Question about HP LaserJet 3030 All-In-One Printer
HO Laser All in one printer
Error 79 appeared and remain even after off and on.
I tried unplug, off and on, disconnect from the computer, etc.
Lights are flashing and it won't do anything.
Please help!
  • 47 Answers
Reset printer, perform a NVRAM INIT
Turn off powerswitch- press and hold * and Menu/Enter on keypad of printer - While continue holding down buttons, turn on the powerswitch.. after a few moments it will begin to beep and say "perminante storage init" release the buttons and wait for the unit to re-initialize.
As always when perform a disc reset, you loose your settings.
Posted on Nov 05, 2008
Red light next to green light is on(not flashing), 79 error (does not work)
79 errors are usually firmware related on newer HP models. Disconnect any USB or Network cables and power cycle the printer. If it will come to read, connect a USB cable from the printer to a computer with internet connection. Then you want to go to www.hp.com and search for the current firmware for your model which will be a program you download and run and it will automatically update your printer. Also ensure that if you are connected to a network that you clear all print jobs from any computers that might print to this printer.
Apr 14, 2014 | HEWLETT-PACKARD CP1525NW Laser Printer
79 service error
Would appear that either someone has put in some bad memory or the memory that came with it has gone bad:-
You could try taking the memory out to eliminate it.
79 Service error
Description
An incompatible DIMM is installed.
Recommended action
  1. Turn the product power off.
  2. Install a DIMM that the product supports.
  3. Turn the product on.
If the message persists, contact HP support.
Dec 28, 2013 | HP LaserJet Pro 400 M401DN Laser Printer
79 Service error
79.XXXX PRINTER ERROR
  1. Turn off the printer.
  2. Turn on the printer.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. (If the message only appears with a certain software program or print job, contact the software vendor for assistance.)
If the message persists, try the following:
  1. Cycle power.
  2. Reseat or replace the interface cable and cycle power.
  3. Remove the DIMMs one at a time and cycle power.
  4. Try using the parallel interface, if possible.
  5. With the EIO cards removed from the printer perform a cold reset:
    1. Remove any accessory, including the HP Jetdirect card.
    2. Turn off the printer.
    3. Hold down the GO button while turning on the printer.
    4. When the printer displays COLD RESET, release the GO button.
Aug 30, 2012 | HP LaserJet Pro 400 M401DN Laser Printer
HP 1700n laser printer. Won't reset.
Hi, first; lets’ start from scratch. Turn off your (Computer), turn off the (Printer), unplug the printer from the power outlet; do not make any changes to the computer. Disconnect (all) the printer cables from the computer; reconnect the cables to the computer, and plug in to power outlet. Turn on the computer (first), turn on the printer. Go to; Control Panel, (Hardware and Sound), click Printer; if the Printer is present; click to open, Properties, click (Drivers): Update Drivers. Restart computer. Thanks paul7of9
Jan 12, 2010 | Dell 1700n Laser Printer
I have a Canon imageclass MF4150 Printer with startup issue
Try in service mode ( add.function & #) then clear all, if not try to switch over every conector on the Main PCB board.
Jan 12, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
SCANNER LOCKED IS ON THE DISPLAY SCREEN I HAVE CHECKED THE GREEN BUTTON UNDER THE PAPER TRAY AND THAT IS SET TO UNLOCK. WHEN I TRY TO PRINT THE DISPLAY SCREEN SAYS SCANNER ERROR AND THE SCANNER LOCKED
Hi, what you want to do is, first; (shutdown) your Scanner, next (shutdown) the computer. Disconnect the scanner, and unplug it from the outlet. Disconnect scanner cables from the computer; Note: do not change anything on the computer. Reconnect cables to the computer. Plug scanner back into the power outlet; turn on computer, turn scanner on. This may clear the (Freeze); but the (Error) might appear again. Thanks paul7of9
Jan 05, 2010 | Xerox Phaser 6110 Laser Printer
HP Laser Jet 3200se fax machine
Hi..
The service error refers to an hardware issue with the printer.. U can try the following step,if this didnt resolve the issue only option is servicing.
1. Unplug printer.
2. Press and hold SYMBOLS & ENTER/MENU.
3. Continue to hold down the buttons while you plug back in the printer, through the entire
power-on sequence.
4. When display reads PERMANENT STORAGE INITIALIZE or HP LASERJET 3200
release the buttons.
Jan 09, 2009 | HP LaserJet 3200se Printer
HP LaserJet 3200se 79 service error 694:SM.C
1st shut the printer off
2nd Disconnect it from the Computer
3rd turn it on
Does the error still occur?
If it starts properly print a configuration page.
If this is possible you have a Printer Driver issue.
Replace the Print Driver.
If it still has the error when the printer is NOT connected to the Computer then you have a firmware issue most likely.
Nov 06, 2008 | HP LaserJet 3200se Printer
Error 77 is apprearing
Unplug the unit.
Hold down the menu key while plugging back in / powering up.
When finished initializing, hit 99.
Wait to status comes back and hit 91.
This supposedly happens due to a power surge or outage.
If this doesn't work for you try reversing the numbers above.
I have a bad memory, it might be 91 first then 99 but, you definately have to hold down the menu key.
Sep 11, 2008 | Brother IntelliFAX 4100 Laser Fax
Unexpected dark lines appearing when I print
I've now discovered the updated model of this printer is now only $79, a third of what I paid two years ago. It is cheaper to replace the printer than have it repaired.
Jul 22, 2008 | Samsung Monitors&Printers x22 ppm Mono...
HP LaserJet 3030 All-In-One Printer Logo
221 people viewed this question
Seeker5211
Seeker5211
