Question about Polaroid PhotoMax Fun Flash 820 Digital Camera
"Camera not connected." -- Serial connection
My PhotoMAX software gives a "Camera not connected" error message when I try to download images from my digital camera to my computer using a serial port connection.
    Master:
  • 450 Answers
The "Camera not connected" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Posted on Sep 21, 2005
"No camera is connected" -- USB connection
The "No camera is connected" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
"Connection failed" -- USB connection
The "Connection failed" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily identified: * Make sure that the computer's operating system is USB compatible. Microsoft Windows 95 and NT operating systems are not compatible with USB technology. (In addition, PhotoMAX and PhotoImpression software cannot be installed on Windows NT systems.) If you have an incompatible operating system, you must upgrade to Windows 98, Me or 2000 to use a USB connection. Your computer must also have the appropriate USB connectors. NOTE: This camera cannot make a USB connection with a computer running Windows XP. * Make sure that the camera power is on. Follow the camera instructions to turn the camera on. Some cameras conserve battery power by turning off automatically after a few minutes of inactivity. If necessary, install new batteries or connect the camera to AC power (if it has an AC power adapter). * Make sure that the camera is correctly set to access images. Make sure the camera is turned on and that its mode dial (if it has one) is correctly set for transferring pictures to the computer. Refer to the camera user guide for more information. * Make sure that the camera cable has not been damaged or become disconnected from the computer. Confirm that both of the connectors are firmly attached. Check the cable for breaks, kinks or other defects, and check the connectors for bent or broken pins. If the cable is broken or kinked, obtain a new cable.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Downloading Images
Downloading images from a digital camera can be very easy if you keep these basic steps in mind. After loading the PhotoMax software on your computer: 1. Make sure that both the camera and computer are turned off. 2. Confirm that the camera has adequate power (using the AC adapter is recommended; otherwise, make sure that there are fresh batteries in the camera). 3. Plug the serial cable that came with your camera into the serial output of the camera. 4. Plug the wide end of the serial cable into the COM port (serial connection) of the computer. 5. Turn the camera on and start the computer. 6. Launch the PhotoMax software (double-click the icon) from the desktop. 7. Click on Get Photo. 8. Click on Album or Camera. 9. Select Twain device from the Acquire From box and click OK. 10. Select your camera from the Select Source box. 11. Click the Acquire icon: (Thumbnails will be displayed). 12. Select images you wish to save from the thumbnails and click on Get Photos. Your images will now be saved to the album you choose.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
"Connection failed." -- Serial connection
The "Connection failed" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
"Failed to Connect to Camera." -- Serial connection
Sep 21, 2005 | Polaroid PhotoMax PDC 640CF Digital Camera
"Camera not connected" -- USB connection
The "Camera not connected" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily identified: * Make sure that the computer's operating system is USB compatible. Microsoft Windows 95 and NT operating systems are not compatible with USB technology. (In addition, PhotoMAX and PhotoImpression software cannot be installed on Windows NT systems.) If you have an incompatible operating system, you must upgrade to Windows 98, Me, 2000 or XP to use a USB connection. Your computer must also have the appropriate USB connectors. * Make sure that the camera power is on. Follow the camera instructions to turn the camera on. Some cameras conserve battery power by turning off automatically after a few minutes of inactivity. If necessary, install new batteries or connect the camera to AC power (if it has an AC power adapter). * Make sure that the camera is correctly set to access images. Make sure the camera is turned on and that its mode dial (if it has one) is correctly set for transferring pictures to the computer. Refer to the camera user guide for more information. * Make sure that the camera cable has not been damaged or become disconnected from the computer. Confirm that both of the connectors are firmly attached. Check the cable for breaks, kinks or other defects, and check the connectors for bent or broken pins. If the cable is broken or kinked, obtain a new cable.
Can I use the PDC 640CF camera with Windows XP?
Yes, you can use the camera with Windows XP, but you will not be able to use the serial port to download your photos. Only USB port downloads are supported under Windows XP for the PDC 640CF camera.
Sep 14, 2005 | Polaroid PhotoMax PDC 640CF Digital Camera
USB connection problem using Windows 98 Second Edition.
The cause of this problem can be traced to both the computer's hardware configuration and Windows 98SE (Second Edition). PhotoMAX cameras and other devices featuring USB (Universal Serial Bus) connections may not work with computers running Windows 98 Second Edition and equipped with the following computer hardware: * an AMD processor (350 MHz or higher) * VIA Technologies USB Host Controller or SiS 7001 USB Host Controller To find out what USB Host Controller is on your system: 1. Click Start > Settings and choose Control Panel. 2. Double click the System icon. 3. Choose the Device Manager tab. A window similar to the one shown below appears. 4. Expand the Universal Serial Bus controllers listing by clicking on the "+" sign next to the listing. 5. Note the type of host controller in the listing. The example above shows the SiS 7001 PCI to USB Open Host Controller.
Sep 14, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Sep 14, 2005 | Polaroid PhotoMax MP3 Digital Camera
Fun! Digital 320: "Camera not connected." -- Serial connection
The "Camera not connected" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily rectified: 1.Make sure that the camera power is on. 2.Make sure that the camera cable has not been damaged. 3.Make sure that the camera cable is properly connected to both the camera and the computer. 4.Clean out the computer's Temp file.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Polaroid PhotoMax Fun Flash 820 Digital Camera Logo
105 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
