Question about Toshiba REGZA 46RV530U LCD TV
Remove swivel stand
Can't get swivel stand off bottom.  It came on the television, is this normal. We are placing tv in power lift entertainment center.
  • Anonymous Mar 16, 2014
    sharlp tv stand does not swivel
There's likely a plastic cover on the back of the swivel stand. If so, remove it and you will find four to eight phillips screws. Take them out and the stand should come free. If there is no plastic cover, then there should be some screws in the back cover that go through the back cover and into the support. Remove the screws and gently remove the stand. Good luck. David
Posted on Sep 05, 2008
How do I remove the back cover from my flatscreen plasma TV?
Cover a table protective blanket.
Place TV face down on table.
Remove the stands legs( 2 screws each) then 4 large screws the legs attach to.
Or remove the wall mount brackets.
2 small black screws middle of the cover (above the component interface box).
Remove the component interface box, 5 small black screws , 2 on top, 3 on bottom.
6 black screws by the PC connection ports, (3 above, 3 below).
2 black screws on either side of the AC input plug.
12 screws around the perimeter.
Then the back should be able to be lifted straight up.
Aug 05, 2014 | Gateway GTW-P42M303 42 in. Plasma...
37LG30 TV. The swivel stand is very wobbly. How do I fix?
Remove the actual stand (4 bolts are hidden in a sunken down spot for them on the back of the tv.
Once the stand is out of the tv, look down to where the swivel joint is at, you should see 4 screws that are going towards the bottom of the stand, those will be the loose screws.
I just fixed mine.
Dec 12, 2010 | LG 37LG30 37 in. LCD HDTV
How do I remove the swivel base?
Steps to remove swivel stand:
  1. Carefully place the product screen side down on a cushioned surface that will protect the product and screen from damage.
  2. Remove the 2 screws that are vertically in line next to the power socket.
  3. Remove the 2 screws that are vertically in line under the RGB socket.
  4. Pull the stand out from the bottom of the TV.
  5. Reinstall the stand in reverse order.
Nov 03, 2009 | LG 42LC2D 42 in. LCD HDTV
I cannot remove tv stand so that i can mount on wall
There are six screws on the back of the set that remove the stand. Turn the set on its face on a soft surface (bed or carpet). At the base of the TV set (on the TV, not on the stand) you will see nine (9) screw heads. Remove the top three and the bottom three. Leave the middle three in place. The stand just lifts off.
Now, replace the six screws into the TV chassis so if you ever want to replace the stand you'll know where the screws are.
Oct 05, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
Removal of tv stand
The stand is usually held in by 4 Philips scres on the rear of the TV.
The stand itself has 2 "Arms" that point upwards, about 4 inches, they go up into the base of the TV, screws then go in from the rear of the set, low down, to secure the legs in place.
The stand, swivel mechanism and "arms" all stay together.
Good Luck, I hope it helps.
Sep 06, 2009 | Panasonic TH37PX60 37 in. Plasma...
Can't remove stand from Element flx 1910 TV.
On the bottom of the Element FLX-1910 there are 4 tabs located on the bottom side of the base. With the help of another person, please slide all 4 tabs in an inward direction. This will release the tension between the base and the stand. Slide the base over the tabs and remove the base from the stand.
Apr 12, 2009 | Element Electronics FLX-1910 19 in. LCD...
How to take bottom off to hang
You will need to remove the stand metal plate first located below the connection panel. It is held in place with 3 screws. You will have to put on of those screws back into place. Then you will need to remove 4 more screws, two on each side midway between the center and outer edge of the TV. You should be able to lift the TV off of the base.
Jan 29, 2009 | Hitachi 42HDT79 42 in. Plasma Television
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
How to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Removing bottom stand Flat Panel LCD Magnavox 32MF605W 32
There are 4 shiny screws at the back of TV just above the stand neck. Unscrew those 4 scrws and then lift the TV up, stand will come out.
Nov 06, 2007 | Televison & Video
Toshiba REGZA 46RV530U LCD TV Logo
670 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
