Just got cable today, and i had to cable man attach it to the tv, and no cable. He said we have prefect reception, and the cable box is good. i get two channels fuzzy and one only a little out of the 63 channels we are suppose to get. any ideas?
    Genius:
  • Televison & ... Master
  • 1,689 Answers
Did you check to make sure that in the options, the TV channel configuration is set to CATV or Cable mode, and not to Antenna mode?
If the above is true, the tuner module in your TV is probably defective.
You need to call in a TV service person who is familar with the type of TV you have to check the tuner.
Jerry G.
Posted on Sep 05, 2008
Sgnal not found
Lila, Signal not found, check all your connections to your cable box, satellite box or Arial, which ever you are using. Make sure cable connections are good and not damaged. On some TV's the setup manual tells you to do a search of all available channels before you can view. TV has to be set to the correct source or input. Try changing the source or input to AV, TV, Digital TV or DTV to see if this is the problem. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
No Signal or reception issues on multiple or all channels
Why Does My TV Say No Video Input or No Signal
SONY eSupport The TV is not displaying any picture or NO SIGNAL message is...
Aug 05, 2016 | Televison & Video
Pioneer Purevision PDP-4340HD will not shoe close caption for cable TV
Hi rafaelvh,
If you see the manual.
(go here if you dont have it)
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000060450.pdf
You can see on page 14 that it talks about the close caption.
"Not all programs offer the Closed Caption option. Please refer to the [CC] symbol to ensure the caption option is available."
It can also be caused if the broadcast source is poor, or the signal is weak.
Jan 12, 2008 | Pioneer PureVision PDP-4340HD 43 in....
I'va a Mod CLC 503 (new out of box) Not able to receive (signal) when turned on. Attaching to "cable", no box or converter needed. The coax cable I'm using is good, out put from splitter is good....
In the menu settings, there are two things you need to change. There is a reception type that you need to change from "AIR" to "CABLE." You also need to set the channel to whatever your cable box is set for (mine is 4).
Nov 10, 2010 | Televison & Video
LCD TV IS CONNECTED TO CABLE USING SATELITE. CABLE IS RUN APPROX 150 FT FROM SAT DISH TO TV. RECEPTION IS VERY GRAINY,,,IS IT THE LENGTH OF CABLE? THE CABLE IS 100FT CONNECTED TO 50FT CONNECTED TO TV....
Is the satellite receiver HD or standard?
If it is standard you should hook up the box to the tv via RCA cables (Yellow/Red/White) and this will help with the picture quality.
If it is a HD receiver then hook up the box to the tv using a component video cable and this will drastically change the quality of the picture.
Using a coax cable to attach from the box to the tv essentially is connecting an analog signal to the tv and this will produce a lower quality picture...
Good Luck!!
Jan 02, 2010 | Samsung LN32B360 32 in. LCD HDTV
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Color has degraded, not much white, or green
Since yo're getting a good picture from DVD then TV is OK. Replace (reset it first) the box.
Jan 25, 2018 | Panasonic CT-36D30 TV
Olevia tv erased all channels accidently
BEVERLYQC::
How do you " accidently erased all my chanels " from a tv??
Was the TV connected to a 'cable box' ?
Was the TV conected to 'air waves' or antena input.?
If the TV is attacned to a cable box, temperly remove the cable box INPUT wire, attache an antenna to the IMPUT AND AUTOSCAN WITH THE REMOTE CONTROL
If the TV cannot 'autoscan' in 'air wave' reception...goto menu and set input channel to ch.3 or see if there is a switch in the back that can change to ch.3 or ch.4
You should get all the 'air wave' chanels which will include ch.3 & ch.4
Oct 22, 2008 | Olevia LT42HVi 42 in. LCD Television
Tv connector cable plug slips out
you need to replace your wall cable outlet. This can be purchased at any Radio Shack or Home Depot store. You will find two mounting screws , remove them and you will have access to the junction box. If the cable system was installed in the proper manner you will find a double male connector attached to the face plate by a single securing nut. Remove this nut and replace the double male connector. simple job, hope this was a help to you.
good luck----------------tomtaso
Nov 21, 2007 | GE 25GT240 25" TV
Poor reception
It sounds like a problem with the tuner in the TV set. Hook up a VCR through the video inputs and hook the cable through the VCR and if the picture is still snowy, the problem is the cable. If the picture is clear, the problem is the tuner in the TV set. If you wanted, you could simply leave the VCR attached to the TV set and change cable channels through the VCR, or have the TV serviced. Good Luck
Jun 20, 2007 | Mitsubishi CS-40505 TV
Poor cable connection
radio shack sells type f/rca adaptors
Jun 28, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
