Question about Polaroid PhotoMax Fun Flash 640 Digital Camera
Downloading Images How do I download images from my Fun! Flash 640 camera?
    Master:
  • 450 Answers
Downloading images from a digital camera can be very easy if you keep these basic steps in mind. After loading the PhotoMax software on your computer: 1. Make sure that both the camera and computer are turned off. 2. Confirm that the camera has adequate power (using the AC adapter is recommended; otherwise, make sure that there are fresh batteries in the camera). 3. Plug the serial cable that came with your camera into the serial output of the camera. 4. Plug the wide end of the serial cable into the COM port (serial connection) of the computer. 5. Turn the camera on and start the computer. 6. Launch the PhotoMax software (double-click the icon) from the desktop. 7. Click on Get Photo. 8. Click on Album or Camera. 9. Select Twain device from the Acquire From box and click OK. 10. Select your camera from the Select Source box. 11. Click the Acquire icon: (Thumbnails will be displayed). 12. Select images you wish to save from the thumbnails and click on Get Photos. Your images will now be saved to the album you choose.
Posted on Sep 21, 2005
When I try to download pics from camera it goes into NOT RESPONDING mode and I can't do anything. It shows up 2 of 8 images and stops and I have to close down everything.
HI,
you have to give a little more info.
On your camera and the computer.
Typically what you are describing is time out. Common if using bluetooth or incompatible software.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Using other Camera software with a Poloroid 640 Fun Flash
I have three different digital cameras. I use the scanner and camera wizard to download my pics.
The second option, if you use SD card with your camera, then you can get a USB 2.0 SD Memory Card Reader/Writer.
Mar 21, 2009 | Polaroid PhotoMax Fun Flash 640 SE Digital...
"No camera is connected" -- USB connection
The "No camera is connected" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Can I use the Fun! Flash 640 with a USB port?
A 9-pin serial connection must be available on your computer to connect a PhotoMAX Fun! Flash 640 digital camera. This camera model does not have a USB driver, so a USB-to-serial adapter will not function properly.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Fun! Flash 640 camera specifications
Optics ? 7.0mm, F 3.0 (40mm: 35mm equivalent) lens ? Focal range 20" - infinity ? CMOS image sensor ? Automatic exposure system ? 1.8" color LCD display monitor ? 1/8 - 1/1000 second exposure control ? Flash range: 3-6' images ? Color: 24-bit (millions of colors) True Color ? JPEG compression ? 2 image resolution modes: 640 x 480; 320 x 240 Storage, Interfaces, and Power ? 2 MB internal memory ? Typical image storage capacity: 15 images (640 x 480); 50 images (320 x 240) ? Serial interface: RS-232 ? 4 AA-type alkaline batteries User Controls and Other Features ? Automatic self-timer ? Tripod mountable ? Automatic power saving mode Physical ? Dimension: 4.25"(l) x 1.63" (w) x 3.13" (h) ? Weight: 8 oz. (approximate without batteries)
Windows NT4 and Windows 2000
Windows 2000 A new camera TWAIN driver (version 0.1) compatible with Windows 2000 is now available for download. The new TWAIN driver will allow photo transfer using most image viewing or editing programs that are TWAIN compatible. NOTE: In order for the version 0.1 driver to work correctly, the PhotoMAX software must also be compatible with Windows 2000. The PhotoMAX SE software originally included with the Fun! Flash 640 is not compatible with Windows 2000. If you use your camera and computer with the original PhotoMAX SE software, contact the Polaroid Parts Department for more information about purchasing a PhotoMAX software upgrade. Windows NT4 No TWAIN driver is available for use with Windows NT4.
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Resolution ?
When you turn on the Fun Flash! camera, the default resolution is 640 x 480, as indicated by the two stars displayed on the LCD panel. To change the resolution to 320 x 240, you need to turn the camera off and then press and hold the self-timer button while turning the camera back on. Release the self-timer button and the camera will be in the lower resolution mode (indicated by the single star on the LCD). Remember, the next time you turn on your Fun Flash! camera it will default back to the 640 x 480 setting.
Can I use my Fun! Flash 640 digital camera with other software applications?
Yes, you can use your Polaroid Fun! Flash digital camera with many popular image-editing software applications. The Fun! Flash is TWAIN-compliant and comes with its own image acquisition software, which is automatically installed when you install PhotoMAX. Just open your image-editing software and select Polaroid Fun! Flash as your acquisition source.
Can I use a Polaroid digital camera as a web camera?
None of the Polaroid digital cameras listed below can be used as a "web cam." All of these models are designed for taking still images only. DMC/DMC 1e DMC2 Fun! Digital 320 Fun! 620 Fun! Flash 640 Fun! Flash 640 SE Fun! Flash 820 MP3 Digital Camera Olympus C-211Z PDC 300 PDC 640 PDC 640CF PDC 640M PDC 640 Plus PDC 700 PDC 800 PDC 1100 PDC 1300 PDC 1320 PDC 2000/3000 PDC 2300Z
Sep 14, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Can I use the Fun! Flash 640 SE camera with Windows XP?
Yes -- with some minor modifications, you should be able use your Fun! Flash 640 SE camera with a computer running Windows XP.
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Polaroid PhotoMax Fun Flash 640 Digital Camera Logo
174 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
