Question about HP PSC 2175 All-In-One InkJet Printer
Brother printer to enlarge a copy
  • 48 Answers
This printer has to be connected to a computer and have a photo program do the enlarging of the document...
If you are doing a stand alone copy (not connected to computer) then the only possible sizes are the one in the front panel, usually its letter size and 4x6 and nothing else.... it a product limitation
Posted on Sep 05, 2008
I have just got a new HP 1050 Deskjet J410 Series printer. I am not able to increase or reduce a document when copying. What do i need to do?
Press Copy until Reduce/Enlarge appears in the top line of the dis
The following options are available in the Reduce/Enlarge menu.
you will have three choices.
Reduce/Enlarge
Actual Size
Custom 100%
Full Page 91%
Legal > Ltr 72%
Also:
Use Photo Fit to Page when you want to automatically enlarge your original
photo to fill the printable area of the paper size loaded in the paper tray.
Photo Fit to Page only enlarges original photos that are standard photo sizes. The
standard photo sizes are as follows:
• 3.5 by 5 inches (9 by 13 cm)
• 4 by 6 inches (10 by 15 cm)
• 5 by 7 inches (13 by 18 cm)
• 6 by 8 inches (15 by 20 cm)
• 8 by 10 inches (25 by 25 cm)
For originals containing text or photos that are not a standard size, use Reduce/
Enlarge.
Manual is HERE Copy functions start on page 27.
Mar 27, 2011 | Office Equipment & Supplies
How do I enlarge copies on my photosmart C6180 printer
To Enlarge or Reduce.
1. Press Copy Menu
2. Select Size
3. Select Custom 100%- Hit O.K.
4. Custom percentage shows up
5. Use the Up Down function to enlarge or reduce
6. Hit Preview Button
7. If O.K. Press Start Copy for B/W or Colour
Feb 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
How do you enlarge copies using a Lanier LD015spf
The option for enlarging copies on any printer are usually found under the "properties", or, "preference" tab/button. There should be sub-tab that says "scaling" that is defaulted at 100 percent. Increasing that number enlarges the copy.
Hope this helps. :)
Oct 02, 2010 | Lanier Office Equipment & Supplies
My MFC-3240c won't copy. Has been fine up to now
Hello may I suggest doing a simple reset of your machine. If you have not tried this please do so.
Simply unplug your printer power wire from the printer and wait about a minute. Now plug it back in and your problem may be resolved.
Next, if this does not make sure you do not have any print jobs backed up in your computers printer cue.
This can be done by looking in the bottom right corner of your computer monitor. look for a printer icon. If there is on there click on it and cancel all print jobs.
Also, check for paper jam, make sure paper is not causing problem.
_________________________________________-
finally, here are the steps to enlarge and reduce. just in case there is a step you are missing.
Press options: UP or Down arrow.
Enlarging or reducing the image copied
You can select the following enlargement or reduction ratios.
Custom(25-400%) allows you to enter a ratio from 25% to 400%.
1 Press (Copy) to illuminate it in green.
2 Load your document.
3 Use the dial pad to enter the number of copies you want
(up to 99).
4 Press Options and ▲ or ▼ to
5 Press ▲ or ▼ to select the enlargement or reduction ratio you
want.
Press Menu/Set.
—OR—
You can select Custom(25-400%) and press Menu/Set.
Use the dial pad to enter an enlargement or reduction ratio from
25% to 400%.
Press Menu/Set.
(For example, press 5 3 to enter 53%.)
6 Press Black Start or Color Start.
Mar 28, 2010 | Brother MFC-3240C All-In-One InkJet...
How to do copies,ie what buttons do i press
Making a Single Copy
Place the original face down in the ADF.
2 Press Copy/Help twice.
To cancel, press Stop.
Do NOT pull on the paper while copying is in progress.
Copy Options: Single or Multiple Copies,
Reduce/Enlarge, Sort/Stack
You can choose additional copy options. First, you can select the number of copies. Next, you can
choose whether multiple copies will be STACKED (all copies of page 1, then all copies of page 2, etc.)
or SORTED (collated). Finally, you can choose an enlargement or reduction ratio. To automatically
reduce the copy to the paper size you have set for the paper tray, select AUTO. To reduce the copy by
a fixed percentage, choose 93%, 87%, 75% or 50%. Or, to enlarge the copy, select 150%, 125% or
120%. To copy a document at its original size, select 100%.
1 Place the original face down in the ADF.
2 Press Copy/Help.
3 Enter the number of copies you want (1-99).
For example: Press 9 for nine copies.
To start copying now, press Copy/Help.
If you would like to select additional copy options, like
SORT, ENLARGE or REDUCE, press Menu/Set.
Oct 02, 2009 | Brother FAX-T74 Plain Paper Thermal...
How to get enlarge photo copy.i want enlarge form of my id card
go to reduction and enlargement setting and select enlarge it should indicate incriments going up
Aug 12, 2009 | Office Equipment & Supplies
Enlarging copies
To enlarge when using the copy function on the machine, you simply do  the following:
  • Press the Copy button to activate copy mode
  • Choose "Enlarge/Reduce"
  • Press the left or right arrow key until you reach "Custom (25-400%)"
  • Press OK
  • Type in the % you want it enlarged, press OK.
  • Start copying away with Color/Mono Start.
Jun 03, 2009 | Brother MFC 490cw Color Inkjet...
Enlarging copies
I have a 5x7 page that I want to enlarge to a 8x10. Can you please give me step by step instructions? Thank you
Apr 06, 2009 | HP PSC 750 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
82 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
