Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Help needed fast
Im having a problem with my wd-52525 tv the red light keeps flashin until i reset the tv .then a rapid green light comes on ...i then proceed to turn the set on and nothing happens could you help me with this problem ....just to let you know i recently replaced the bulb.....
    Problem Solver:
  • 6 Answers
Sounds like the same problem I had, I googled that same issue and ended up buying a kit here http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits/osCsid/145ffde26a9336eaf57c21ff6389def7 that came with capacitors that had to be replace, the kit comes with a service manual and a bag with lots of different capacitors to replace any out on your board, they are really good at troubleshooting and they offer help online. If that is whats wrong with you, you will need a soldering tool, I bought my as a kit at radio shack for $20.00 and plus the $36.00 for the kit, and a lot of patience, my TV is well and running now, it was better than the $600.00 estimate I got from a local repair shop. Good luck!
Posted on Sep 09, 2008
Power light keeps blinking
try pressing the small reset button on the TV the light should blink rapidly for about a minute and then stop if it does not stop you will need to have the TV repaired
Nov 04, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My wd-52525 dlp tv has a flashing green timer light(rapid).. TV does not start even after reset, unplug ect. This started after powerloss in house. HELP??? ANYONE>
Replace the capacitors on the power board. You get the V26 DLP DM repaor kit at the following link which has the capacitors plus detailed instructions on CD.
http://www.tvrepairworld.com/
Jul 25, 2009 | Televison & Video
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Static picture or flashing colors pictures wd-52525
HEY AWOOD,THIS SYMPTOM IS DUE TO POWER CAPACITORS GOING BAD IN THE POWER SUPPLY AND THESE CAPS CAN CAUSE A COUPLE DIFFERENT SYMPTOMS,YOURS SEEMS TO BE THE MOST COMMON.IF YOU'RE TECHY ENOUGH YOU CAN REMOVE THE BACK AND GET ACCESS TO THE TWO PLUGS ON THE LITE ENGINE TO TEST (WITH A VOLTMETER) THE 5 VOLT SUPPLY ON I BELIEVE PLUG J19 PINS 1 AND 3.IF LOW THEN REPLACE 6 CAPACITORS ON POWER BD. YOU SHOULD BE ABLE TO SEE IF THEY ARE BAD JUST BY A VISUAL INSPECTION.GOOD LUCK JOE TV
Sep 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
