Question about HP Office Equipment & Supplies
When I want to print using the photo or black ink cartridges, my printer uses the tricolour cartridge. If I take the tri colour cartridge out, the printer alerts that there is a cartridge missing and still does not use the photo or black ink cartridges.
  • 48 Answers
If what you are trying to print is a black in white image then you cant print that when you dont have the other colors installed. The reason is because your image/photo has shades of gray, and for the printer to produce gray, it needs the other colors as well. It needs colors to get the light black or gray shades of the photo....
If however, you are trying to print text only, the printer should be using the black cartridge and not the other colors... I believe that there should be an option in the printers preferences to select black ink only... look for it under advance tab...
hope this helps
Posted on Sep 05, 2008
Does the canon pixma ip1200 need both the black and the colour cartridges in to print ?
You need both cartridges. It is a paradox that you need both cartridges to even scan on the mfp,s
May 10, 2014 | Canon PIXMA iP1200 Photo Printer
Have hp d1430 printer, I only use the color print cartridge, the printer will print color but will no print normal black lettering, have tried two different hP22 cartridges. Is the printer done for?
YOU SHOULD USE HP 21 BLACK INK CARTRIDGE FOR BLACK PRINTING.IF YOU USE 22 COLOUR CARTRIDGE YOU WILL GET ONLY GREAY PRINTING ONLY.I AM RIGHT?IF YOU USE COLOUR CARTRIDGES MAY YOU WILL GET MONEY LOSE. BECOS IT WILL FINISH EARLY.BLACK INK COST IS LESSTHAN COLOUR INK CARTRIDGES. SO YOU SHOULD BUY BLACK CARTRIDGE FOR REAL BLACK PRINTING.
Jun 29, 2011 | HP Deskjet D1430 InkJet Printer
Epson sx200 printer, wont print black ink only
Many printers especially Photo ones also use colour even when printing Black. so you do need to replace the spent colour cartridge.
If you only need to print in black get a B&W printer not a colour one.
Jan 01, 2010 | Epson Office Equipment & Supplies
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
Can't print color only black and white
Please check if your Colour Ink Cartridge is not emply. If their's ink in the cartridge then try to service your printer through the Print Preferences. Your Colour Cartridge Nozzels could have been blocked thats why your printer is unable to print in Colour.
In case if both the above doesn't work then check in the Print Preferences that you should not have saved the option of PRINT DOCUMENT IN BLACK ONLY. hope this helps , AJ
May 18, 2009 | Dell 966 All-In-One InkJet Printer
Refilling tricolour tanks
It can be done, I have used refilling ink on HP printer before with only two cartridges, I just went by the diagram that came with refill package. However, it was a messy job and there are lots of shops that refill tri-colour cartridges now and I would definatley opt for that option.
I hope this helps
Nov 27, 2008 | Office Equipment & Supplies
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
Why is there 2 black ink cartridges in my Canon MP600 printer
On some printers, probably including yours, the black ink will be taken from the reserves in your colour cartridge unless you specifically tell it to do a black and white print on each document, regardless of whether it's printing black exclusively. I wouldn't worry, the black ink in it's own cartridge can also be used for colour photos etc with no detrimental effects.
Mar 29, 2008 | Canon PIXMA MP600 all-In-One InkJet...
My canon i960 is printing only green
I had this problem. If I tried to print a black& white photo on to glossy paper, it would only print green. When I tried on to plain paper using the 'fast' option, it printed in black. The reason for this is, on plain paper it uses the black cartridge, but output to glossy photo paper using the 'high' option, uses the mix of colours in your colour cartridge. If one or more of your colours has run out, you will get a print with the ink left in the cartridge. Replace the cartridge or refill it & your problem is solved.
Dec 19, 2007 | Cannon Canon i960 Photo Printer
139 people viewed this question
Ben Johnson
