Question about Protron PLTV-32 Television
Does the power supply you purchased from LCD Payless still working?
I am thinking about getting one from them and a few guys on this site had problems with it after 2-3 weeks is your power supply still working?
  • securityguys Oct 29, 2008
    pltv 32 tv i have same problem cant get the guy in calf that can fix the power supply does any one know how to contact this guy im adding a cooling fan to my tv this should take care of heat problem
    Problem Solver:
  • 5 Answers
I tried to purchase one for the $142.00 and it was not in stock. I think contaced the person someone recommended on this website. This was his answer:
It seems a lot of people are having problems with the Protron power supply. I’ve been able to repair all the ones I’ve seen so I’m confident I can fix them. I don’t sell the replacement power supply but I’ve heard about the ones on EBay. They seem to be a mishmash of two power supplies (12vdc and 24vdc) wired together with the proper connector. This should work but it just doesn’t sound very clean looking to me and they end up costing $150.
I’ve been charging between $50 and $100 to repair these power supplies. My recommendation would be to send me the power supply I’ll check it out and unless it’s unusually damaged it will cost $50 plus shipping to repair. If I can’t repair it I’ll return ship it and only charge for shipping.
I will guarantee the repair for 1 month. I don’t know what’s causing the power supplies to fail so I can’t guarantee it any longer than that. My feeling about the reason the Protron power supply stops working is two part; could be overheating due to lack of proper ventilation to the power supply; or the TVs power requirement is overdriving the power supply.
Feel free to contact me if you have any questions.
I repair these at my work, so here’s the shipping address:
Dave Simpson
23372 South Pointe Dr.
Ste. B
Laguna Hills, CA 92653
Also, I’m set up for PayPal.
dave@thola.com
Posted on Sep 12, 2008
LG42LC7D
LG LCD TV SOLUTIONS
Sep 04, 2012 | LG 42LC2D 42 in. LCD HDTV
Sony bravia works on ups/battery not mains :(
Sure sounds like the power supply board received an insult that allowed a different voltage to work for a while . UPS will regulate top 120 volt whereas mains may be higher or lower . You may be able to change bad capacitors or just buy the power board between 80 to 200 dollars .
If it was connected to UPS during surge it should have been protected...make sure you are connected to 'battery' side as a lot of UPS have a 'surge only' side that will not stop a rapid on/off power insult .
Hugh
Mar 02, 2017 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
I HAVE A 32" VIZIO LCD I PURCHASED 2 YEARS AGO.
You should buy a sodering kit and remove the buldging capacitors yourself. Find a local electronics store, I used Radioshack, and see if they can match the capacitors. I had this happen with my Samsung lcd about a year ago and just help another friend with the same issue yesterday. The sodering is not as hard as you'd think. The capacitors should be under $5 v. paying a few hundred for the power board.
Mar 21, 2011 | Vizio VOJ320F1A 32 in. LCD TV
Need power supply for a lcd sceptre x7g
try www.newegg.com or google search for it, sry thats the best i can think of!
Dec 11, 2009 | Sceptre 17" LCD Monitor
Xerox screen fails to power up.
Hi guys I've got XA7-19i 900p and I had the same problem But I've got it repaired myself. This is common issue and problem is in the power supply unit. I have changed 6 capacitors 470uF 25v and 1 capacitor 220uF 25v. It will definitely help! Try to google it you will find instruction how to do it.
Aug 27, 2009 | Xerox XA7-192i 19" LCD Monitor
The monitor has a white screen when its turned on. nothing happened when its connected to a computer. What do you think the problem is?
You may have a problem with the power supply board. On many LCD monitors after a few years the power supplies start failing. The problem is parts called capacitors start failing. They get damaged because of the heat trapped in the small spaces of the monitor case. You can take a look at a few pictures on our site at: www.ccl-la.com/badcaps.htm We also have a section with dis-assembly and repair instructions. Check it out, if you have more questions just email me. If you don't want to do the repair yourself we offer a repair service.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years pf PC and printer support/repair.
Jul 29, 2009 | Dell E176FP 17" LCD Monitor
Protron pltv-32 ac adapter
I also sent my power supply to Dave in California.
dave@thola.com
Service and turnaround was incredible. I sent it to him, he e-mailed when he received, the e-mailed a day later that it was fixed and on its way back to me. Very reliable and reasonable. This all happened in April 2009.
Dave- thanks so much
Oct 16, 2007 | Protron PLTV-32 Television
From 300w psu i change it to 450w will that be ok?
Ivy My field is in home appliances. I do fix my own computers and have replaced a few power supplys. The only thing I could say to you is go back and recheck your connections. They should only fit on the bord one way. The other connections for the hard drive and cd drives and so on really dont matter. so good luck and I think if you recheck it all the computer will work.
Jul 11, 2007 | Jackson 25 in. TempStar HH Free-standing...
Protron PLTV-32
I found a power supply for this TV on Ebay but it is about $150.00 and is not guaranteed for more than a month.I found it after I sent for one that did not work with the TV.If I do try the right spec unit...12V 3Amp with light and fan and it works, I will try to get back to inform you all....CDM
Aug 07, 2006 | Protron PLTV-32 Television
Protron PLTV-32 Television Logo
93 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
