Question about Dishwashers
Dishwasher problems Hi - I'm back. I loosened the clamp and water started to spill out.
  • dknapp1 Sep 05, 2008
    Brigadier General:
  • 6,966 Answers
Water spill indicates drain reaches that point. the next would be the drain pump assembly. loosen the clamp after the pump to the hose and check for presence of water. You may need to also check for loose/disconnected sensors/switches/triggers/wiring in the area.
Posted on Sep 05, 2008
HOW TO CHANGE OUTLET HOSE ON SAMSUNG DISHWASHER
It's a fairly big job. You have to pull the dishwasher out from under the cabinet. Then remove the left-hand metal panel. You should now be looking at the case-brake assembly. Reach inside the dishwahsher and turn the water-inlet bezel counter-clockwise to remove it. Now you can tilt out the case-brake assembly and loosen the clamp that holds the drain hose in place. Pull the hose off (have a towel or Sham-Wow ready to catch the water). Then you have to remove the clamp or hose-restraint at the back of the dishwasher. Thaen you can pull the drain hose out and replace it.
Aug 02, 2014 | Samsung DMB28AFW Dishwasher
We are having water leak from the bottom of our Roper Dishwasher door. THe model # is RUD5750DG3. I have taken the inside door frame off and found a small white rubber seal had dislodged inside. i...
Step 1:
Remove the service panel that runs along the front of the dishwasher just below the door. If it is screwed in place, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to remove it from the hooks.
Step 2:
Check the end of the drain hose that connects to the dishwasher. If it's leaking, tighten the clamp with a screwdriver.
Step 3:
Check the drain hose connection to the kitchen sink drain. Again, if it's leaking, tighten the clamp with a screwdriver.
Step 4:
221_a1.jpg Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
Leveling the machine Step 1:
Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
Step 2:
Open the door completely and remove the bottom dish rack.
Step 3:
Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
Step 4:
Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
Step 5:
Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
Step 6:
Reattach the dishwasher to the countertop and reinstall the front access panel.
Fixing a leaking door Step 1:
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
Step 2:
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Step 3:
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Step 4:
Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
Step 5:
Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Apr 06, 2008 | Dishwashers
Water does not drain,how do I access the pump
Hi jolanda03,
Remove the Top Panel, fastened by 2 screws at the back, Then remove the right Side Panel, you should see the Drain Pump attached to the sump. To test it, you could attach direct power to the two pins on it (Alternating current, so position of connectors unimportant). If it works, it could be either that it is not receiving power from the PC Board, or the sump is clogged inside (Filter).
Hope this helps, if it did please rate with 4 thumbs up. A testimonial would be nice too. :-)
Apr 21, 2011 | Dishwashers
Water wont drain
You use your dishwasher so often with no problems that any issue can seem like a major disaster. But you can fix a drainage problem with a trip to the hardware or plumbing supply store and a few minutes of effort. If your dishwasher doesn't drain properly, the drain hose is probably kinked or damaged, interfering with the flow of water out of the dishwasher. You can fix the problem by replacing the drain hose yourself.
Difficulty: Moderately Easy Instructions And 4 Tools (Material) Needed To Solve The Drain Problem.
  • Shallow dish,Pliers or screwdriver,Replacement drain hose,Replacement hose clamps
  1. Turn off the water supply to the dishwasher. Turn off the dishwasher's power supply by unplugging it (under the sink) or turning off the appropriate circuit breaker.
  2. Pull the dishwasher all the way out from the cabinet so you can access the drain hose and pump near the back.
  3. Locate the drain pump and hose. The drain hose is the larger of the two hoses attached to the dishwasher and is generally located close to the bottom back of the dishwasher.
  4. Place a shallow dish under the drain pump. Loosen the clamp on the drain hose close to the drain pump, using pliers or a screwdriver. Pull the drain hose off of the pump, allowing any water to drip into the dish below.
  5. Remove the other end of the drain hose from the garbage disposal or drain by loosening the hose clamp and pulling the hose off of the connection.
  6. Attach the replacement hose to the drain pump and the drain or garbage disposal. Attach new hose clamps, and tighten them to hold them in place.
  7. Turn the power and water back on, and run the dishwasher through a cycle to make sure that the dishwasher drains properly and the hose doesn't leak. Tighten the hose clamps if you find any leaks.
Good luck and thanks for using fixya.
Jan 30, 2011 | Kenmore Dishwashers
Water not draining
There are several components to check when your dishwasher refuses to drain water. You need to check your drain hose, your pump assembly, timer, motor and drain valve and/or solenoid.
Most of the time it is the drain hose that is responsible for such problem. To check the drain hose, please follow the steps below:
  1. Disconnect the power source to your dishwasher before you conduct this or any other check. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
  2. Before you can check your dishwasher's drain hose for a blockage, you have to gain access to the hose. First remove the lower kickplate panel located below the door. This panel can be removed by removing a couple of screws that are located either above or below the panel. On some models, the dishwasher door has to be open to access and remove the screws, but then closed in order to remove the panel.
