Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer and refrigerator are not keeping cold
Hi...we recently were given a used Jenn-Air side by side refrigerator Model #JCB2389ARS with a few problems. The temperature for the freezer and refridgerator don't keep constant temperature...either it's too cold or too warm in BOTH compartments. One day it's freezing the produce in the crisper on the refrigerator side and the next it's thawing out ice cream in the freezer compartment (as it is now :( what could be the problem as we do not have the owners manual (by the way...how can we obtain one?) AND how do we fix it? Both compartment get warm. I can unplug the main control board for a few minutes then plug it back in and it will work for a few days
  • 421 Answers
The thermostat controler is most likley bad this is where you set the temp with the knobs you can find the parts online with the model number please rate- jeff
Posted on Sep 05, 2008
I have a Jenn-Aire side-by-side refrigerator Model #JCB2280HES, Serial #10024253EP. The warranty expired in February 2010. The food in the bottom half of both the freezer and refrigerator is frozen and...
Hi!!
Check to see if the evaporator fan behind the freezer wall (remove wall) is running. If it isnt the air will not flow properly in the unit. Replace the fan motor and it will fix it.
Good Luck!!
Jul 29, 2010 | Jenn-Air JCB2280HES Side by Side...
I have a Jenn air side by side refrig/freezer
Hi rdiorio.
you could have one of many faults, either thermostat, compressor or if electronic maybe that have failed. If the Thermostat starts to fail it can produce eratic readings which freezer the chiller part of cabinet, then it can fail completly. What ever you do remember 240 Volts kills. Use a qualified person when dealing with electrics... Cheers
Mar 29, 2010 | Jenn-Air JCD2389G Side by Side...
I have a jenn air side by side. the freezer is
This is usually a sign of a defrost problem. I will need you model number to help you better. Sea Breeze
Jun 26, 2009 | Jenn-Air Refrigerators
Jenn-Air JCB2389GRS Fridge not cooling properly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
puiodf
Mar 15, 2009 | Jenn-Air JCD2389G Side by Side...
No cold air coming into the fridg
iF YOUR REFRIGERATOR SETTING IS HIGH, YOU NEED TO LOWER THE SETTING IN ORDER TO GET IT COLDER.
If you still have no air flow, there is a fan that blows cold air from the freezer to the refrigerator. The motor could be burned out.
Sqiudo
Dec 15, 2008 | Jenn-Air JSD2789GES Side by Side...
Fridge not keeping food cold.
When you open door to freezer do you hear a fan inside that compartment blowing? If you don't the fan motor is shot and will need to be replaced.
Nov 24, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air Refrigerator Not Cooling
As others have noted, the solution is counter-intuitive but easy. The refrigerator keeps cold on this model by cold air coming over from the freezer side. So most likely it is ice blocking the freezer coils or the fan that moves the air. So turn off the freezer and defrost it. You will need to remove the big white plate on the back of the freezer (on the inside) to most effectively get the ice to melt. You can use a hair dryer for this, or just leave the freezer sitting with the door open for several hours.
Jul 09, 2008 | Jenn-Air JCD2389G Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
195 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
