Question about Panasonic PanaFax UF-8000 Laser Fax
J 72 When trying to make a copy thru the ADF, nothings happen but we get a J 72 error
    Sergeant:
  • 284 Answers
There is a small plastic sensor that dangles in the ADF, sometimes it gets push up and if it does it will give you this error. either you or a tech need to take it appart to fix the problem
Posted on Sep 10, 2008
    Genius:
  • 2,120 Answers
I don't have my manuals today, but I think there's a jam in the ADF (just pull it straight up to open)
Posted on Sep 05, 2008
Support code 2700
From Canon:
2700 Description
This error occurred due to one of the following reasons -
  • An error occurred while copying.
  • The document is still in the ADF.
  • An error occurred while scanning and the document is still in the ADF.
Resolution
  1. When copying, press the [OK] button to dismiss the error, and try to copy again.
  2. If the document is still in the ADF, press the [OK] button to feed out the document.
  3. When scanning, press the [Stop] button to cancel, and then try scanning again.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Feb 15, 2015 | Canon PIXMA MX340 Wireless Office...
Can faulty ink cartridges prevent the printer from copying or scanning?
When you power up the printer it should go thru POST and your scanner should go thru the motions. You can lift the ADF lid and see if the light goes on while it goes thru POST. Also try resetting the printer to factory default.
May 30, 2014 | HEWLETT-PACKARD Officejet 4500 All-in-One...
Error message with canon mx410 "cannot scan from adf"
I fixed this by changing the Copy Intensity from Auto to Manual
I had the same paper jam (caused by pressing Stop during a page going into the ADF), but I had pressed OK as instructed and the page was auto fed back out again. Then I couldnt copy from ADF after that.
I tried everything, and then started to retrace my steps of all the things I might have tinkered with to try and get the copying working in the first place, before the paper jam.
Then I remembered I had set the Copy Intensity from Manual to Auto (thinking Auto is always best). With hindsight, it now makes sense for it to be manual with the ADF as otherwise how would it load a page, use it to set auto density, and then reload it again for the actual copy to occur. This happens okay on the flatbed scanner as it can scan a little, work out the settings, and then scan for real.
Copy Intensity is reached on my Canon MX from the Menu button at the bottom left of the front panel. - Then press the right arrow twice to get to Color Intensity. - Hit OK. - Then right arrow from "Auto" to "Manual Adjust"- Then pick a setting or leave it as half-way between light and dark- Press OK
Now every time my ADF copying works a treat. Thats what I get for tinkering in things I didn't need to change in the first place. I was just trying to get a quick copy going from ADF to paper without saving a file up on the computer and then printing.
Aug 09, 2012 | Canon Pixma MX410 All-In-One Printer
My HP J6480 ADF is making a grinding noise when I try and fax or copy documents fed thru the ADF. I have tried cleaning the rollers but that hasn't worked. Any other suggestions?
You need to locate, from where sound is coming from.
Then use wd40 or silicone grease oil, and lubricate.
its probably dirt on axis bushings.
Jul 05, 2010 | HP Office Equipment & Supplies
Brother 8820d MFC auto doc feeder does not work...
You need a new hinge so the cover will sit down properly, or paper will jam anyway, but it sounds like there is still a scrap of paper on one of the sensors inside the ADF, you need to look with a flashlight down thru where the paper goes and also look up thru the slot with the ADF lifted.
Sep 11, 2009 | Brother MFC 8820D All-In-One Laser Printer
Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
The Automatic Document Feeder (ADF) is not working.
Mark,
A little help here, what machine are we talking about. Do you here any thing moving?
Richard Eklund
ITWorkz
512-589-6410
Mar 05, 2009 | Xerox WorkCentre M15i Laser Printer
How can I set up the ADF to copy on dell printer 3115?
It would help to know what kind of machine this is. But check to make sure the cable from the ADF is plugged into the back of the copier. If it is not. Turn off the machine, unplug it from the wall, then plug the ADF into the machine. After that is complete plug the machine back in and power up.
Jan 27, 2009 | Office Equipment & Supplies
Line in copies that go thru feeder
Over time the automatic document feeder (ADF) will get dirty, occasionally causing vertical black streaks or lines in scans and copies .
Manual cleaning of the ADF might be necessary. Follow the procedure below to manually clean the ADF .
You will need the following materials:
  • Soft lint-free cloths
  • Glass cleaner
if you look carefully on the left side of ADF ( top feeder ) there is an assembly which u can lift , there wud be a set of rollers if u lift that part there would be a glass strip . u are suppose to clean that strip .
While holding up the inside of the ADF, clean the glass in the location of the vertical streak with one of the cotton swabs. Try cleaning the glass first with a dry cotton swab. If that does not correct the problem, then moisten the swab with glass cleaner .
If the vertical lines or streaks still appear, go through the above cleaning process again, this time cleaning the entire surface of the ADF scanner glass.
and after this try the following steps as well .
CAUTION: Use only glass cleaner. Avoid abrasives, acetone, benzene, and carbon tetrachloride, all of which can damage the scanner glass.
Apr 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
ADF Paper Feed on Ricoh Aficio 1013
1-clean rubber belts with lint free clothes immersed in pure alkohl
2-remove adf covers and confirm that nothing broken inside(gears-belts)3-every clutch and selonid are in good condition.
4-solonid lever engaged firmly to gear slevee 5-apply light grease to gears and slevee6-confirm that nothing object the actuation of adf microswitches no dust and dirt in optical switches.
Mar 05, 2008 | Office Equipment & Supplies
Panasonic PanaFax UF-8000 Laser Fax Logo
109 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
