Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
Whirlpool Side By Side Refrigerator
My fridge started making bubbling or running water noises recently. Its loud and NOT normal.
What is it?
    Novelist:
  • 166 Answers
1. How do I get repairs done under warranty?
* If your refrigerator is under warranty, you must use an Authorized Service Company.
An Authorized Service Company can be found by using our Service Locator. Enter your zip code on the Service Locator to get a listing of available service companies in your area.
Back
2. How do I order parts?
* Parts can be ordered through an Authorized Frigidaire Parts Distributor.
An Authorized Parts Distributor can be found by using our Parts Distributor Locator. Enter your zip code on the Parts Distributor Locator to get a listing of distributors in your area.
* You can call our toll-free number to order parts (credit card orders only.)
Please call 800-599-7569 M-F 9:30am - 5:30pm.
Back
3. Noises / Sounds.
* Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises.
The following can be sources of these noises:
1. Dish vibrating on shelf - move dish slightly.
2. Floor is uneven or cannot adequately support refrigerator. Use shims or extra support.
3. Items on top of refrigerator are rocking. Place a pad under the item or remove.
4. Refrigerator is not level. Adjust leveling legs or rollers as needed. Add shims in the back if floor is not level from front to back.
5. Refrigerator is touching wall or cabinets. See your owner's manual for space requirements.
* Snapping or clicking sound.
If your refrigerator is equipped with an ice maker the water valve will snap on when the ice maker is calling for water. This is normal. In some cases you may not have the water connected to your ice maker and the sound will be greater. In these cases, pull the wire signal arm (bail arm) on the ice maker in the up position to turn your ice maker off until the water supply line is installed.
Back
4. Taste and odors.
* Ice or food has a bad taste or odor.
Ice and uncovered foods can pick up odors or taste from strong smelling foods in the refrigerator or freezer. Cover foods tightly and discard old ice.
* Ice tastes like plastic.
Plastic water lines will give off a taste when first used. It takes one or two containers of ice for plastic to stop leeching. Discard initial container of ice after installation.
Back
5. Ice maker - not making any ice.
* Freezer may not be cold enough.
Temperature must be 5 F. or colder to work properly.
* Water supply valve may be blocked or restricted.
Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
* Water supply valve may not be open.
Find and open the supply valve.
* Wire signal arm on ice maker is in the up position.
This position shuts off the ice maker. Pull wire arm (bail arm) down to start ice making.
Back
Posted on Sep 05, 2008
Our refrigerator does a very loud buzzing for 5 seconds 3 or 4 times a day what is the problem its only 3 months old and very annoying
Normally as loud buzzing from the fridge on that frequency it just the icemaker cycling, the water inlet solenoid valve often makes a buzzing noise depending upon water pressure. Other than the noise, there is nothing to worry about.
Sep 26, 2016 | Frigidaire Refrigerators
My Bosch Fridge makes a loud gurgling sound every twenty five minutes even after freezer fan &emotion were replaced.
It's a normal noise! When the liquid refrigerant becomes less pressurised, usually when the thermostat clicks off,, it still bubbles through the system until the pressure equalises.
Dec 17, 2014 | Bosch B22CS50SNS Side by Side Refrigerator
Beko WME8772W washer not working
clean the filter first
look in the pump for any bits in it
Feb 06, 2014 | Washing Machines
NOISY FRIDGE
hi glenn ,most fridges make this noise but if your worried ring the place you brought the fridge from and get them to send an engineer to check it. good luck
regards
shaun
Dec 09, 2011 | Washing Machines
1. My fridge is making a loud clicking noise at
If there is ice in the icemaker and its not ejecting the ice you more than likely have a bad heater in your icemaker not heating the cubes for the rake to scoop them out. No water through the door would probably be a separate issue. If its a GE they are known for poor insulation on the freezer door and the water line will freeze going up the inside of the door. If you remove the kickplate there will be a quick connect coupler. remove it from the line going up the door and call for water. If you get water to this point you know the line is frozen through the door. If not then you will want to check your saddle valve for calcium deposits gunking it up. Least common issue would be a bad water valve.
Jan 09, 2010 | Hotpoint HSS25GFP Side by Side...
02 Durango: loud engine/exhaust sound. Also Recently noticed the cooling fan running more than normal; had someone check the antifreeze/coolant....it was empty....had them put in a 50/50mix of coolant and...
That noise is probably the air injection system which is part of the emmision system. When it is making that noise, open the hood and determine where it is coming from, note if it is a mechanical sound, etc. The air injection if equiped would sound almost like forced air scaping somewhat like an exhaust leak, but less intense.
Jul 14, 2009 | 2002 Dodge Durango
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
522 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
