Question about Microsoft Xbox 360 Console
Xbox 360 power converer
Power converter led light should be green but the light is red. tried unplugging from console but does not fix problem
    Master:
  • 505 Answers
Power adapter Is faulty
Posted on Sep 05, 2008
My son's x box has 3 red lights on the circle and won't switch on
Refer to this thread for the xbox 360 "red ring" problems. http://forum.teamxbox.com/showthread.php?t=472553
Mar 07, 2011 | Microsoft Xbox 360 Console
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
3 flashing red lights
on my xbox 360 i sent it in to the company to get fixed three times all three times it came back in the same condition i used another power supply block the grey block---powersupply is possibly bad try using another one first there are video's on utube on how to fix it if that doesn't work
Nov 25, 2009 | Microsoft Xbox 360 Console
3 red lights
Turn off the xbox 360, then look at the power supply, is the led light on the power supply is green..
then you need to submit a console repair request to microsoft.
http://support.microsoft.com/kb/907534
microsoft offers a 3 year warranty and will fix the three red light error for free..
Oct 30, 2009 | Microsoft Xbox 360 Console
MY 360 HAS 3 RINGS AND WON'T WORK BUT EVERYTHING ELSE IS FINE.
THINGS TO TRY
  1. Try restarting the console.
  2. If restarting the console does not resolve the behavior, follow these steps:
    • Turn the console off.
    • Unplug all the power and AV cables from the console.
    • Unplug the power cord from the wall socket.
    • Firmly reconnect all the cables.
    • Turn on the console.
  3. If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
  4. Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
If the above suggestion dose not yield results, i would use the link provided below to help fix this issue yourself.
CLICK HERE(XBOX 3RINGS FIX)
Jun 18, 2009 | Microsoft Xbox 360 Console
Xbox 3 lights blinking
THINGS TO TRY BEFORE REPAIRING THIS ISSUE
OK, if the above suggestions didn't fix this , I suggest using the link below to further dive into the repair of the 3 rings of death issue.
CLICK HERE
My xbox 360 has 3 flashing lights?
Now, if the above troubleshooting tips don't yield results, i recommend using the link below to combat this issue further.
CLICK HERE
May 22, 2009 | Microsoft Xbox 360 Console
Red Light on Plug in connecter thing
Sounds like there is something wrong with the Xbox 360 power supply, try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord. Give it a minute then reconnect it all back, also try it on another wall outlet without any extension cord at all.
If it's still red that suggests fault with your Xbox 360 power supply so will need to contact Xbox 360 customer support if its under warranty they should be able to sort it out for you. If out of warranty it might cost you for a new power supply!
Dec 13, 2008 | Microsoft Xbox 360 Console
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
My xbox no show no picture
3 Red Lights Flashing - is a general hardware failure
  • Unplug everything and let it sit for 20 min. Re-connect and try re-starting
  • If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
  • Check the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the console flash red.
Check here for more things to try
Oct 30, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
42 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
