Question about Texas Instruments TI-85 Calculator
Degrees, minutes, seconds converted to decimal degrees
I can convert decimal degrees (DD) to degrees, minutes, seconds(DMS) but am not able to convert DMS to DD. Help please.
  • WayneJM_20 Sep 13, 2008
    is there a DMS button? If the angle is 59.75 degrees is there a button that will convert that to 59 dgrees 45 minutes
  • Anonymous Mar 26, 2014
    convert decimal degrees to degrees, minutes and seconds
  • 35 Answers
No DMS button
1degree 22.25 minutes
2nd Math F3 1 F1 22 f3 15 f3 enter
Posted on Nov 25, 2008
How can i convert degrees,minutes and seconds to decimal degrees in a casio fx-82MS
Use the DMS key marked degree, apostrophe, double quotation mark.
Lets us call it [DMS]
To enter an angle in degree minutes seconds or hour, minutes, seconds, type in the number of degrees, press the [DMS] key, enter the number of seconds, press the [DMS] key, enter the number of seconds then the [DMS] key. Press = the calculator displays the value in DMS units. If you press the DMS key again the number displayed is converted to decimal degrees.
Example:enter 12 degrees, 15 minutes, and 25 seconds
12 [DMS]15[DMS]25[DMS] =
Calculator displays 12 deg 15'25"
Press the DMS key again and you see 12.2569444
Feb 19, 2013 | Casio FX-82MS Scientific Calculator
How do i enter 50deg,25minutes,23seconds into a casio fx-9750 plus
In Run>Mat press the OPTN key, Then F6:> to move to the next page of options. You will see the ANGL tab as on the screen capture (above F5 key.
Press F5. You will see what follows.
Type in 50, press the F4 key, 25 then F4, 23 then F4. Press EXE. you get the result in decimal degrees as on the screen capture. To convert from DMS to D.D, or from D.D to DMS, vice-versa, press the F5 key
Jan 05, 2013 | Casio FX-9750GPlus Calculator
Dd to dms conversion
Press the DMS button to convert between decimal degrees and degrees-minutes-seconds.
The DMS button is marked with the degree, minute, and second symbols. It's located above the [ENG] key, which is located above the [8] key.
For full details, start with the "Degree, Minute, Second (Sexagesimal) Calculations" section beginning on page E-22 of the manual. If you need a manual, you may download a copy here.
Jan 19, 2012 | Casio FX-115ES Scientific Calculator
How do you enter Degrees Minutes Seconds on acasio fx-9750 Calculator
To access the DMS function, turn calculator ON, go to the RUN screen. Press OPTN F6>, F5:ANGL You will see a csreen as on the capture.
To enter an ganle value in DMS, enter the degrees, press F1, enter the minutes, press F1, enter the seconds and press EXE. the value may be displayed in DD Decimal degrees. To conver press F4. To convert back press F5 (notice the backArrow on the TAB).
Oct 30, 2011 | Casio FX-9750GPlus Calculator
Can I convert Decimal Degrees to Degrees, Minutes, Seconds on my casio fx-991 ES?
Yes. Pressing the DMS key (two keys above the 8 key) when a result is displayed toggles the result between decimal degrees and degrees-minutes-seconds.
For example, to convert 3.5 degrees, press 3 . 5 = and you'll see 3.5. Now press DMS and you'll see 3 degrees 30 minutes 0 seconds.
Jul 31, 2011 | Casio FX-115ES Scientific Calculator
I know how to convert between decimal degress and degrees, minutes, seconds, but how do you enter degrees, minutes, and seconds directly?
Enter it as DD.MMSS and then press 2nd [DMS-DD] to convert it to decimal for further calculations.
For example, to enter 21 degrees 34 minutes 45 seconds, enter 21.3445 then press 2nd [DMS-DD].
May 12, 2011 | Texas Instruments TI-30XA Calculator
How do i enter 46degrees 15minutes into my ti-36x calculator?
Enter DMS (Degrees/Minutes/Seconds) values as D.MMSSs, using 0s as necessary:
  • D degrees (0-7 digits)
  • . decimal-point separator
  • MM minutes (must be 2 digits)
  • SS seconds (must be 2 digits)
  • s fractional part of a second
For example, enter
  • 46° 15' as 46.15.
  • 179° 9' 2.54" as 179.090254, note the 0s in front of the 9 and 2.
Before using a DMS value in a calculation, you must convert it to decimal with [2nd] [>DD].
Jan 13, 2011 | Texas Instruments TI-36 X Solar Calculator
How do I convert DMS to DD with a ti84 plus?
To enter an angle in DMS format, enter the number of degrees, 2ND [ANGLE] 1 to indicate degrees, enter the number of minutes, 2ND [ANGLE] 2 to indicate minutes, enter the number of seconds, ALPHA ["], then ENTER.
ANGLE is on the APPS key, " is on the + key.
You can convert an angle from decimal to DMS with the ->DMS command, 2ND [ANGLE] 4
Jan 10, 2011 | Office Equipment & Supplies
How do you put degrees mins & secs in a ti 84 plus
The DMS symbols are available under the ANGLE menu
Press [2nd][APPS] (ANGLE)
Under that menu you find the degree and minute symbol. To enter the seconds unit you use the key sequence [ALPHA][+] (")
To enter 1deg 15 minutes and 37 seconds
1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+]
To enter a number in decimal degrees (eg 15.37)
  1. If angle unit is the degree just enter 15.37
  2. If angle unit is the radian , you must specify the angle unit as degrees: To enter 15.37 degrees you type 15.37 [2nd][Apps][1: degree] [ENTER].
To convert from DMS to DD and from DD to DMS, you use the sequence [2nd][Apps][4:|=>DMS].
Feb 08, 2010 | Texas Instruments TI-84 Plus Calculator
How do I convert from decimal degrees to degrees, minutes, and seconds?
You have a key, the label of which is the degree sign, the apostrophe and the double quotation mark. It is located between the change sign key (-) and the [HYP] key.
To enter an angle with degrees, minutes and seconds you use the key to separate between numbers
Ex: 18 deg 0' 45" you press 18 [Deg ' "] 0 [Deg ' "]45 [Deg ' "] [=] As you type the calculator displays 18 deg 0 deg 45 deg but the result will show correctly. You have to press the key after the seconds figure, otherwise you get a syntax error.
While the foregoing result is still in answer memory, if you press the [Deg ' "] key the result will be displayed in decimal degrees.
The key is used to enter the DMS values and also to toggle between DMS and D.D.
Jan 21, 2010 | Casio FX-115ES Scientific Calculator
Texas Instruments TI-85 Calculator Logo
2,859 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
