Question about HP OfficeJet 4215 All-In-One InkJet Printer
Hp 4215 all in one
I an send fax but i can't recieve it
  • 72 Answers
Go to Menu and than go to Fax setup. from there Go to Error correction mode and make sure it is off.
Try this and reply.
Regards,
Lalit
Posted on Sep 09, 2008
  • 40 Answers
May i know if you do have an answering machine that is connected on the line??is your line is just a regular phone line??
send me feedback for more troubleshooting instruction...
Posted on Sep 05, 2008
I can receive fax but cannot send fax on my HP 4215 xi
Check telephone out going, add std code, check FAX facility in your telephone connection
Aug 09, 2011 | HP OfficeJet 4215 All-In-One InkJet...
I have Vonage phone line. I cannot fax to anyone on my HP 4215 officejet. My officjet is connected to the wall jack and set to "slow" settings as advised in one of the HP solution forum. that did...
Press the setup button on teh front panel and go to fax set up
Under fax setup look for
ECM - Error correction mode
By default its ON turn it off and try to send the fax
But let me thing clear the telephone line which you have has definitely some disturbence
Apr 16, 2011 | HP OfficeJet 4215 All-In-One InkJet...
Hp officejet 4215 all-in-one does not send or recieve faxes. What to do ?
Try this web link ;---
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01667035&cc=us&lc=en&dlc=en
Good luck!!
Apr 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
HP officejet 4215 to print instead of fax
if you are using windows then go to control panel and go to printers(windows vista) or printers and faxes (windows xp) and then select the correct printer icon out of the two icons.. there will be two icons (for eg . officejet 4215 and officejet 4215 fax.. ) choose the one which doesnt says fax .
Oct 20, 2009 | HP OfficeJet 4215 All-In-One InkJet...
How do I recieve faxes?
make sure you are plugged into an analog phone line (not a multiline phone). second I would put a phone on that line and have someone call it to see if it rings through. Let me know what happens
Jun 22, 2009 | HP OfficeJet 4215 All-In-One InkJet...
HP OfficeJet 4215 can not send fax
Check for dial tone at the fax machine
Plug in a telephone on the cable from the wall.
Do you get a dial tone?
Yes,
Something is wrong with the fax machine.
No,
Call the phone company or a telephone repairman.
May 27, 2009 | HP OfficeJet 4215 All-In-One InkJet...
I can send faxes, but cannot receive faxes.
Thank you for specifing your connection>
When you have a shared fax line it is import to have a Distinctive Ring Pattern which will differenciate the type of ring patter to recieve voice calls and Fax message.
All You need to do is get a distinctive ring pattern from your telephone service provider (AT&T) and setup your fax machine as per the ring pattern provided by your service provider.
All you need to do is set your rings to answer in youe phone to Rings 4 in your Phone.
Then in the All-In-One Go to menu / Setup> Press the right arrow key and locate basic fax setup> Press Ok and set the Ring Pattern to Number 5 or 6> Press Ok and cancell to come to the main menu
Then in the All-In-One Go to menu / Setup> Press the right arrow key and locate Advance Fax Setup> Locate Distinctive ring pattern and set it to the ring pattern which your Telephone service provider has alloted i.e Single Ring, Double Ring or or Triple Ring (Whichever is applicable)> Nd press Ok and cancell to come to the main menu.
Then you will be able to receive fax message voice cals and voicemail without any interuption.
Good Luck
Sep 25, 2008 | HP OfficeJet 4215 All-In-One InkJet...
How to fax
You would need to connect a phone line from the appropriate port on the all-in-one to an open phone jack in order to make faxing work. If that's a problem, you can use the scan feature and send docs by email as a workaround. If you want to get incoming fax service, though, you will need the phone line connected to the unit.
Aug 14, 2007 | HP OfficeJet 4215 All-In-One InkJet...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
47 people viewed this question
Ben Johnson
