Question about RCA TruFlat 27F520T 27" TV
Television suddenly powers off and on again
This problem has been getting worse for the past couple of months - everytime I try to use the TV, after a few minutes, the unit suddenly turns off, then on again, then off again immediately, and on, looping like this endlessly until I hold the power button for a few seconds to turn the unit off completely. All my other devices (DVD, Playstation, sattelite box) work fine, so it's not a power fluctuation. Is it something that's worth repairing, or should I get a new TV? This unit is only four years old. Thanks!
  • 85 Answers
Replace keyboard cba
Posted on Sep 06, 2008
  • hiwatt Sep 06, 2008
    replace keyboard cba
My RCA D52W19 HDTV Ready TV will not turn on. The power led comes on three times after pressing the button on the tv itself or attempting to power on with the remote. The condition has been getting worse...
Hi Aaron,
I just want to ask you something before I give the solution, does the unit gone to start-up problem (needs warm-up before it finally turn on, needs to pressed the power button key several times, needs to unplug from the outlet and plug it back in)before, you have said that you've encountered it last few months?
Jdvillanueva
Sep 29, 2011 | RCA D52W19 52" Rear Projection Television
(Please Help)Need to unplug my TV everytime to turn it on
you have a bad power supply, here is the part number
MLT169B
google it or try to get here :>
http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=MLT169B
Fosg2000, Rate me Please
Mar 15, 2010 | Akai LCT4216 42 in. LCD Television
Yellow circle in the middle of the screen. It has
Not sure if this will help...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba 42H83 42" Rear Projection...
Hi. I have a 2004 52' Flat screen projection TV. For the past couple months, we have turned on our TV and all we hear is sound, but no picture comes up. We thought the bulb was having problems. We ordered...
The buzzing is the ballast arc gap,normal sound. When the tv starts does the lamp start to come on. Can you see any light from the back? Sounds like bad ballast. Unfortunatly this part is no longer available. the light engine will have to be removed and sent to Toshiba to be rebuilt.
Nov 26, 2009 | Toshiba 52HM95 52" HDTV Projection...
Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Apr 07, 2009 | Sharp LC20SH7U Television
Hi Sense 26'' LCD2629 No Picture No Sound Just Black/White Lines
Unplug the TV to let the memory clear. Wait 1 minute, replug, see if that works.
Sep 03, 2008 | Hisense TL2620 26 in. LCD Television
Won't turn on
Hi, everyone. Me too have the same problem. TV just stays in red but won't turn to blue. I tried unplugging then wait and restart again, sometimes it will work but lately that trick doesn't work anymore. Then somebody suggested to open the back of the tv (it's not hard... just a lot of screws and a couple of bolts to remove) and clean (vacuum) the exhaust fan. Out of frustration, I did open the back and clean the the fan (has a lot of dust on the blades) and everywhere where there is dust. Just be careful not to touch any part of the printed circuit board with the vacuum nozzle to eliminate the destructive effect of static electricity. Or while you're cleaning it you have to hold the metal frame with your other hand to ground yourself (by the way you have to unplug your tv before you start opening the back). After the cleaning then covering the back, the tv worked... for only a few hours. It did stop working again as soon as I turned it off then on again. Again I opened the back, this time I removed the power supply board ( that's the biggest board and located above where you connect all your wirings). Got myselt a small brush and start brushing and vacuuming the dust out. I don't know if the cleaning did the trick or it was the unplugging of the connectors from the power supply board. All these work did the job... my tv is still working for almost three weeks now. Another thing, when you have a a time warner cable with a dvr box where you can program its remote to power most of your equipment in sequence by pressing the remote power button, I set it so that the tv will be powered up last considering that power can fluctuate everytime a unit starts up specially when they are all connected to the same power/surge protector... tv doesn't like it when the power fluctuates while it is still starting. Hope these helps.... (Hitachi 42HDS69)
May 21, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Toshiba Plasma TV Green and Pink (Diffusion?) Problem
I could be wrong but sounds like your plasma display is going bad. What is your model number?
Dec 28, 2007 | Toshiba 42HP66 42 in. LCD Television
Ilo Flat screen
if your tv is on warranty take it back to supplier for another.if the warranty has expired have a tech repair your tv the Audio,or power is defected good luck.
May 14, 2007 | iLO 2600 Television
RCA TruFlat  27F520T 27" TV Logo
44 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
