Question about AOpen AX4SG-UN Motherboard
Cpu overheating CPU temp is running around 31 deg C with case open and external fan blowing on it. With case closed it started climbing up to 37 before I reopened the case. Do I need to replace only the cpu and fan, or should I replace whole motherboard? I've been trying to find a board to buy but no one seems to have one. Have they stopped making them or what? Can I use another board instead? Karen
  • karriola Sep 05, 2008
    I will buy a new fan and give that a try first.
    President:
  • 1,263 Answers
I would purchase a external fan to keep the unit cool. if your computer is functioning and the only issue is that it's over heating, you could hardwire another fan unit. this way the fan is always running and that should keep the temp down. if your having a hard time finding a board chances are they are obselete and your out of luck, however you can check around your local repair shops and you just might get lucky... please rate this
Posted on Sep 05, 2008
  • Ronald Mueller
    Ronald Mueller Sep 05, 2008
    if you can try and hard wire a fan unit inside the case as well this will only help the situation.
    Brigadier General:
  • 6,966 Answers
Three possibilities:
  • the HSF (heatsink/fan combo) is no longer sufficiently cooling the CPU, probably dusty, clogged, the fan lubrication dried up. Remove, clean lubricate;
  • thermal runaway of the CPU (unlikely but still is a possibility);
  • temp sensor faulty. Could possibly resolve with a BIOS update/flash.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Sep 05, 2008
    Should you still be interested with a replacement motherboard, pls try here (it's a store in the Philippines).
  • 89 Answers
First of all make sure that your motherboard is not overclocked. you can try to use a stronger fan and if the temperature still goes up then it only means that there is something wrong with your processor and you need to replace it.
  • 6,487 Answers
You can just simply btry to add another fan or get a bigger fan to make the system much cooler to avoid overheating, I think they already stop making this MOBO that's why its hard to find this any store even online...
Hope that helps.........
    Genius:
  • 1,268 Answers
You can try to use another fan with high cooling capability. Also you can adjust the CPU temp on the BIOS setup.
Fan speed zx6800
It depends on which fan you are talking about (CPU or Case) It would also depend on the heatsink you have fitted and the CPU that is fitted. The speed is about right for a CPU fan though. If your computer stops on it's own after a short while you may have an overheating problem. To check the CPU temp is in the correct range try CPU world website for the spec for your particular model.
Jan 12, 2013 | Gateway ZX6800-01 (PW.G8802.004) 23 in. PC...
Hi, My three year old DV8396EA is overheating within minutes of boot; the rather noisy fan starting almost immediately. Core Temp meter, which previously gave readings of about 50 to 60 degs, now reads...
You are receiving temperatures that would be considered dangerously high for the internal components of your laptop. What i would suggest doing is opening up your laptop, if you are comfortable doing so, and inspecting the heatsinks, fans, along the chassis of the laptop, under the keyboard, and anywhere that there may be dust. Clean off all the dust with a good spay with a can of compressed air and try again. If your temps are still that high I would suggest redoing the thermal paste under the heatsinks in your laptop. Not having a good application at the factory can cause issues later on down the line. I use artic silver for my thermal paste. All you have to do is follow all the instructions that come with the paste and it should be alright. If you do not see your temps go down after that, I would suggest taking your laptop in for service as there could be a potential of damaging your internal components.
Aug 19, 2011 | HEWLETT-PACKARD Pavilion DV8396EA Laptop...
I turn on the computer and it may run some times for about 10 or 15 min. and then shut down i was wondering if i need a bio's update or what i have two hard drives in the computer xp pro on 1 and vista...
It could be overheating. After it shuts down, restart it, and enter BIOS SETUP, and look for a "PC Health" or "Status" entry on the menu. If you're lucky, it will report the current CPU temperature, and the speed of the fans, and the settable temperature at which it will shut itself down.
Check the capacitors on the motherboard -- any capacitor with a "dome" on top, instead of perfectly-flat, is a leaking capacitor that is intermittently failing.
Jul 19, 2011 | Mach Speed (MSNV-939) Motherboard
The Dell Dimension 9200 has up to now worked fine but now seems to freeze qand the fan starts to blow at full speed. The only solution is to switch off the system by pushing on the on/off button for a...
