Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
FDB949GFB2 Frigidare Dishwasher
It washes but does not dry. Where is the thermostat and what part number do I order? The manuel that came with the DW was a joke. Is there one available thjat shows the parts and their location?
    President:
  • 1,462 Answers
Don't know this appliance but as a guide:
take top off and dryer manifold goes across the top of the machine. there are various stats mounted on the manifold. one or more may be resettable stats ie have a litle button in the middle. press the button to reset. if you have access to a multimeter, check continuity thro the stats as wee and check continuity thro the heater itself
Posted on Sep 05, 2008
Dishwasher lights show "washing, drying, clean" like normal, but when it's finished I open it to find that the DW Detergent Pack never dissolved.
Make sure water is at least 120 degrees F.
As a test run water from the kitchen faucet closest to the dishwasher until it is a hot as it will get, put some in a cup then you can then check the temperature with a thermometer. OR you can just run the dishwasher to see if that helps.
Oct 20, 2015 | Whirlpool WDF750SAYM Gold Series...
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
Just replaced the control panel on a Frigidaire DW #PLD4375RFCO. Had the dreaded "ER" flashing problem. All was working well ....about 15min into the wash and now "HO" flashes, and...
Probably the thermostat. Remove the kick panel and look toward the back you will see a circular piece with 2 wires attached on the top. Turn off the power to the dishwasher, unscrew the thermostat and order a new one.
May 21, 2011 | Dishwashers
Rough film on dishes
first clean dw use tang then prime sink and run dw after that cut back on detergant
Jun 06, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
Water will not drain from dishwasher. Fridgidaire mode FDB949GFB2. I have checked the lie going into the sink garbage disposal and it is clear. I have cleaned all screens.
Draining problem is very common in Bosch washers. However, it is very easy to fix.
1) Remove the white circular plate, located on the bottom left. Push a small screwdriver or needle through it and simultaneously rotate the plate clockwise.
2) Open the drain valve. Rotate the circular black handle counterclockwise. Beware of residual water.
3) Clean it. Re-assemble in reverse order.
Thanks for contacting fixya.com
Nov 23, 2009 | Frigidaire ATF6000ES Front Load Washer
It does not heat up or dry the dishes
Depending on the make of your DW, the Heating element inside the bottom of your DW might be at fault.
Your may have a fuse that connects to the heating element that may have blown- relace fuse.
Check the heating element to make sure it is functional.
go to Appliancepartspros.com and enter your model number and find schematics of your DW to see where these things are on your DW
or if you have bosch dischwasher read this:
http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes
Nov 01, 2009 | Dishwashers
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Frigidaire FDB635RBB heat wash/heat rinse
Most DW today take a minimum of 90 minutes. Run the hot water from the sink until it gets hot, then start the DW, this will shorted the first wash cycle. It is not uncommon for the DW to run 2hrs or more based upon the water temperature entering the DW and the soil level of the items in the DW.
May 29, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
97 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
