Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Instructions for descaling Saeco Royal Digital
No instruction manual with unit. Says to descale. How does one do it???
  • stmax Sep 06, 2008
    Have since downloaded the manual from "The Coffee Shrine". Thanks.
The instructions say clearly in quite a few places never to use vinigar... actually you need to buy a descaling solution, they have them with any coffee maker accessories. there are instruction in the manual for "descaling" follow those.
Posted on Oct 28, 2008
    Brigadier General:
  • 5,158 Answers
I used to run vinigar and water thru my coffee maker to remove the **** vinigar is slightly acidic. make sure run just straight water thru it afterward to get rid of the taste.
Robert
Posted on Sep 05, 2008
If descale not function, how can I do?
Try reading the user manual. You can find it at: http://www.cerinicoffee.com/saeco-user-manuals-28/ or there is a video on how to do it at: https://www.youtube.com/watch?v=k6iGAQ5C8hs
May 05, 2015 | Saeco Royal Digital Espresso & Coffee...
Where do I get the solution and filter from
You can find most parts and the descaling solution at http://www.saecoparts.com/
You can also find descaling solution on amazon, just search for saeco royal descaling solution.
Apr 11, 2015 | Saeco Royal Professional Espresso Machine
I have a Saeco Royal Digital Plus and have just descaled it and am wondering how do I cancel the message stating to decalcify my unit?
. Go back into your menu and scroll up or down 1 to "Signal Descale" and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Nov 04, 2010 | Saeco Royal Digital Plus Coffee...
Keep getting "decalcify" message
Go to MENU and scroll down and find SIGNAL DESCALING. Select ENTER the machine will ask RESET , YES or NO. Select YES and ENTER.
Jul 12, 2010 | Saeco Royal Cappuccino Espresso Machine
How to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Jun 13, 2010 | Saeco Royal Digital Plus Coffee...
Saeko royal says decalcify but manualonly has
Hi
Do a descale again only use the proper descaler and you should be good. Watch what you use to make sure that it is done correctly.
Feb 14, 2010 | Saeco Royal Professional Espresso Machine
Looking for instructions on cleaning and servicing the Saeco Royal
When you clean the brewing unit wash it with hot water, do not
use any solvent.
Make sure there are no coffee residues on the two steel filters: the upper filter can be removed by unloosening and turning the plastic pin anticlockwise using the tool supplied.
Dry thoroughly each central unit component, fit the filter again and tighten it properly with the screw .
To do a descaling:
Saeco descaler is recommended; however, you can use any non-toxic and/or non-harmful descaling product for coffee machines, commonly available in retail stores. The used solution is to be disposed of according to the manufacturer’s
instructions and/or regulations in force in the country of use.
Never use vinegar!
Best regards
/Mirran
Nov 26, 2008 | Saeco Royal Digital Plus Coffee...
After descaling the Saeco Royal Professional, all features remain functional except for the coffee dispensing. It will grind and the brew unit will go through its usual cycle, but no coffee will get...
The first descaling cycle likey dislodged some calcium which then found its way into a valve or water line. A second descaling cycle resolved the problem.
Oct 06, 2008 | Saeco Royal Professional Espresso Machine
Decalcify?
I had the same problem with a Saeco Royal Digital. I ran the decalcifying liquid through the machine with the automatic descaling program as per the instructions on the bottle and the DECALCIFY message stayed up.
I solved it by going to the menu and selecting "Signal Descal." and toggling it from No to Yes. I escaped back to the menu and git the usual "Select Product".
Hope this helps.
Nov 05, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
697 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
