if not replace the LSB first and the SSB if that doesn’t work.
Aug 20, 2008 | Philips 50P8341 50" Rear Projection...
55P8341
sounds like the red CRT may be shorted.You can get a repalcement Red CRT at the following link for a very reasonable price. If your not sure which one your model uses. leave them a email with your model number of your set.
Aug 12, 2008 | Philips 50P8341 50" Rear Projection...
Remote control
Just to make sure you have the correct remote, please match the part number you received to the part number in the link below (this is the original direct from Philips for that model).
50P8341 Original Replacement Remote
If the remote is correct, then you may have a problem with your IR remote receiver that is located on the TV set. This part however has been discontinued.
Mar 27, 2008 | Philips 50P8341 50" Rear Projection...
The bulb recently burnt out. Need to replace it.
Your set doesnt have a bulb. Its a crt projection unit. Is the set completely dead? If so troubleshooting the power supply is needed. If the audio works but no picture, then the deflection/HV circuits will need troubleshooting. Let me know if I can assist you further.
Feb 27, 2008 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
