Question about Polaroid PhotoMax PDC 640 M Digital Camera
ERROR: code 402 in LED panel
When I turn on my camera, the camera beeps and the shows 402 in the LED panel. What could the problem be?
    Master:
  • 450 Answers
Error code 402 indicates an issue with the SmartMedia card. Make sure that the memory card is properly inserted into the camera. If the card is not the one that was originally packaged with your camera, check to make sure that it meets the camera's requirements. The PDC 640 digital camera accommodates SmartMedia cards at 2 MB, 4 MB and 8 MB capacities. If the condition persists after checking the above, the SmartMedia card may be faulty or corrupted and in need of replacement.
Posted on Sep 21, 2005
SOURCE:
When I am starting my pc it is making a long beep sound and my keyboard is not working every time I press f1 it is making a beep sound
Also, you can search for a free (or trial) download of [b]PC_Bios_Codes[/b] or similar on your browser.
I used this applet for many years, basically just a small database list of Beep codes for various BOIS'es. (AMI, Award, etc).
These beeps are the computer's audio code of system status, including any system/hardware errors it finds.
Sort of like 'SOS' in morse code.
Apr 08, 2018 | Time Computers & Internet
Gw712 doesnt start just beeps
Lets see if an error code pulls up.
With the machine off, press and hold the Wash Temp Down button and then push the power button until the machine gives 2 short beeps and lights up. Now press the Spin Speed Up button three times so that the Hold and Slow LEDs are illuminated.
The eight wash progress LEDs will show the error code.
Apr 29, 2014 | Washing Machines
Fisher and Paykel E402B beeping, freezing symbol flashing, crisper bins freezing.
sounds like a sensor faulty will need a tech to recify the problem.
Nov 29, 2012 | Fisher and Paykel Refrigerators
I have a brand new SAM4S ER-180 cash register. If I plug in the power it immediately goes to error mode & beeps at me. The LED screen is reading E Lo0000 or E Lo0.00. I have tried everything & dont...
A beeb normally means defective (hardware failure) DOA. Go back to your store for a warranty replacement.
Does it start without the scanner?
http://tinyurl.com/69hd8kf
Does computer beep when you turn it on? Information on beep codes bleeps on booting, boot codes led flashing flashes 1 2 3 4 5 once twice three times on and off times on boot. power on self test fail, boot failure.
Quick help guides and LED flashing errors codes search for error codes using your
Service manual.
Maybe more info here
http://www.goodson.com.au/service/FrmService.htm
Feb 13, 2011 | Computers & Internet
I have the Caddx NX-6 alarm system. Problem: Alarm system will not arm when entering the 4 digit code. Symptom: I have all doors/windows/zones closed. LED displays READY. I press the code and get 3...
If the power was out for 5 hours and the control panel still shows 'low battery', it's probably time to replace the battery for the control panel. However, this shouldn't keep the alarm panel from arming up. I would first try to re-start the control panel by removing the power and battery connection for a few seconds and plugging it back in. After that, it would be a good idea to re-enroll all of your attached sensors, etc. by entering into programming mode and exiting. Press * 8 + {go code} then just press exit. The default 'go' code is 9713. After about 15 seconds, the panel will have auto-enrolled each attached device. Try arming and disarming the panel. Be careful of setting off the alarm, as your monitoring station may dispatch police, etc. in the event of alarm. This is why having a certified alarm installer do this work is a good idea, as they can put your account with the monitoring station on 'test' so alarm signals are recorded for testing purposes but are not acted upon.
Feb 11, 2011 | GE / Caddx NX 6 Fastpack with NX 1308E LED...
Kenmore model 417-44052400 front load washer error code E04 (5 vertical LED flashes & beeps and 4 start led flashes. I ran the diagnostic test, it dose everything up to tumble, it won't tumble or...
Take the front lower panel off 2 or 3 screws you will see the pump.You will see a black "baffle" atatched to the pump.squeeze it feel a sock?Take the boot loose and clear.Only other thing would be the motor control board back let hand corner replaced many of these when tubs dont move.I hope this helped.
Nov 17, 2009 | Crock Pots & Slow Cookers
Abit beep code error and LED code of 87
Hi had similar problem today, 1 long 4 short beeps - so not exactly the same.
I ended up resetting the CMOS - and this fixed my problem.
Hope that helps!
Jun 06, 2009 | Abit AX8 Motherboard
Diagnostic Indicator
Beep codes and power LED status are pre-post errors. Usually beep codes indicate a problem with a memory module. Power LED is solid green for normal operation. Solid or blinking Amber color power LED indicates a power distribution problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 13, 2008 | Dell Dimension 2400 PC Desktop
Motherboard message LED message is --
Your motherboard has died .
No beep code explains it all .
LED lights and even fans spins only tells me that your getting power to the motherboard , but No beep code is crucial .
Every motherboard will beep once when your first turn on and beep once again before the Opertional System boots up .
Sorry again for your loss ...
Aug 07, 2008 | Evga nForce 680i SLI (122CKNF68)...
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Polaroid PhotoMax PDC 640 M Digital Camera Logo
88 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
