Question about Polaroid PhotoMax PDC 640 Digital Camera
I don't see anything in the color LCD.
My camera is powered on, but I don't see anything in the color LCD. What's wrong?
    Master:
  • 450 Answers
If the color LCD is not illuminated when the camera power is turned on, check the following: * The camera may be in the wrong mode. Run this check to test the LCD: 1. Make sure the camera power is on (the lens cover should be open). 2. Press the Review button (top left) on the back of the camera. The LCD will display the last photo taken. To exit the Play mode, turn the camera power off. * The camera may be connected to a TV. Disconnect the camera from the TV and try the LCD again. * The batteries may be weak. Replace the batteries or use the AC adapter. To save battery power, use the optical viewfinder when composing photos.
Posted on Sep 21, 2005
Image problems on my lcd tv
The internal power output maybe need replacement.If you have outage power loss the IPU receive to much voltage when the power restore and become faulty
Jul 16, 2013 | Televison & Video
The LCD Display is distorted on my Power Shot A310 Camera. I can only see ghosts and colored lines. Can you tell me what might be wrong.
HI,
The fault is with the CCD display.You'll have to get this repaired and that's the only solution.
If you need anymore help let me know..
Jun 02, 2008 | Cameras
THE LCD OF MY GE CAMERA IS COLOR VIOLET.. I DON'T KNOW HOW IT HAPPENS.. IS THERE ANYTHING WRONG? i think it is in the battery..
If you dropped it, you could have dislarged one of the cables or color processor going to screen. Very expensive to repair if you can send it out. The battery should not cause that because it gives the right voltage (camera on) or the wrong voltage (camera can't turn on). Did water or STEAM get into the camera.? water can do it.
Sep 01, 2011 | GE X500 Digital Camera
The camera was plugged into the wrong charger and now it won't do anything. is there any way to fix it? it is a Kodak M893is.
Now it looks like you have a problem here. Different cameras/chargers have different polarities. If you try to charge with wrong chargers then there is a possibility of the batteries getting damaged or sometimes may even explode, so be very careful in future. Some times the power control board can also get damaged and may require repairs. At this juncture you can try hoping for the best to replace the batteries. On many occasions this has solved the problem.
Regards.
PLZ. don't forget to rate my solution.
Jul 14, 2011 | Kodak Easyshare 1725043 M893Is Digital...
Wrong background color
Right click anywhere on your desktop.Make sure all programs are closed.Select properties,then select desktop.From here you can change it to anything you like.
Apr 11, 2010 | Acer AL2216W LCD Monitor
Color wrong and red spots
Sounds like CCD sensor problem . It starts with 'noisy' pictures ( colors not true and resolution deteriorates )but eventually the sensor stops outputting anything and you end up with blank screen. Have the sensor replaced and camera will work fine.
Sep 11, 2007 | Fuji FinePix 2800 Zoom Digital Camera
LCD
The connection between the LCD and the circuit board is loose or partially broken. You will see this symptom more and more frequently as time goes on and eventually the LCD will fail completely. No reason to do anything yet, but eventually you may have to get it repaired. David Millier Advance Camera Repair
Feb 03, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Blurness of the LCD of my Canon A80 Camera
This is a defective CCD known to Canon. They will repair it FREE of charge. Go here for more detail: http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8044&keycode=2112&id=29819
Dec 04, 2006 | Canon PowerShot A80 Digital Camera
My camera's LCD screen goes black every so often. What is wrong?
No. All Lumix® Digital Cameras have a built-in feature to conserve battery power. After a certain amount of inactivity, the LCD will power down to preserve the battery. Simply hit the SHTR button, and the LCD will turn ON.
Aug 30, 2005 | Panasonic Lumix DMC-FX7 Digital Camera
Aug 30, 2005 | Panasonic Lumix DMC-F1S / DMC-F1K Digital...
Polaroid PhotoMax PDC 640 Digital Camera Logo
125 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
