Question about Samsung CLP 300 Laser Printer
CLP 300 toner cartridges don't have a chip
My toner cartridges (new with the new printer) do not have any chips in the spaces provided on each cartridge. How does the printer know the status of the toner and how do I tell the printer that the toner is now full again without the chip? I don't want to have to buy the chip when it obviously didn't need them in the beginning. I refilled the toner myself and it works fine otherwise but keeps telling me the toner is low.
I also don't want the printer stopping because it thinks the toner is completely empty.
TIA for any help.
Kim
  • Kimaboo Sep 10, 2008
    Maybe my question was not clear enough. I knew a reset chip would do the job, but I want to know how to reset the "counter" in the machine itself. That way a chip would never be needed. All it would take is a connection to the chip contact where the cartridge goes and the right code to send.
    Kim
New Models of Samsung Laser printers come pre-packed with Cartridges that have no chips but an empty space where the chip should be. These chipless cartridges do not need to have a chip because the printer is pre-programmed to run for one cycle. These pre-packed cartridges can also be refilled in the same way but will need a reset chip.
Buy new chips from:
http://www.clp300.com/index.php?main_page=product_info&products_id=133
Posted on Sep 10, 2008
Scx 3200 samsung status light
If you refiil the toner cartridge ,now must be change the cartridge chip.The chip countered the total copy,not how many time you refill the toner.The original chip working 1500 copies,change one new chip to 1,5K or 3 k or moreK(K=1000 copies).
Mar 26, 2013 | Samsung CLP 300 Laser Printer
AFTER RELOADING TONER INTO CARTRIDGES, THEN RED LIGHT BLINKING AND IT WILL NOT PRINT. WHAT CAN I DO TO FIX THE PROBLEM?
Did you change the chips in the cartridges after you filled them with toner? Inside the cartridges are chips that the printer keep track of the number of images that are printed. After so many pages, the printer marks the cartridge as empty, even if you fill it with toner. When the cartridge is changed the printer reads the serial number on the cartridge and keeps a log it its memory. If the chip is replaced, then the printer does not recognize it and thinks it is a new cartridge.
Hope this helps.
Apr 30, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP-315 eats toner. Cartridges last almost
ean_inkrefills on ebay. Search on the terms "samsung clp 315 toner refill solution". Chip installs on the printer motherboard--installation is not overly difficult, but still not for the faint-hearted. I expect it voids the printer warranty. Ean gives good email support.
Aug 02, 2009 | Samsung CLP 315 Laser Printer
CLP 300 toner cartridges invalid toner
the drum has chips encoded,need cartridges with chips.
May 29, 2009 | Samsung CLP 300 Laser Printer
Refill clp-315
No need to drill holes. If you turn the cartridge with the drum facing away from you, on the left hand side, you should see a small block elliptical cover with a couple of divider on it. That is the cover for filling the cartridge. The problem is there is no available reset chip yet for clp-315.
Feb 21, 2009 | Samsung CLP 315 Laser Printer
CLP-300
The only way to reset it it to buy oem cartridges because it only lets you use the starter tanks once, after that they must have chips
Feb 24, 2008 | Samsung CLP 300 Laser Printer
Toner and Imaging Unit issues
If this IS a CLP-510, first make an information confirmation print.
Press MENU, then press ENTER, and ENTER again.
Look at the counter for the imaging unit, is it a low count confirming that you have indeed replaced it ?
If not you will need to reset the counter.
Check the counters for the toner cartridges, and check the capacity of the cartridge. On a CLP-510 the image counter for the toner is held on the chip on the cartridge (which also identifies the capacity of the cartridge).
There have been some faulty (oiginal Samsung chips), and of course re-manufactured cartridge chips could fail (many re-manufacturers don' test their cartridges before dispatch, they don't have the facility to do so without starting the count on the chip (or 'bowing' the reset fuse on a CLP-500 cartridge). VERY few re-manufacturers can test these cartridges without starting the count.
Sometimes the 'replace xxxxx toner' messages are caused by toner on the three contacts on the side of the cartridge, or their mating contacts inside the printer. Rarely, this can be caused by a faulty circuit board.
Dec 20, 2007 | Samsung CLP-510 Laser Printer
Compatable toner problems
try to swap the chip on the toner cartridge with the original toner cartridge
Nov 10, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
394 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
