Hyunai A/C Unnit
Thanks for the quick response. What is the timer's circuit? Is it something I need to get a qualified tech out for?
  • 1,269 Answers
Yeah, only a qualified or pro aircon tech can replace it. Also the evaporator coil needs to be check for leak. If your unit is still under warranty better call the manufacturer. Anyway, here's how aircon works:
Window air conditioners work on exactly the same principles as a refrigerator or dehumidifier. They have a cooling system that refrigerates the air entering the unit. The moisture in the air condenses on the cold coils and drips into the bottom tray of the air conditioner. The warm air in the room is drawn over the evaporator coil, which collect heat. The heat is conducted into a refrigerant gas. The gas is then circulated to the condensing coils on the back of the unit where it is dissipated to the outside.
Posted on Sep 05, 2008
My ZR500 cmcorder ahs a dead battery. I checked the charger vor voltage and it is OK. (I am an electronics tech). The red charger light does not comeon. Thanks, George
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on .
Oct 31, 2010 | Canon ZR500 Mini DV Digital Camcorder
No sound from zenith dvt412 stuck in bypass to override?
this is a protection circuit.
When bypass mode then it means that something in the power supply module has failed and the unit then goes into protection mode to protect the board components.
Your surround sound need service from a qualified tech. No other remedy.
Mar 24, 2010 | Zenith DVT412 System
1991 jeep cherokee. Car turned off but something still running in engine near passenger side
its normal.... it maybe coolant is going down the pipes or ECM finishes its job
Jan 29, 2010 | 1996 Jeep Grand Cherokee
I heard something pop from the back of my mitsubishi 60 inch an my tv went out an the light lamp came on and the timer light came on
you have a faulty high voltage circuit, this can only be repaired by qualified personal sory
Jan 27, 2010 | Televison & Video
Oven door locks when using oven
It's made to do that to prevent some dumb child from climbing in while it's on and getting roasted...
Jun 11, 2009 | Ovens
Sound cutting out
protection circuit cutting in. needs a tech shop visit not something that can be done by unqualified persons
Apr 05, 2009 | Audio Players & Recorders
When t.v. is turned on, black picture and no sound.
Usually when the fuse blows its due to a component being shorted and if you increase the rating of the fuse you can cause other components in the circuit to blow. The pop you hear was most like a capacitor on the D board. The D board is no longer available from sony as its listed as discontinued. You will most likely have to have a qualified sony service tech trouble shoot the circuits on the D board to locate the short as it will be outside the scope of a do it yourself type of repair
May 16, 2008 | Sony KP-61HS10 61" Rear Projection...
TV won't turn on.
The horizontal (line) deflection circuit appears to be at fault. This circuit is responsible for the generation of high voltage (tension) that also drives many of the secondary circuits such as the vertical drive, tuner and sound stages. While the main power supply itself is running, a failed secondary stage will give the symptom that you've mentioned. Replacing the line-output transistor is likely to solve the problem. However, this advice is given with the understanding that you are familiar with TV repair. Otherwise please refer servicing to a qualified tech.
Jan 09, 2008 | RCA TruFlat 27F520T 27" TV
Sony trinitron tv
If you have sound but no picture it means that your power supply and tuner are working correctly. The number of times the timer LED blinks is the code for the problem with the picture. The computer will stop the picture and blink the timer LED if the vertical circuit stops working, if the picture tube is too weak or if the horizontal sweep has stopped. The set should be serviced by a qualified tech familiar with Sony sets.
Sep 03, 2007 | Sony WEGA KD-34XBR970 34" TV
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
