Canon MultiPASS F60 All-In-One InkJet Printer Logo
Anonymous Posted on Sep 05, 2008
Canon Multi pass F60
I have to keep cleaning or deep cleaning to get the black ink to print properly or else it is blotchy and prints poorly. If I keep using it it seems ok but if it sits for awhile maybe half an hr to one hr I will have to clean it again. The color works fine. What do you think?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 11, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
75
Points
I flipped up the leve on the right and removed the print head assembly and cleaned it real good and now it works perfect.
Printer not printing very faint
Clean or deep clean the black printhead. Go to 'printer properties' then 'maintenance' and click the appropriate button.
Selphy DS700: False paper jam message and poor print quality
1.Sir Please have a vacuum cleaner with you and clean the area where the paper is being pulled in thus the sensor will be clear 2.if your problem isnt yet resolved please post your Windows here i will assisst you further
Hi, I am having a problem with my relatively new canon ip100. Since I installed new cartridge for black ink, when I run the test of nozzle it shows that black print head needs cleaning: missing parts lines...
Welcome to FixYa!
Here are my suggestions:
Confirm that the Ink Tank is installed properly.
If the ink tanks are not loaked into place, the will not be supplied to the print head.
Remove tape from the
The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
Confirm there is no orange tape across the top of the ink tank.
Try to use other Black Ink Cartridge. The cartridge might be defective.
I hope this helps.
Thank you for using FixYa.
Keep me posted.
Jas247
1helpful
Black won't print. Changed all ink cartridges,
It may need a new purge assembly, if it doesn't clean both sides properly either color or black will quit. You might try a new printhead first, QY6-0064-000 around $40.00
I have a canon multi pass f80 printer. it is several years old (10?) i love it and have had NO problems. last night i went to print and my black ink has a new cartridge and there is no ink coming out...i...
First you need to ensure that this is not a driver problem, by reinstalling drivers and testing the printer on a different computer.
Also ensure that ink cartridges are OK, try replacement inks.
If the problem is not a software problem, and the printer is recognised by computer, and the printout is coming as a blank or faded page, then you usually have a faulty or clogged printhead.
Try first performing print head cleaning procedure from printer tools, that may not fix the problem, but do the cleaning a couple of times, just in case.
If the print head is clogged, that can be fixed soaking the print head in isopropyl alcohol overnight.
If still no luck, then the printhead must be replaced, here is the part: Canon MULTI-PASS F-80 Print Head $61.00
1helpful
5answers
Canon iP90 stopped printing in BLACK
hi... it might be that you need some time to let the ink absorb into the pads in the print heads ... this can take between a few hours and a day... Must be frustrating to deep clean three times and just seem that you are wasting ink cartridges, my "solution" would be to give it time or possibly clean the print heads manually.. hope it will solve it out..
thank u!!
Poor print quality
First Perform deep print head cleaning if this fails and the print results are same then you may need to replace the print head on the printer .......
Good luck...
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Poor black in colour prints
Dwonload 'Ink Saver' install it and adjust the ink flow.
old marine
old marine
ZJ Limited
ZJ Limited
