Question about Kenwood Audio Players & Recorders
My stereo gets power put when I put my faceplate on it does not light up but i can eject a cd if I push the eject botton
What may have happened is the contacts on the faceplate or the main unit may be broken or not making contact check to see if any contacts are pushed in far or bent or missing if so replace or fix them it should work what probably happened is the contact for the display lights might have been damaged and be fixing that issue then you should gain the screen back.
Posted on Sep 05, 2008
Unit has power and lights up. None of the buttons work and cd wont eject. The CD eject button turns the unit off but won't eject the CD. Cannot change the functions. Have reset the unit and checked th
Remove the face plate and clean the contacts on both the head and the radio. It sounds like a bad connection, The base and head use serial data to talk to each other(control).If one of these connections are bad the unit will not work properly.
Oct 06, 2014 | Sony MEX-BT2900 Bluetooth Car Stereo with...
Hello, I have an odd problem with my Pioneer DEH-P9800BT Screen
Clean all contacts chemically and check all wiring for good, tight connections.
Aug 25, 2017 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
Will not turn on without removing faceplate and putting it back in
Try cleaning the contacts behind the face and on the sub panel behind the face with either q-tips and rubbing alcohol or a pencil eraser. If you use a pencil eraser, make sure you brush off the debris.
Jan 22, 2013 | Car Audio & Video
Can't get my cd to eject from car stereo
Did somebody put coins or something inside it? Try putting a high power vacume up to it and seal the whole opening with the vacume end...
Jun 18, 2012 | 2006 Chevrolet Malibu
My dual model cd770 faceplate will not stay down, I can eject and put new cd's in but I can no longer see the screen behind the faceplate, It drops then the power shuts off and brings the faceplat
No mine did that and what it is is there is a strip connecting the two faces and sometimes it gets stuck and u have to gently pull it out and it fixes the problem worked on mine
Feb 13, 2012 | Dual XD7600 CD Player
It wont eject my cds so i pulled on the cd with a pair of tweezers while it tried to pull it in and now the cd player don't work. what might be wrong and how can i fix it?
remove faceplate and find the small pinhole on the deck.Insert paperclip and hold 10-15 seconds to reset also try doing this and pushing eject
Jan 22, 2011 | JVC AM FM CD DET FACE CAR STEREO
Cd won't eject
is this a jvc?
i think if you take the faceplate off there is a manual eject button
either on the back of the radio or under faceplate
good luck
Jul 06, 2009 | JVC AM FM CD DET FACE CAR STEREO
No power to Kenwood KDC-4019 faceplate
It sounds like the stereo does not have the "ACC" voltage. It could have blown a fuse. The "ACC" voltage goes to the red wire on the harness and you get that voltage turned on only when the ignition is turned on in the car.
The symptom of the disc ejecting and nothing else works is an indication that only the constant voltage for the yellow wire is connected. Check the voltage on the red wire with the car turned on, if you have that 12 volts at the red wire, then you need the radio serviced.
It is not very likely that the faceplate has gone bad. Just because the radio will not turn on is not an indication that the faceplate is bad. It could be a voltage regulator in the radio or a circuit trace is blown, or almost anything else. There are many reasons that the radio would have the problems you describe and it can only be found out for certain by troubleshooting the radio on a test bench with the proper tools. If you have a multimeter and a power supply I can guide you thru troubleshooting the radio and even email you the service manual in PDF format if you would like to take a crack at it yourself.
Let me know how you want to proceed.
Dave
Oct 25, 2008 | Kenwood KDC-4019 CD Player
Sony DVD RW DRU-820A
HI,
Double check the Ribbon Cable Connector is installed Correctly ( 40-80 Strand IDE ) sometimes if these are not fitted squarely Or pushed in hard enough. Can cause a Problem.
Also try the emergency eject procedure on The Drive. Small jewellers screwdriver Or Needle, insert into the drives faceplate ( pinhole in drives faceplate drawer ) push to open dvd drawer. pull out drawer Gently. And push back in. This ocassionally works for a stcking Drawer/eject mechanism.
Finally try the drive without a disk in ( open/eject Or Close )
Mike @ Compurepair.
Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
50 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
