Question about Samsung Blackjack SGH-I607 Smartphone
Sims card Black jack 1 will not read simms card
  • johnathonwil Sep 05, 2008
    it says this phone is assigned to a specific SIM please enter code or approved SIM
I need a little more info. What exactly does it do when you insert the card and turn your phone on?
Posted on Sep 05, 2008
How do I install my sims card into my iphone 3g?
On the top of the phone there is a small hole next to the headphone jack. Find a paper clip and bend it so that the paperclip is straight. Then insert the paperclip into the hold next to the headphone jack and push lightly until the SIM card try slides out. Then insert your SIM cart into the tray and then put the tray back into the phone.
May 21, 2011 | Apple iPhone 3G Black Smartphone
When i inserted a sim the feedback i get is searching
try a different simms card,make sure card is in perfectly in right,clean connection with achohol,if you dont have a sims card go to a dealer ask them to use one
Jan 23, 2011 | Samsung SGH-t239 Cell Phone
Service 960 memory error- r for my Lexmark C532n printer
A 960 RAM MEMORY FAILURE message indicates a failure of the RAM MEMORY that is soldered onto the printer's main controller/system board.
If the printer is displaying a 960 memory error.
1. Power off the printer.
2. If you have any extra memory SIMMs or code SIMMs installed in the printer, remove them.
3. Power on the printer.
4. If the 960 error continues, the main controller/system board will probably need to be replaced.
5. If the 960 error does not return, try printing a few documents.
6. If these documents print correctly, the cause of the 960 memory error is probably one of the SIMMs you just removed.
To confirm this, do the following:
1. Turn off the printer and reinstall each SIMM one at a time.
2. After you install each memory card, power the printer back on and try printing. If the error returns as soon as you install a particular SIMM, that SIMM is probably the cause of the error message.
Nov 08, 2010 | Lexmark C530dn Laser Printer
I need a puk code for samsung s-3650 can not use it without it.
If you enter your SIMM password wrong a few times (3 in general), your SIMM will be lock: contact your Mobile phone Service provider help desk who should be abel to give you the specific SIMM card 'PUK' code.
DO NOT ATTEMPT TO ENTER INVALID CODE as after usually 10 tries, your SIMM CARD WILL BE DESTROYED and need replacement simm at a (substantial) cost!
Dec 24, 2009 | Samsung S3650 Corby / S3650 Genio Touch...
My hp ipaq hw6515 does not read my Afghanistan's sim card
The IPAQ 6515 will only work with GSM Simm and network. It is also NOT 3G compatible.
You can verify that the 6515 is working with another network SIMM, then it is likely that your Simm card is not compatible and may in fact be design on Afghanistan's 'Analog' network.
Incidentally, the 6515 will also not work in Japan even with a working 'roaming' SIMM as the Japanese Mobile Network is also not compatible!
Hope it helps!
Dec 15, 2009 | HP iPAQ hw6515 Pocket PC
Sims and sims 2 on external hard drive?
It works great, I had to do the same thing. All you have to do is save it to the external drive. yes all the programs and expansions need to be on the external drive.
When it asks you if you want to put it on the C:/programs/simms as it always does, just change the "C" to what ever drive your external drive is. do this with each game.
You will me living like a simm in no time. Let me know how you did..
Aug 20, 2009 | EA - Electronic Arts The Sims Deluxe...
Continuous Beep-Beep-Beep.. When I turn on T3304 E Machine
there is a faulty hardware in your PC. here the beep error code this might help to locate the faulty hardware in your pc, and which help you to isolate the problem.
1 Short beep - System is operating normally.
1 Long beep - Memory refresh circuitry has failed which indicates a problem with the motherboard. Try
reseating the memory DIMM or SIMM modules. Make sure if you have added memory that it is rated at the correct speed for the system.
1 Long 2 Short beeps - The video adapter has failed, or the video memory is having a read/write
failure. Try reseating the video card. If the video card is a PCI video card, try moving it to another slot.
1 Long 3 Short beeps - The system does not detect a monitor. Verify that the monitor cable is properly attached to the video card or the onboard video and to the monitor (if the monitor has a detachable cable). If possible, try another monitor on the system to verify that the video adapter is operating properly.
2 or 3 beeps - There is a problem with the system’s memory. Reseat the memory DIMM or SIMM modules.
4 beeps - This indicates a non-functional timer. This indicates a problem with the motherboard.
5 beeps - This indicates a CPU (Central Processing Unit or processor) failure. Try reseating the processor.
6 beeps - This indicates a keyboard controller failure. Try reseating the keyboard connector.
7 beeps - Another indication of a processor problem. Reseat the processor.
8 beeps - This indicates a video memory read/write failure. Reseat the video card (if any) and memory DIMM or SIMM modules.
9 or 10 beeps - This indicates a ROM (Read-Only Memory) checksum error or shutdown register failure. This indicates a defective BIOS chip(s). Reseat the BIOS chips.
11 beeps - Indicates an error in the cache memory. If the system has a Pentium class processor, reseat the processor. If the system has a cache memory module, try reseating it. These beep codes will vary depending on the system
hope this would help.
Nov 30, 2008 | E-Machines eMachines Desktop PC
Sims card
the sim card may be pre-paid and blackberry's and i-phone don't take pre-paid sims, it gets annoying, but if this doesn't help maybe go see a phone technition? without the phone and sim infrount of me i can't quiet dignose the problem.
Oct 26, 2008 | RIM BlackBerry 7520 Handheld
N internet or texting
ok no dis but owing them money will do this, also a coverage change in the 3g netwrk may also be the problem so call your provider and check that as well as simply restarting your phone if you have a sims card take it out while off and place back in fi not skip step and when powering on there should be an internet signal that should connect to your provider such as cingular has an blueglobe etc for diff providers if this comes up and still no luck ask provider to check yor simm card for if a new one is needed or in no simms a software checkup.
Nov 11, 2006 | Motorola Mobility RAZR V3
Samsung Blackjack SGH-I607 Smartphone Logo
97 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
