Question about Samsung Digimax A402 Digital Camera
Camera Ready and Flash
Camera turns on fine but then green light flashes and camera takes LITERALLY 1 minutes PLUS to be ready to take pictures even in broad daylight. And then a long time between photos to be ready again AND now no matter the mode I'm in, the flash won't fire at all.
Batteries are new and I keep changing them with no change in above issues, I haven't changed anything since I last used camera in may'08, no warnings coming up on screen, nothing....
Help. Thanks
  • shadyady Sep 26, 2008
    I have had same problem. and have been changing bateries for three months, still no difference. pleas help
    Scholar:
  • 97 Answers
I'f your using alkaline AAs, try using rechargeable NiMH batteries or lithium disposables. Alkalines are very poor at supplying the kind of current needed to recharge the flash. I've found other Samsung cameras to be particularly fussy about batteries, and not always consistently so! Good luck.
Posted on Sep 05, 2008
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Minolta Maxxum 3200i Flash does work
Try to short out the flash and see if the flash flashes.
Remove flash from camera.
New or fresh bateries installed.
Get wire with insulation and remove both end bare to 1/4"
Turn on flash and wait until light turn green or ready.
Touch one lead to center of flash pin, touch other end to the outside(rail on the side) pin.
Flash should discharges.
atdlee@netzero.com
Jul 28, 2008 | Cameras
Ready light on my SB-800 speedlight
put in a fresh set of batteries. The ready light won't turn on until the flash capacitor is fully charged. And if your battery is weak, it can take very long (minutes!) to fill the capacitor. You still can fire the flash even it is not ready, it will just dump whatever power it stored in the capacitor.
Jun 12, 2008 | Nikon Speedlight SB-800 TTL Flash
Flash won't power up
Try it with a NEW fully charged battery
Nov 17, 2007 | Pentax Optio S5i Digital Camera
Won't take picture
If the lightning bolt continues flashing and never stops there is a failure in the flash sub-system. Try selecting the no-flash setting, if the camera fires normally at this point then your problem is definitely in the flash system. It is hard to say what the failure is beyond that. The problem is the camera will not take the picture until the flash is charged and ready to fire - the flashing lightning bolt indicates that it is charging the flash. The fact that it just keeps flashing indicates that the flash is never becoming ready. This repair could cost $68 to $125 plus parts to fix, although an evaluation would be necessary to identify the problem.
Jun 05, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M60 Digital Camera
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries. Please refer to the section pertaining to Battery Life.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Samsung Digimax A402 Digital Camera Logo
90 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
