Question about Brother MFC-465CN InkJet Printer
My Brother MFC-465CN is printing text with alignment off and double text.
The pages I am printing seem to be clear quality, but the text is off, almost like double text, where the same word is printed over twice making everything unreadable and unsightly. I cleaned my printer heads and did and alignment check but when i am asked for the correct alignment the one it is set to is the closest (still off) and not giving adequate results at all. Please help, it woudl be much appreciated.
  • 2 more comments
  • Anonymous Sep 10, 2008
    connection
  • yoddle Sep 10, 2008
    Connection was deffinitely not the problem. Tested and this was proven false, this i belive has to do with something mechanically, possibly?
  • chaiklee79 Sep 22, 2008
    The pages i printing is unclear and double text .The word is unreadable.I tried to test cleaning my printer catridge test the alignment as well but still cannot resolve the problem at all .Any solution for this problem as this is new machine just bought from VIKING ..
  • Anonymous Mar 05, 2009
    I have the same problem with my MFC-240. seems like is printing double with an offset, making the print unreadable and unclear
My Brother printer MFC-465cn is doing the same thing. I have workaround / worked-around it by disabling bi-directional printing. Then print is clear. It's as if the head is shifting an irregular amount on the opposite direction, like the head is loose.
Same for copies. If I use the PC interface to make copies, I can set the copy printing to be mono-directional, then copies are clear.
Posted on Mar 02, 2009
I keep getting this error message; Unable to print 34
Posted on Sep 18, 2008
Connection
Posted on Sep 10, 2008
How do I fix double printing
Not sure what you mean by double printing.
Is it printing a ghost of what you print further down the page. Or is it mis-aligning the characters so it appears to have a shadow on each character?
Aug 11, 2014 | Brother MFC-465CN InkJet Printer
How to you clear the memory on a brother MFC-9125CN
Im not completly sure this applies to your mfc brother. remove all paper. turn on machine. select"menu" "0" "6" this resets it . you will have to re-due your personal setting otherwise it goes to defalt at time of purchase.
Jun 06, 2014 | Brother MFC-465CN InkJet Printer
I have not been using the Brother MFC 465CN printer for a while. Bought and installed new cartridges, cleaned the print head several times (from the printer menu option). But, nothing is getting printed....
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 24, 2011 | Brother MFC-465CN InkJet Printer
My brother printer model mfc 465cn, it has ink but the print its not coming out, dont know what to do
try cleaning the carriage assembly. the that the ink is installed at. then do the print alignment at the printer settings.
Jul 02, 2010 | Brother MFC-465CN InkJet Printer
The printer quality is very poor, it is like there is no black ink in the cartridge (which is full). I think there is a faulty on the roller. There is a consistant line through the text.
Have you tried cleaning the print head? There will be an option in the printer control software to do this. Look at your manual or online help.
Head cleaning is a process that the printer will perform itself - it prints one or more pages in a process designed to clear any ink blockages on the print head of the cartridge.
If the printer is seldom used this is likely to be the solution.
Feb 12, 2010 | Brother MFC-465CN InkJet Printer
I have btorher printer mfc-465cn. problam is i give computer print all text dubble latter com i check scan and same problam but printer self is good how to solve i don't indurstand pleasse help me
http://www.hp.com/#Support this link could solve your problem.
also make sure you are using good quality ink for your printers. I use to have many problems with my printers and then i started purchasing my ink from www.yahootoners.com, you could not find a better price quality product anywhere else. trust me its worth it.
Jun 04, 2009 | Brother MFC-465CN InkJet Printer
Brother mfc 465cn printer
If you remove the empty cartridge, you will see a small window on the egde that plugs into the printer, in the center. This is where the printer optically scans for ink levels. On the empty color cart, you can try covering that raised spline with electrical tape or by coloring it with a black permanent marker. That should fool the sensor into thinking your ink is full.
Oct 31, 2008 | Brother MFC-465CN InkJet Printer
Printing selected text only
Have you tried highlighting the text, copying it, pasting it into a notepad and printing it from there?
Aug 22, 2008 | Brother MFC-465CN InkJet Printer
Brother MFC-210c prints some lines blurred, letters stacked - alignment ok.
i have the same problem. repeated cleanings seem to help, when i print large fonts they come out pretty clear, but the smaller the font, the worse the blurring. 600 DPI prints mismatching patterns, but 1200 DPI prints perfectly fine. so i have found that printing on "fine" quality instead of "fast" or "normal" quality improves print quality ALOT. it uses more ink, but i am in business and need to be able to read very fine print!
May 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
Double prints or Text shadow printing by MFC 420CN
yes. you have to run the alignment feature. press ink - set - arrow-down til alignment. After alignment test print read the paper and choose the right setting by nr.
Apr 09, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-465CN InkJet Printer Logo
1,753 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