Your CPU may be overheating. Open the case, vacuum all the dust and
inspect all fans: Power Supply, CPU, Chipset, Graphic Card etc...
If all are operational then maybe the CPU heatsink compound (grease)
has dried up over times, and need a fresh new replacement.
Download a copy of Real Temp 3.60 and run it continously to monitor
the CPU temperature in real time.
http://www.techpowerup.com/downloads/1872/Real_Temp_3.60.html
Jul 16, 2011 | Dell Dimension 9200 PC Desktop
Acer aspire 4720z overheating problem. had this problem for a while about a year ago and then it stopped. now it has started again. currently i am running a core temp monitor i watch the temp go up hear...
The CPU Cooler does not seem to be doing its job properly. I would suggest you use a laptop Cooling Pad. It is a tray for your laptop and has a number of cooling fans to keep your laptop well circulated.
Nov 17, 2009 | Acer Aspire 4720 Notebook
Boots up but only runs for about a minute. Then fan runs at full speed constantly with no video. Also front panel popwer switch appears shorted. i.e as soon as you plug in the PC starts
Very well could be overheating or powersupply problem. Most Definately Hardware related. You can try opening up the case and blowing air into it from compressor. (Make sure to do this outside away from clean items). Also, check CPU fan and heatsink to make sure fairly clean. CPU fan may also be old and need to be replaced. Don't put case back on and try again. Look at CPU fan to see if moving (or struggling). If computer stays on longer then CPU fan most likely the problem. If off in same time as before then most likely the main power supply problem, in which case the only way to check this is to replace the power supply. Hope this helps, Best Regards,
Nov 09, 2009 | Acer Aspire T310 PC Desktop
Random shut down
Yes.... over heating can and will cause a system shutdown..
Download and install speedfan ( http://www.almico.com/sfdownload.php ) It will most likely tell you how hot things are really getting......
Depending on what cpu you have, you may have a thermal paste problem, you may need to remove the heatsink and re-apply heatsink thermal paste to the bottom of the heatsink and reseat ontop of the cpu. This will void any warranty if you PC still has any left.
Jan 07, 2009 | EliteGroup GeForce 6100SM-M Motherboard
System temperature too high
Do you still have your manual? If not download it from Gigabyte at this link:http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=2637
Enter your bios & open manual to page 51, "PC Health Status". Here you can monitor the CPU temp, system temp & CPU fan speed. Notice the manual shows the example of system temp to be 30degs C & current CPU Temperature is at 47degs C. One would think these temps are reasonable. My CPU fan runs between 3308Rpm & 3341Rpm. CPU @ 41deg C & MB @ 31deg C. AMD 64 X2 Dual Core 4200+ 2.21 GHz.
Suggest you try this. If your running Win XP. Open system properties. Click the Advanced tab. Click the settings button under
Startup and Recovery. Remove the check mark to the left of, Automatically restart. Windows should provide an error message if & when the system freezes. This will help in finding what is causing the system to freeze. If your CPU fan is running under 3000Rpm you might consider buying a faster fan or add a case fan to the side of the case to help bring in fresh air to blow onto the CPU fan & PCI-Express card. Here is a decent lace to look for case fans: http://www.xoxide.com/casefans.html
Keep me up to date andr_zero.
Mike
Dec 17, 2008 | Gigabyte GA-P35-DQ6 Motherboard
Motherboard problem
Chances are the CPU fan may be running too slow, dust & dirt build up under & over the fan blades can be a big factor. CPU fan could just be going. Are you over clocking the system. (IF so buy a better heatsink & fan for over clocking the system).
To check if CPU is getting too hot. Enter the bios & go to the title, "Power" page 2-28. Open Hardware monitor & check the CPU temp & mother board temp. (Make sure the case is closed in normal running conditions).
Link to Asus: http://support.asus.com/download/download.aspx?modelname=M2N-MX&SLanguage=en-us
Jul 02, 2008 | ASUS M2N-MX Motherboard
CPU fan not working
you need to check your power supply if this is okay you need to replace the cpu fan. the cause of shutting down is the overheating of your cpu
Jan 06, 2008 | Acer Veriton 5200D PC Desktop
AOpen AX4SG-UN Motherboard Logo
94 people viewed this question
Top AOpen Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
