HP6310 officejet printer , a communication error occurs when an incomming fax transmission is in progress.Error22 shows up
  • 48 Answers
Turn off ECM and v34 in the fax settings of the unit...
try to plug it direct to the wall phone outlet too...
if you have DSL on the same line, make sure that you have a filter on this printer's fax line...
Posted on Sep 05, 2008
What's error 345 with HPOfficejet j5780 all in one while faxing?
error 345 while faxing is related to Communication error. This error is not related to printer hardware issue.
Below are the possibilities ....
  1. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted.
  2. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted.
  3. The remote user pressed the Stop key while the reception was in progress.
    The suggested solution would be as follows....
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
Jun 02, 2014 | HP Officejet Pro L7680 All-In-One Printer
When I first got my HP Officejet Pro 8500A I had no problem faxing. Now I get an error 350 code. Why? How can I fix this problem
HP's description of this error code is as follows
Definitions
  • The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote user pressed the Stop key while the reception was in progress.
  • Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved. Click here for instructions on enabling and disabling ECM (c00060802) (in English).
Sep 01, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
In trying to fax, we get Error 344
Definitions
Solutions
Aug 02, 2011 | HP Officejet 6500 Wireless All-in-One...
Error 351
The reason for this error code is :
•The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
•The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
•The remote user pressed the Stop key while the reception was in progress.
•Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions what you can try :
•Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
•Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved. Try sending at a lower transmission speed
For more details you can check this link out :
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=buu02549&lang=en&cc=us&taskId=101&contentType=SupportFAQ&prodSeriesId=351105&prodTypeId=18972#Error344
Nov 07, 2010 | HP Officejet Pro L7680 All-In-One Printer
I am getting an error code 344 when trying to fax from my hp officejet 4500. It is brand new so the current drivers have been loaded. I did a fax test and it came back with all things passed. WHen i...
Solutions
Oct 27, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
What is the meaning of eror 232*
Error Code: 232
  • A communication failure occurred between the two machines.
  • The user at the remote machine might have pressed the Stop key.
  • The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line. Do not use call waiting on a line with a fax machine.
  • The power at the remote machine was interrupted, or deliberately turned off causing the fax session to be interrupted.
Solutions
  • If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Click here for instructions on enabling and disabling ECM .
  • Set the host machine to receive at a slower transmission speed.
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems.
Nov 04, 2009 | HP OfficeJet J4580 All-In-One Laser...
"Call Blocked" appears in the 6310 display on incoming calls...
"Call blocked" refers to the phone system caller ID name; this has nothing to do with the Fax function of the HP6310. Some callers block their name from showing up on your phone's call ID display.
Aug 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Error 345 a communication error occured when ending a Fax .what is this and why does it happen?
I changed the fax resolution from "fine" to "standard" using the button on the keyboard.
After this, the page who was not faxable have been transmitted without problem.
Paolo
Mar 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printer error
error message 345
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power related problems.
OR
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
*Re-attempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
*Disable ECM. Errors may still occur, and may result in a degraded image quality on the received page. However, the ability to transmit the entire document will be improved.
*Try sending at a lower transmission speed.
Dec 05, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP officejet 7210 fax error
HP Officejet 7210 All-In-One InkJet Printer
Error code: 405
When I send a fax I have a dial tone and the fax feeds through, I hear the other end answer it says it is sending and then I get the printed page that says: "A communication error occurred during the fax transmission."
Oct 29, 2007 | HP Officejet 7210 All-In-One InkJet...
193 people viewed this question
jasbo
jasbo
