Question about Refrigerators
Dial goes from 1 to 5 in fridge, what is correct setting
    President:
  • 1,462 Answers
1 is warmest and 5 is coldest. set to 3 and just see if that gives you a reasonable temperature. fridge temp should be about +4degC and freezer temp about -18degC
Posted on Sep 05, 2008
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
I have an Amana BX21VW refrigerator and both the freezer and refrigerator stopped cooling. The fan is still going and there is power, but no cooling of any kind. What is going on?
Hi!!
Check
Temp. control knobs,
Most likely, the evaporator coil is covered w/ice, obstructin the air flow thru it and to the fridge side of the unit.
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure all ice is melted andthe air duct going to the fridge is clear.
Once this is done, restart unit and set temp. 1/3 of the dial, ie. if the dial goes from 0-9, set it on 3. wait 24 hrs to make adjustments
Keep me posted!! Rate this post!!!
Aug 12, 2010 | Amana Refrigerators
My fridge keeps freezing how do i change the temp settings
Hi!!
You didn't mentioned brand and model of your fridge, so I will give you a general answer.
Usually the controls are in the fridge compartment, either on the right or back upper wall. Usually is one control for the freezer and another for the fridge. The normal settings should be about 1/3 of the dial's range, ie. If dial have 9 numbers, the setting should be between 3 and 4, depending on use and outside temp.
Wait 24 hrs. between adjustments to allow the system to stabilize.
.NOTE:
The Freezer Temp. Dial is the main temp. controller, if you set it too low, it may not have time to cool fridge side properly.
Good Luck!! Don't forget to rate this post!!!
Aug 03, 2010 | Refrigerators
Defy Fridge temperature dial is confusing - which way is colder?
0 = off, 1 = cool, 2 = cooler, ..... 7 = coldest.  0 - 7 Nothing to do with the degree the fridge is set to.
Jan 07, 2009 | Refrigerators
Temperature Setting Dial in Fridge
Hi. thanks for the question. # 9 is the high, 1 is low. and it will run for 24 hrs to get on track .thanks the appliance doc
Oct 05, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Gorenje KE267MLA Fridge too warm
higher the number, colder the fridge ie 7 is the coldest setting
switch with red dot is for summer/winter operation. only necessary to switch it on if the appliance is in a cold location
Sep 30, 2008 | Gorenje Refrigerators
I don't know how to set the temperature setting on my Hotpoint RLAV21 fridge. The dial goes from 0 to 4. For fridges I have had in the past the higher the number the colder the fridge but I've got my...
You should have 2 dials one is the thermostat when you set it all the way one direction it will shut you refrigerator off. Turn it back to about the middle if there are no numbers. The other dial is the air damper between the freezer and the refrigerator. The fan circulates the air through refrigerator by this damper. If you open this open to much your food in the refrigeration section will freeze. Close it back to about 2 that will give you a colder freezer and should be about right for the refrigeration section.
May 17, 2008 | Hotpoint Refrigerators
Refrigerators Logo
376 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
