Question about Asko 1375 Dishwasher
ASKO 1605 Fills, Drains, Heats well, but has stopped washing.
  • douglas smith May 11, 2010
    can you hear the main pump going??
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Posted on Jan 04, 2011
I have an Asko D-3122 dishwasner. When it is started on a normal wash cycle it drains, fills, heats the water if necessary and then stops. It does not go into the wash cycle. I assume the circulation...
If there is no sound of the circulation motor then it is faulty. But if the circulation pump sound is coming but water is not circulating then you need to check the wash arms for blockage.
Refer this diagram for location of parts in wash system
http://spares.bigwarehouse.com.au/images/files/19975_6146c636e8211a1ecc4ecdc062082148.pdf
Apr 12, 2014 | Asko Dishwashers
My ASKO W6342 washing machine drum will not turn on any setting, it fills and drains fine but the drum does not turn during the cycle, however it is free to turn by hand, the belt from the motor is OK, I...
It seems a minor problem for me, but cannot say anything without checking your washing machine. You should better call washing machine repairer to fix this minor problem.
Mar 14, 2014 | Asko Washing Machines
Dead circulation pump capacitor: I have an Asko
Capacitor should have a uF and voltage rating stamped on it. They are NOT a one-size-fits-all.
Always keep your Owners Manuals so you can use it to get parts. Without seeing it myself, the part will probably have to be replaced.
Sometimes you can find the manufacturer online and get parts through their website.
Possibly find this capacitor at an AC shop.
Oct 29, 2013 | Dishwashers
Asko w600 front load washer did not spin water out of clothes. I emptied the drain pump and now it fills with water but doesnt wash the clothes. The water drains out but nothing else. Help
Check to see if your model has a "out of balance" micro switch.
If it's tripped from you moving the unit around you may have to reset it manually. It will be mounted somewhere close to the outer perimeter of the tub. Can't say exactly where. Could be high or low.
Jul 11, 2012 | Asko W600
The Frigidaire pld2855 fills and drains but no water to the spray arms, it also heats very well, any ideas
it sounds like you have a problem with your spray pump it could be clogged up or it may have seized you will have to take it off and have a look at it
Dec 08, 2011 | Frigidaire Dishwashers
Asko 10505 will not spin the belt is not broken, tub fills and drains
Your washer unit is needing a new timer and replacement is needed if the part is available.
This will require some electrical experience to replace the timer unit or go to your local Sears repair and they will come out and repair your unit for a fee.
Jan 29, 2010 | Asko Washing Machines
Our Asko D3250 dishwasher is brand new, and it fills up and drains and fills again and then the water inlet fault flashes. It doesn't go past this point.
this sounds like a improper install ! ck to see if the drain hose outlet is lower than bottm of tank. it should drain to the disposal . and have a drain loop under sink .. the dw prosser is sensing that the drain is longer in time so it flasher inlet fault . . elevate the drain and try again ..if it drains to a lower use a stand pipe or a siphon brake . in the install .. mm
Dec 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Washing machine fills with water when not in use.
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
Feb 22, 2009 | Asko Washing Machines
Asko 1375 Dishwasher Logo
534 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
