Question about Jenn-Air JBL2086HES Bottom Freezer Refrigerator
Can't get the fridge to work
It starts off by making a strange noise. Like a long hum and a click. As if the compressor is attempting to come on but can't. It will do this for a couple of days then it will no longer cool or freeze. The fan is working, but blowing hot air.
  • 4 Answers
      if this solution pertains then u gotto check ur compressors...as it is de heart of a fridge...do service them....ur prob ll b solved
Posted on Sep 05, 2008
What does it mean when the rv fridge makes a humming type of noise?
humming can mean a few things like --its working normal ---compressor trying to start --its running and compressor internal damage
Aug 02, 2016 | Refrigerators
Why would a brand new fridge make strange noises already?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFSS2614QS, is making a strange humming noise. Your new, high-efficiency refrigerator may introduce unfamiliar sounds. These sounds normally indicate your refrigerator is operating correctly. Some surfaces on floors, walls, and kitchen cabinets may make these sounds more noticeable. This could possibly be the compressor that you are hearing. Modern, high-efficiency compressors run much faster than in the past. The compressor may have a high-pitched hum or pulsating sound. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire FFSS2614QS FFSS2614QS 26 Cu....
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
AEG OKO Santo not sure how old There is a hum
The hum on the motor can be faulty compressor motor or a weak capacitor that makes the motor to move slowly.But If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off. If not the auto defrost timer, or the thermostat must be checked.
The ventilation fan that circulates the COLD air from the evaporator coils could get clogged with frost and so could be jammed. Also the wires to the fan can be worn out due to the frost. If so check if the defrost timer works to switch the heater to remove the frost. Also the check if the compressor is shut down by the timer /thermostat . If the heaters are not working, check continuity of the heaters.
So attempt to test using a multi-meter / clamp tester from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Thank you for using Fixya.
Sep 03, 2011 | Refrigerators
Why does the compressor not work
If the compressor is not working at all , you will first of all check the power at your mains, Trace down wards from the main wire to the main relay unit. When the fridge is switched does it makes a chatter/ click , hear any hum on the motor before it goes still? If so you will need to check on the compressor motor. Use a clamp tester to check if the load current is exceeding and hence tripping off. If so the compressor unit will need a change. If there is no click at all then the relay can be faulty, this is a trip off/ relay and the contacts get bad over a period of time. The capacitor can also be faulty so that the motor will not start but make a humming noise. Hope you check this out and find out. Good day.
Jul 27, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Makes a clicking noise and humming when starts up
If your unit is fixed with a high speed compressor and in case you are not using a votage stablizer when ever there is a fluctuation in voltage there could be a click noise from the compressor. Do not frequently open your fridge and slowly the noise will vanish. It tells you that the unit is functioning just like our heart making thud thum thud noise when it functions and nothing to be worried about. It is normal.
Jul 06, 2009 | Refrigerators
My Kenmore side-by-side refridgerator is making a loud humming noise. My Kenmore side by side refrigerator/freezer has been making a buzzing noise every few minutes. Now I realize that the freezer is no...
You need to clean your coils under the 'fridge,' and wait 24 hours, if it is not not getting cold, perhaps replace the freon. If that does not work, you need to call a repairman.
May 26, 2009 | Kenmore 57029 Side by Side Refrigerator
Our refrigerator/freezer will stop working (not cool or freeze) then days later will begin to work again.
i find it hard to believe the compressor is going out,if the fridge is staying cold,put a thermometor in the fridge and it should stay about 32 degrees,ideally around 40 is a good temp.if the freezer isnt staying below 32 degrees then it sure sounds like a thermostat problem.But i have heard of computers in these newer refridgerators but havent worked on any just yet.
May 09, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Whirlpool side by side, clicking noise, strange smell from bottom
The clicking is from your compressor relay on the side of the compressor it has eather went bad or a condenser fan motor is not running this will cause the walls to be warm if the fan is running in the back try cleaning the coils hope this helps
Mar 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jenn-Air JBL2086HES Bottom Freezer Refrigerator Logo
144 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
