Question about Belkin Computers & Internet
I am adding a new deskstop to my house, so a friend gave me his belkin router. i have been trying to set it up, but the problem is i have qwest choice internet and my modem is in my cable box in my master bedroom and a ethernet cable to wall which allows my office desktop to work with another ethernet cable to wall in office... how do i get all my computers working off of router????
  • Coss May 11, 2010
    How many network (LAN) ports on the router?
  • 97 Answers
Wat u do is to just Connect ur Telephone wire to modem as usual and the output of modem has to be given to WAN port of ur router. your router must have atleast 2,3 LAN ports, take output from those ports and connect it to ur both desktop pc's...
Posted on Sep 05, 2008
Can i setup the belkin f7d4302 as a wireless bridge
belkin does not support this. The only way you can do it is by running a cable to the router to extend your wireless signal around the house. I did a similar setup with a powerline network adapter if running a cat5 cable is not a option. just make sure you change the main ip address for the 2nd router to like 192.168.2.2 and disable dhcp since the main router will handle dhcp. also make sure the wireless settings are the same and channel is different if 1st router is channel 1 then use channel 6 or 11 for the 2nd router.
Feb 26, 2012 | Belkin Wireless Play Router (F7D4302)
I have a PK5000Z from Qwest, and an XBOX360, I had an issue previously with a PK5000 made by Actiontec, with NAT issues, set to moderate, it doesnt let me hear all players in a xbox live party chat, or in...
try turnig off all restrictions related. like , S.P.I. (statefull packet inspection) and try setting firewall setting for the address of the Xbox to "DMZ" . check setting of M.T.U. in router, adjust it to 1580
Good luck.
Sep 27, 2010 | Computers & Internet
I need the software for my F5D7230-4 BELKIN
Are you trying to set up router ?
You can set up your router manually, without the
CD.
Make sure that your computer is able to go online
directly through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for more information about the routers
and network
Feb 16, 2010 | Belkin (F5D7230-4) Router (587009)
My router won't work with my Qwest modem.
Are you trying to set up the router.
You can do it manually without the CD.
When you connect the computer to the quest modem, does it work?
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 07, 2010 | D-Link Computers & Internet
Belkin DI-604 router connection problem
Change the router's IP address to 192.168.10.1, The Qwest modem like Action Tech have the same IP address with the router.
To change the router's IP address you might needing to access the configuration page of the router, then proceed to the LAN settings.
Mar 24, 2009 | Belkin (F5D5231-4) Router
I cant communicate with belkin wireless g router
It sounds like you don't have the units connected properly. Make sure you have a cable(wired) from your ethernet card on your pc connected to a wired port on the router. Then plug your router from its yellow port into the modem. Make sure your modem is connected to its Internet interface. Plug in your modem and wait 60 seconds for it to power up. Then power up the router.
At this point you should be able to access the router with the supplied installation CD. Run the setup assistant and it will define your wireless network. When you are through you should have internet access through the wired network. When you are finished you should be able to use the wireless network assuming you have the card installed correctly and the software for the card correctly installed.
Jul 09, 2008 | Belkin (F5D7230-4) Router (587009)
Wireless will not get to the internet
driver for ur wireless card is working?
on the router software the ap module is on? set on ad-hoc? or ap mode.
Apr 07, 2008 | NetGear MR814 Wireless Router
Computers & Internet Logo
53 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
