Question about RCA HD52W59 HDTV Projection Television
Fl231 Hi - I have noticed in all of your posts you warn about the power for the people who are going to try this fix. Is that warning just so you dont get too close to the flyback? I assume I need to just pop that old fuse out and solder the new one in. I don't have to worry about getting fried just by doing that, do I? I will unplug from the wall. Thanks!
  • rivard9 Sep 06, 2008
    Thanks for that info. I went up to Radio Shack and showed them a picture of the fuse I found online and they said they didn't have any fuses that looked like that. Should I have asked for a resistor, or would it only be called a fuse? Also...do I have to remove the old solder, or can ~I! just take the one off and put the new one on?
    Thanks!
  • RCA Master
  • 8,617 Answers
You can get the replacement fuse FL231 which is a 400ma 125v micro fuse at the following link under the RCA parts category.
http://servicemanuals.vstore.ca/
Posted on Sep 06, 2008
    Genius:
  • 1,030 Answers
If you got a steady hand you fine. just try not to short anything. the flyback is not generating voltage unless running. the mains input board or the one with the plug in it and the main capacitor is the one that holds the charge. you should be ok i just warn everyone. and the charge usally goes away after about 30 min to hour. replacing that little square fuse next to flyback should be any trouble.
Posted on Sep 05, 2008
Why do I see a rear access open and a gate ajar warning on insument panel, even though it is locked?
[SOLVED] False Gate Ajar/Rear Access Open warnings: follow up post ...
forums.trailvoy.com > ... > 02-09 General Tech Q&A > General
Dec 28, 2009 - 4 posts - ‎2 authors
[SOLVED] False Gate Ajar/Rear Access Open warnings: follow up post General. ...2002 Chevy TrailBlazer LTZ ... In cold weather, I have a constant "gate ajar" warninguntil the ... Should I try to unhook/rehook the connections to the BCM? ... You might confirm it by starting the vehicle cold, see that you have ... Annoying tailgate ajar won't quit going off on 04 gmc ...
Feb 4, 2010
Rear latch assembly not functioning on Lift Gate
Oct 12, 2009
Gate Ajar - turning off
Jul 1, 2007
passenger door ajar
Nov 9, 2005
More results from forums.trailvoy.com
Rear access door ajar - false signal - Fixya
www.fixya.com/cars/t22610885-rear_access_door_ajar_false_signal
Feb 03, 2016 | 2002 Oldsmobile Bravada
Tip
Low Power Warning For Full Charged Camera Battieres
<span> <p>I have noticed that, some users asked that, there old cameras always display low power warning for full charged new batteries, or there will be a low power warning after only taking 5-6 pictures.<br /> <p>If you have met this question (I wish not), I'd like to share the solutions.<br /> <p><span> <p>The this problem are so common for <a href="http://www.digital-camera-batteries.net/canon.htm">Canon PowerShot</a> A series cameras when you try to powered your camera by Ni-MH batteries. This is because that, the camera judge the battery is power off by voltage of the battery. And if you use Ni-MH batteries for your camera, the Ni-MH batteries' voltage is lower than the Li-ion ones and close to the camera's judge voltage of low power, so the camera will warn you to change a new battery.<br /> <p>So if you use <a href="http://www.digital-camera-batteries.net">Li-ion camera batteries</a> this questions will be solved simply.<br /> <p>From <a href="http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/">http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/</a><br /></span><br /></span>
on Apr 26, 2011 | Cameras
Why does the Engine Warning light come up but other warning lights like battery, oil pressure etc.don't show up in ignition mode & the car doesn't start?
Sounds like a wire was not re-installed under the hood. When the alternator or battery were replaced, there are several power wires under the hood that attach to the same power terminal. Look for a RED wire with a large round connector, that is just hanging out in the open air. You need to install it back onto the post that it came off of. good luck.
May 07, 2014 | 2010 Chevrolet Spark 1.2
I have a 2003 Ford Explorer. Recently I noticed thsat a warning light "Service Engine Soon" illuminated on my dash and wont go away. I've never seen this before and Ive owned the car since 2003. What'
Hi Dennis
The light is warning you that there is a problem with the Engine management system, I cannot and no one else online can tell you what the problem is. But I can advise you to take your car to a workshop and have it scan, the technician will tell you.
Good luck
Apr 07, 2014 | 2003 Ford Explorer
Car won't start
wont crank
or
wont start.? (but cranks robustly)
fuse warning? no , we check fuse, we never pray the PCM /BCM
will never warn us, because"they dont check them all"
why not post the full symptoms.????
I key on, what happens?, do the warning lamps all glow like the operators manual says? (NO?, fuse blown , fact !)
CEL glows (check engine light glow, ) if CEL is dead so is PCM. (fuse again.)
Do the head lights work , key off (fix that first) ( no? fuse or battery dead)
when you turn the key to start, does the starter motor crank fast?
if not fix that first. (wiggle shifter or try , neutral starts)
if yes crankes, then check for spark.? (google that.)_
if it dont start, i hook up my scan tool ($200 tool) that sees all Jeep codes (key fact that) and then crank for 5 seconds, amazing, it can
tell me, why the ASD dropped out. Sure can.
if the IMMO lamp sticks on, bingo, it will never run.
here is a good ASD page
http://www.fixkick.com/Jeeps/ASD.html
Mar 30, 2014 | 2008 Jeep Liberty
Steering warning light on 2005 suzuki reno
Speed Sensitive Power Steering
(SSPS) Warning Light
If your vehicle has Speed Sensitive Power
Steering (SSPS), this warning light will
come on briefly when you turn the ignition
to ON as a check to show you the bulb is
working.
Then it should go out after a few seconds.
If the warning light does not come on, have
it fixed so it will be able to warn you if there
is a problem.
If the warning light stays on, or comes on
while you are driving, the SSPS system
may not be working. If this happens, see
your SUZUKI dealer for service.
Feb 16, 2009 | 2005 Suzuki Reno
Warning up
Hi , The printer might have problem with the Power adaptor , If you have one try replacing the adaptor.
Jan 11, 2009 | HP Officejet 4355 All-In-One InkJet...
Warning light indicator
Hello, My car is nissan tiida 2007. I recently noticed that there is a yellow colored engine shape warning indicator in the dashboard. What does this mean
Jan 05, 2009 | Nissan Titan Cars & Trucks
Turn signals dont work
hey, same problem. Car not fixed but try fuses, relay, also check bulbs and replace if you see that the are "black" on one side. I'll try to post you on what was wrong with my car in a couple of days. Good luck!
Dec 30, 2008 | 1997 Cadillac Seville
Bad picture
3d multicolor pitcture. is and indication of what is known as a convergence problem. First question. when you go into customer setup menu do you have the convergence option. if you do not then it is a common problem known as the fl231. This is a special type fuse that tells the tv that it is a three tube projection and not a one tube type tv. If you do have the option go into it and got to both blue and red convergence see if they move at all using the remote. if they do not move then you might have a convergence power board problem. if they do it might be a convegence amp or just s setup issue. i HOPE ITS just the fl231 there like 5 dollars and easy to replace if you know how to solder i fix this problem weekly on these sets at the shop. WARNING THESE SET GENERATE LEATHAL VOLTAGES EVEN UNPLUG THEY HOLD A CHARGE. if you are not experence with electronics be carefull. if you have any question let me know if i can help
Aug 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
256 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
