WHY Force the Arctica to Defrost if it Don't Want to? Don't
bother using the self-diagnostics feature to force a defrost cycle. On some
models - those with control knobs - which technically are not Arctica models (Arctica
models have plastic liners with touch pads - Standard GE electronic models
with metal liners have knobs) servicers would have to invest in parts to build a
"test" control panel, complete with touch pads and digital displays, to
achieve this (self-diagnostics) function. Instead, save both time and money by
following this helpful Arctica Tip: If a frosted evaporator or a "frost
block" is apparent, initiating a defrost cycle may not reveal anything helpful
anyway. First, disconnect power and then simply check the resistance across the
defrost heater and bi metal circuit at the main board located at the backside.
The two associated wires at the main board are almost always BLUE and ORANGE.
The heater/bi-metal circuit should normally read around 30 ohms roughly. Next,
check the evaporator thermistor at the main board between thermistor input
terminals J1-4 (Blue/White) and J1-5 (Blue) to determine that its resistance is
greater than 1.2k ohms but not more than 166.8k ohms depending on its ambient
temperature. If thermistor resistance falls within this range according to
temperature (Approximately: 6k ohms at 70ºF - 16.3k ohms at 32ºF - 51k
ohms at 0ºF) and the heater/bi metal circuit is diagnosed as good, then replace
the main board. Note: Always check the tech sheet per specific model to verify
wire colors and terminal locations. The best way to determine what has caused a non defrosting
GE electronic control model is to first access the control board. Jump terminals
line power to defrost, (J4 and J9). An amp probe should be placed on this jumper
wire to determine current draw of the defrost circuit. A three amp draw is what
is normal for this circuit. This will eliminate checking behind the evaporator
cover to determine a defective heater or over temp device (defrost terminator).
Note: This test is only to check the defrost circuit. It does not initiate a
defrost cycle. If the unit is in any other cycle than defrost, that cycle will
continue to operate as well.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