  3. With the panel removed, locate the drain hose. It is connected to the pump located below the lower spray arm. The drain hose runs from the pump to the sink drain, or to the air gap on top of the sink. There is a second hose leading from the pump that is a recirculation hose. When you are checking the drain hose for a blockage, you should check the recirculation hose as well.
  4. Place a shallow pan below the hose to catch any spills. Disconnect the drain hose form the pump by pinching the wire clamp with pliers and then sliding the clamp up the hose. Remove the hose from the pump assembly and wiggle the hose in various locations. This may help to loosen the blocked debris.
  5. Try running water through the hose to loosen and unblock the debris. A garden hose at full pressure is efficient to use for this task. Now disconnect the recirculation hose and check it for blockage in the same manner.
  6. Once you have successfully removed any and all blockages from either or both hoses, reconnect each hose to the dishwasher. Replace the clamps, and replace the lower panel. Reconnect the dishwasher's power supply and run the dishwasher to make sure it is running properly.
To replace the hose, please follow the steps below:
  1. Disconnect the power source to your dishwasher before you conduct this or any other repair. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
  2. Before you can replace your dishwasher's drain hose, you have to gain access to the hose. First remove the lower kickplate panel located below the door. This panel can be removed by removing a couple of screws that are located either above or below the panel. On some models, the dishwasher door has to be open to access and remove the screws, but then closed in order to remove the panel.
  4. Place a shallow pan below the hose to catch any spills. Disconnect the drain hose form the pump by pinching the wire clamp with pliers and then sliding the clamp up the hose. Remove the hose from the pump.
  5. Reconnect on end of a new hose to the dishwasher's pump assembly and the other end of the new hose to the sink drain.
  6. Replace the clamps, and replace the lower panel. Reconnect the dishwasher's power supply and run the dishwasher to make sure it is functioning properly.
That should do the job for you. And if that does not do it, then it means the problem is from other components of the dishwasher.
Hope this information helped.
Jan 15, 2011 | Dishwashers
Today, dishwasher started overfilling, and spilling water onto the floor. We turned off the water supply and let the dishwasher finish its cycle, turned on the water, started another cycle and it began to...
Hi
Thanks for using FixYa. If the dishwasher is overfilling it’s caused because of water-inlet valve going bad. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. If the water-inlet valve is defective, you need to completely replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Whirlpool 24 in. DU920PW Built-In...
Water wants to drain and keeps trying
Sounds like anti flood system has triggered (polystireen float and micro switch) that puts the washer in pump out mode only and shuts the inlet water off. You need to look at the bottom of the washer and check that water leak / spill is not causing the float to activate. Clear the water and fix leak (pipe or pipe clamp) and this should fix the problem.
May 18, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Whirlpool dihwasher adp 4552. Water comes into dishwasher, appears to start cycle then water is drained out again and light flashes to show a problem!
This is a typical anti flood activation due to the anti flood device (polystireen float and micro switch) at the base of the washer detecting a water leak / spill. This device puts the washer in pump out mode. Check to see if water at the base is causing the polystireene float to activate the switch. Dry the water and rectify the fault (normally a leaky pipe or pipe clamp) and this should solve the problem.
Mar 25, 2010 | Dishwashers
The dishwasher won't start. The cancel/drain will
This seems to be the "anti flood" device at the base of the washer is triggered due to water at the base of the washer. This safety device consists of a polystireene float and a micro switch that detects water leaks/spills and automatically puts the washer in pump out mode. You need to find the leak (hose or clamp)dry the base and rectifythe leak it before the washer works.
Mar 22, 2010 | Dishwashers
HOTPOINT 3400 DOES NOT DRAIN totally
Hi Bob,
Yeah! I'm a Texan! Cool!
I'd almost bet that your dishwasher drain line is NOT clogged but simply installed incorrectly. If I'm right, some water from the sink will drain (siphon) back to your dishwasher making you believe that it's not draining properly. (BTW, I've had a thousand service calls run for just this problem, so I know of what I speak)
Look under your sink and take a gander at your dishwasher drain line... if it looks like this, it ain't right.
This allows sink/disposal water to siphon off to your DW. All you gotta do is loosen the clamp (in the pic), remove the drain line, pull as much slack as you can (without pulling to hard... like it'll break if you do that) and put a loop in it like this...
OK... after you get your loop, you'll need to tighten your hose clamp. As an extra measure of security (to keep the loop in place), secure the drain hose to your sinks water supply line.
There ya go! 15 minutes, no parts, no head-aches and you're done! Cool, huh? All you gotta do now is kick back and wait for the Cowboys pre-season! (BTW... if your drain is installed properly, write back and we'll go a little deeper into a diagnosis, OK?)
SG
May 17, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Dishwashers Logo
43 people viewed this question
Top Dishwashers Experts
