Question about HP WLAN MultiPort W200 802.11b Wireless Adapter
WLAN W200 adapter...problems with linux.
Hello, looking for a simple solution, or...a step by step intructions on how to solve my problem. I just installed Fedora 8 on my computer and realized that my fedora doesn't seem to like my built in adapter (the wlan multiport w200...i run on a compaq evo n610c) and i can't seem to find a simple downloadable driver anywhere. and it seems like the installation of a different driver for linux that can support my adapter is kind of complicated to do. if you could help me with this, it would be GREATLY appreciated.
Thanks,
Tyler
(By the way, i dont see a place for my email at the moment..my email is stonecold712@hotmail.com, again, thanks!)
3 Suggested Answers
SOURCE: WLAN Multiport W200 not connecting to wireless network
Seems I am in the same boat. I brought my N610c over to my parents for Xmas and the W200 was trying to connect to the D-Link wireless router my dad has. It kept not finding anything and then, BAM, BSOD. Restarted.....same thing after 2 seconds of the Welcome screen. Something's messed up with the W200 somehow or another......
Posted on Dec 25, 2007
  • 7 Answers
SOURCE: Wlan W200 connection problem
There is a solution to this, and you won't have to buy a new card. The folks at HP, however smart in their design of this laptop, have not properly updated the bug fix for the wlan w200 drivers. What you'll need to do is actually take back your network adapter driver all the way back to Version 1.0 revision C. I did this with an n610c that I got for free because it was BSOD'ing every time the wireless was turned on. For the most part the wireless can handle older routers and wlan areas, but will BSOD when within range of a wireless "N" adapter. Simply download the driver version 1.0c and you should have no more issues.
Tip: You can disable the card manually by pressing your "Fn + F2" keys, rather than trying to navigate your menus before getting the BSOD.
Posted on Oct 11, 2009
computer1990
  • 65 Answers
SOURCE: Hi Guys. Compaq Evo N610C equipped
Yes you have to go to your internet's routers web setting page and change your settings from whatever you have now to WEP and follow these instructions.
Sup guys i found the cure to this horroble blue screen death for this N610c. Ok i called hp and they wanted $69.99 for tech support well just imagine what i told them to do lol. Anyway i did my research and guess what i found out. That the updated driver is made to screw up your connection so that you have to call tech support and they can steal your money.
Im a computer technician since 1990 and what i discover was that beautiful driver that works here is a list of drivers that cannot be used on the Evo N610C because it causes conflits that no one can fix i know for sure.
List of the no no drivers are:
These drivers will make your screen go from windows to BLUE.
sp29156
sp28252
sp29156
Here is how i fixed the problem i deleted everything that had to do with LANMultiport drivers every single one then i searched my laptop to remove the rest of the lost files.
Once that was done the i installed this driver (sp23031)
Once that was installed and the puter rebooted the wifi card found my wireless connection and asked me to input my Network Key and walla it works great now without any problems.
Im using windows XP Home i just bought memory cause im installing windows 7 32 bit.
Finally the key is this driver (sp23031) for both home and pro eddition.
Here is the link to download your driver:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=hb-13082-1&lc=en&cc=fr&dlc=en&os=228&product=235687&lang=en
It works! Please hit me up a feedback
Posted on Dec 24, 2010
Hpcompaq wlan w200 driver win7
OPERATING SYSTEM SUPPORTED:
Microsoft Windows 2000
Microsoft Windows XP 32-bit Home Edition
Microsoft Windows XP 32-bit Professional
OPERATING SYSTEM NOT SUPPORTED:
Microsoft Windows VISTA -WIN7
Apr 03, 2012 | HP WLAN MultiPort W200 802.11b Wireless...
Since I did a clean install of my OS can not
jeffrundall
To be able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
Dec 26, 2009 | HP WLAN MultiPort W200 802.11b Wireless...
Please my laptop can not detect any wireless network and i have downloaded the latest drivers and its still not working. i was told it might be the wireless network adapter, please how can i solve this...
Check wether your laptop is genuine OS have install proper drivers. If yes, then contact to dealer and get it chek, may have the wireless network adapter issue.
Nov 22, 2009 | HP WLAN MultiPort W200 802.11b Wireless...
W200 cause a blue screen
First of all: If you install SP2 you don't have to install SP1 over it. It already did. Secondly, don't install SP3, it destroys Windows XP.
Try reinsalling the PC with SP2, install the drivers and do nothing else, see if that helps.
If not, by all means post back here,
Yannick.
Jun 16, 2009 | HP WLAN MultiPort W200 802.11b Wireless...
Compaq wlan w200 bsod with wrt54gs router
Check your router config for wireless "N". if it's there, disable it. You can also use the driver on the compaq to go back to the install of driver 1.0c
Dec 20, 2008 | HP WLAN MultiPort W200 802.11b Wireless...
Blue screen on HP WLAN MultiPort W200
Rollback the W200 driver to version 1.00C. Subsequent drivers are incompatible with XP SP2.
Unfortunately, WPA support came in version 1.00E, so W200 + XpSp2 = no WPA support. :(
May 21, 2008 | HP WLAN MultiPort W200 802.11b Wireless...
Nov 07, 2007 | HP WLAN MultiPort W200 802.11b Wireless...
Anyone who has this problem: the problem is with the W200 driver that HPclaims you should use. Download this driver instead and your problems should be fixed:
Oct 20, 2007 | HP WLAN MultiPort W200 802.11b Wireless...
Network adapter
download a program called driver genius (its free) this will scan youre pc and inform you of all the drivers you have or require.if you purchase the program it will find and install them for you.but it solve youre problem.if next time you could mention brand of laptop I could probably tell you the drivers you need or at least the site.
Oct 08, 2007 | HP WLAN MultiPort W200 802.11b Wireless...
HP WLAN MultiPort W200 802.11b Wireless Adapter Logo
140 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
