Question about Sony KP-53V90 53" Rear Projection Television
HAVE 3 PICTURES,1 IN BLUE, 1 IN GREEN, 1 IN RED.
HELLO ALL,
I HAVE SONY KP-53V90, THE TV HAS 3 PICS ONE IN BLUE,ONE IN GREEN,ONE IN RED.HOW CAN I FIX THIS PROBLEM,
TRIED FOCUS FUNCTION IN THE MENU SCREEN WAITED FOR IT
TO FINISH.AFTER DONE STILL DID NOT FIX THE PROBLEM.PLEASE
SUGGEST ANY REPAIR PROCEDURES. THANK YOU FOR THE HELP
AND YOUR TIME. GOOD DAY
  • Sony Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions yoHAVE 3 PICTURES,1 IN BLUE, 1 IN GREEN, 1 IN RED. - 2c07611.pngnce chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
578ba6c.jpgTV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 28, 2009
    Problem Solver:
  • 9 Answers
In the menu functions, try and reset all settings to factory. Have you moved this set recently? if you have you may have jarred the 3 projector lenses loose, in which case you need a repair visit.
Posted on Sep 05, 2008
HOW DO YOU FIND IT AND THINK THE REMOT IS NOT THE PROPER ONE FOR THE TV IT DOES WORK BUT LIMITED
Convergence is the alignment of the red, green and blue lines to produce a white line when doing a convergence setup. You need the correct remote to do that. Support for KP 53V90 Sony
May 24, 2016 | Sanyo Televison & Video
1. picture is getting darker 2. there is a green outline when the brightness is turned up
Hello ksolovy, i understood your Problem with the Sony KP-53V90 53 in. Rear Projection Television,In fact i encountered already that kind of problem you have it now. Check first the color wheel im sure that the blue section of your color wheel was burned and the blue color turn to dark; That's why you have seen dark picture, Re-place color wheel.
Dec 21, 2010 | Sony KP-53V90 53" Rear Projection...
Sony kp-53v90 no picture but has sound and display lettering
The tv have a problem known as a convergence problems,it dead.The tv convergence board require changing 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 05, 2010 | Sony KP-53V90 53" Rear Projection...
Three pictures red green & blue and it looks concave
Install the Sony type 1 convergence repair kit available from www.tvrepairworld.com the kit includes the components and the cd with instructions.
Jun 30, 2010 | Sony KP-51HW40 51" Rear Projection...
I have a Sony KP-53V90 53 with no display and red light flashing
This is a good one. Your TV "looks" at the feedback coming from each picture tube in your TV. When it doesn't see what it expects, it kicks out a 5 flash. Most commonly, the correct signals never got to the picture tube(s) and that's why the feedback was abnormal. Which brings us to the most common solution: C boards, they attach directly to the bottom of the picture tubes. Figuring out which one has a problem... that's another matter. Due to the age of the TV, parts costs are rising. Each C board (3 in the TV) runs about $100 so guess work can be expensive. I hope this was helpful.
Mar 28, 2010 | Sony KP-53V90 53" Rear Projection...
Sony kp51hw40 has green shadows and on edges in pictures and blue flickers on and off, tried all adjustments including screen, focus, and menu??? no luck
The CRTs in this model of TV had a problem with internal leakage. The blue was usually the first to show the symptom (flicker). Because all 3 CRTs are connected to the same high voltage source, when 1 acts up, the other 2 suffer as well. You need to replace the Blue CRT. However, this TV has some age on it... 1 tube will lead to 2 tubes, and 2 tubes to 3... They only last about 7 years. If you love the TV, replace all 3 (about $200 each). I recommend replacing the Red and Blue first, adjusting the geometry and convergence to the original Green. Then replace the Green, adjusting the geometry and convergence to the new Blue and Red.
Mar 15, 2010 | Sony KP-51HW40 51" Rear Projection...
Color yokes for KP-53XBR45
1-451-441-11 for the Red and Green tubes
1-451-441-21 for the Blue
Dec 19, 2008 | Sony KP-61V90 61" Rear Projection...
Sony model # kp53v90 rear projection tv
HI THERE,I HAVE 3 PICS. 1 IN BLUE,1 IN GREEN, 1 IN RED,I
USED THE FOUCUS FUNCTION IN THE MENU, BUT THAT DID NOT FIX THE PROBLEM.ANY SUGGESTION. THNX ALL.
Mar 15, 2008 | Sony KP-53V90 53" Rear Projection...
Sony KP-53V90 53" Rear Projection Television Logo
304 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
