Question about HP PSC 2175 All-In-One InkJet Printer
Cartridge Jam I just recently recieved the printer from my boyfriends mother because it was just sitting around her house & I was in need of one. However I plugged it in and it tells me " Open door...Cartridge Jam..Fix & then press Enter." My boyfriend & I have both opened the door took out the cartridges and looked them over & put them back in & shut the door & tried to print and copy & the messages pops back up again. anyone know what I can do to get this problem fixed??
  • 48 Answers
The only thing you can do with this is make sure that there are no foreign objects that could be blocking the movement of the cartridge head. And when you insert the cartridge back, make sure you hear a clicking sound on both the cartridge and the cartridge cover when you insert it. Power down then power back up... make sure all covers are closed when you power back up. If it gives the same message, the printers sensors may be bad and it will require service or replacement. So, check with your manufacturer for warranty options.
Posted on Sep 05, 2008
MF4350d gives a paper jam error when it has no paper in it.
I hired a technician who came to house and showed me where the paper jam was hidden... found technician on craigslist for $50 flat rate, came out on Saturday. He solved the paper jam problem in 20 minutes. One place to check for paper jam you cannot see until to look behind a hinged plastic flap above the cartridge area. Remove cartridge.Above the cartridge area is a width-wide plastic piece, about 1 to 1 1/2 inch wide from top to bottom, hindged along the top edge, moves but is attached along the two lower corners of the piece by small springs (one at each corner) to the housing of the machine. You cannot easily lift the plastic flap up to look behind it for paper jam until you remove the springs. I used forceps to remove them. Tweezers may work. Don't lose them! Once you remove the springs you can easily lift up the plastic flap (it is hinged) and look behind it into the crevices for any paper. That is where we found a small piece of paper. We needed a skinny forceps to reach into the crevice to get the paper out.
Feb 16, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
My HP Officejet J4680 states that there is a cartridge jam. How do I fix this?
this issue is a little tricky as the unit may think there is a paper jam
first make sure the craddle - where the ink cartridge sit - can move freely, if it can then look for any bits of paper that may be stuck around it or in the machine, clean the rollers on the rear access door of the unit as well.
if the error message doesnt clear out then try the next step
If the carriage chute will not move then disconnect the power cord press and hold # 3 at the same time and as holding those 2 buttons re connect the power cord. if the carriage fails to move upon reset then you have a carriage jam and your printer needs servicing
Mar 29, 2010 | HP J4680 Office Jet All-In-One Printer
Xerox 5334 says it has a paper jam but i don't see one
A paper jam on this machine can be several things. Not seeing the machine, it can be in the fuser area, There is one switch there that can cause a jam. if there is a acornidan jam there the paper has to be removed.
The machine can have a bad cartrige, the pr belt maybe be a cause of the jam espeically if there is a U-7 code. (A false jam) The pr belt timing hole cannot be read by the timing hole sensor. If this is the cause, a broken mount on the copy cartridge unit can cause this problem. The cartridge reciever unit needs to be replaced.
In the registration area there is a jam sensor that can cause this type of jam. If it fell out of place, or the magnet on the back of the acutuator arm has developer beads, can cause the machine to get a jam signal.
Oct 12, 2009 | Xerox Office Equipment & Supplies
OFFICE JET 7410 PRINTER
Check the cartiridge if it is sitting nicely on its place. it seems you dint place the cartirdge properly
Apr 02, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Dell 944 carrier jam
THE CARRIER MAY HAVE A FINE PEACE OF PAPER STUCK IN THE FEEDER ROLLER OR IN THE ROLLER PANS, REMOVE EVERYTHING, GET A CAN OF AIR AND BLOW IT OUT GOOD AROUND WHERE THE PAPER FEED AND EXITS THE PRINTER, THE CARTRIDGE MAY MAYBE GETTING SNAGED ON THE PRINT HEAD ALSO. SHACK THE PRINTER UPSIDE DOWN TO GET ANY TYPE OF MATTERAIL IN THE MACHINE, IT CAN BE PAPER, PAPER CLIP, STAPLE, PENCIL, ERASER MATTERAIL,
INK BUILD UP ON THE ROLLERS, CHANGE THE TYPE OF PAPER YOU ARE USING, IT MIGHT BE CHEAP PAPER PRODUCTS, LABEL GUM STUCK INSIDE THE PRINTER HOUSING AND EVERY TIME YOU USE IT JAMS.
ROD
Feb 13, 2009 | Dell 944 All-In-One InkJet Printer
MP780 paper jam
You need to open up the unit as if repalcing a cartridge and get a torch and really look hard for the jam it can be really tiny. Look in and under cartridge roller (paper roller too) and is the cartridge aligning itself when you open the unit so thta acartridge can be changed? Good luck.
Nov 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
PRINTER ERROR-CHECK CARTRIDGE
Unplug the power cord. Try to move the cartridge to the right by hand.
Oct 03, 2008 | Sharp INKJET FAX UX-A1000
Problems with the hp c3180 all-in-one printer
Did you clean the contacts inside the printer as well as the ink might be built up where cartridge contacts touch the printer contacts in the housing. You have to be quite careful here as there is a small metal spike which grips the printer and you do not want to push this into the contacts in the housing. Just get some damp tissue and rub it over these contacts to clean up any residual ink( turn off the printer first)
Fred
Jun 14, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer cartridge jam
Oh dear, you may have a paper jam preventing it from movin, Open up the unit cover, get a torch and check thoroughly around it and rollers and down the back where paper goes behind unit too. I am willing to ber you find a tiny jam. Post back if it still won't print. Hint: sometimes you nedd to reset printer default settind and turn off and on again when jam is cleared to reset warnings.
Aug 27, 2007 | HP PhotoSmart 7760 InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
48 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
