Question about Samsung TX-P2670WH 26" TV
Samsung 26" (CRT) HDTV won't turn on...
Would definitely appreciate any info/help u could provide me...
My [CRT] HDTV at random times refuses to turn on [via remote or manually on the set] - some days it turns on w/no problem, some days I press the power switch and can actually hear the tube try to power up but does not successfully turn on.
When it DOES turn on, a musical tone can be heard upon start-up & the picture appears... when it does NOT turn on, I will only hear a sort of low, base-tone, "pop" sound. After one to a few days pass [I'll keep trying every once in awhile to turn it on] so far, it eventually does turn on.
Based on what u know/experienced, can my problem be fixed by simply replacing a part or two (diode-bridge, ic controller, trans flyback, etc.) ?
Thank you for your time!
- NP (Honolulu, HI)
  • 4,234 Answers
Since the set works some of the time, I'd first look for poor connections. One thing to keep in mind is when the set does NOT work properly. does that occur more frequently with heat? cold? Humidity? If you can solder, first try resoldering any connecitons on the boards that appear grainy or have rings. If that does not resolve the problem, look for patterns for when the set fails. Those patterns will help to narrow down the possibilities.
Keep me posted,
Posted on Sep 05, 2008
Samsung UN32F5500 32-Inch 1080p 60Hz Slim Smart LED HDTV -- turning on and off, fix?
sad to inform you but we do not have any parts for anything here on FIXYA.COM .
Nov 05, 2015 | Samsung UN32F5500 32-Inch 1080p 60Hz Slim...
Hi i have a coby 26" LCD TV model no TFTV 2617. How Can I get all my high definition channels. I all ready auto program it & it does not work
i have a coby 26 , I know sorry about that, but if any can help I appreciate it . turned set on today and green lite only no pic/sound/snow did have a horizontal red line for a few days prior to today.
Jul 15, 2011 | Coby TF-TV2617 26 in. LCD TV
My samsung refuses to send text messages, when i try it says error
May I kn ow the model of the phone and the provider you use.
For clarification do you use a prepaid or a postpaid line..
Regarding with your problem, you better call your network provider for this issue,
Hope this initial info helps.
Oct 03, 2009 | Samsung SGH-C300 Cellular Phone
HDMI splitter audio drop-outs with Sony Bravia HDTV
Loose the splitter and you will be in good shape unless there was damage done you should be good.
Aug 15, 2009 | Toshiba 26HF85 26 in. Television
RE: Samsung 26" (CRT) HDTV won't turn on...
THe problem is not likely to be a defective part although that could be the case. I would first look for poor solder connections that would have been agrivated by any moves that you have made. If you can solder, resolder any connections on any board that appear grainy or have rings.
Keep me posted.
Sep 05, 2008 | Samsung TX-P2670WH 26" TV
Samsung pcj522r shuts off randomly
samsungs have convergence ic that heat up and cause tv to shut off but most of the time the colors will be off. Alsp solder connections could cause this on voltage guess would be convergence ics cost for repair is 250.00
thanks doctor video
May 12, 2008 | Samsung PCJ522R 52" Rear Projection...
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
Frozen digital screen
Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Dec 21, 2007 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Samsung TV turns off at random times
Samsung TV turns off at random times it is purely due to loose contact in 1 connector 2 print loose 3 compnent in power supply loose.
Sep 25, 2007 | Televison & Video
LCD TV randomly cycles through viewing modes
yea have a tech check your tv the microchip is faulty causing it not to be stable this chip is on a module.good luck
Apr 27, 2007 | Samsung LN-S2652D 26 in. HDTV LCD...
Samsung TX-P2670WH 26" TV Logo
568 people viewed this question
Jerry Greenberg
Jerry Greenberg
